Dr_Ruminahui Posted June 1, 2025 Share Posted June 1, 2025 (edited) The Call to Arms 2025 CHAOS STRONGHOLD Time to bust out those brushes and paints and stand ready to represent your Forum/s of choice and aid them on the path to claim Victory!!!! What is The Call to Arms, I hear you ask? The Call to Arms is a multi-forum event designed to encourage us all to start a new army, or bolster our current forces. The Forums of the B&C are divided up into five Strongholds; The Astartes Stronghold Adeptus Astartes Black Templars Blood Angels Dark Angels Space Wolves Ultramarines Grey Knights Deathwatch (note, Deathwatch models can be vowed either in the Astartes or Imperium Strongholds) The Imperium Stronghold Adepta Sororitas Adeptus Mechanicus Astra Militarum Imperial Knights Talons of the Emperor The Imperium of Mankind Deathwatch (note, Deathwatch models can be vowed either in the Astartes or Imperium Strongholds) The Chaos Stronghold Chaos Daemons Chaos Knights Heretic Astartes Death Guard Emperor's Children Thousand Sons World Eaters The Realm of Chaos The Xenos Stronghold Aeldari Drukhari Genestealer Cults Leagues of Votann Necrons Orks T'au Empire Tyranids The Heresy Stronghold Age of Darkness Epic Scaled Heresy Games These five Strongholds will act as the hub for each of the five main Factions, and will for the 3 Month duration of the Call to Arms, run independently of the four other Strongholds. Each Stronghold may have different targets and goals, and even their own mini/complementary events, all with unique badges and achievements, but at the end of the 3 months, the five Strongholds will face off, and overall winners will be declared. Dates Start Date: 15th JUNE 2025 End Date: 15th SEPTEMBER 2025 (Timezone will be GMT -8 [so, North American Pacific Coast time], please make local adjustments for time) So, how is it all going to work? 1. As each of the Strongholds are acting (initially) as their own Events, you may choose to focus within a single Stronghold, or participate in all five Strongholds, and any complementary/mini-events that you would like to. Your Vows will be treated independently in each Stronghold, meaning a Failed Vow in one Stronghold will NOT effect Vows in the other Strongholds. 2. Models pledged to a Stronghold must come from the army books associated with those Forums covered by each Stronghold. The exceptions to this are Titans and models not associated with a given faction (such as Necromunda models and terrain), these models / units may be pledged to any Stronghold. 3. You may join in any of the Events at any time within the 3 Month time-frame of The Call to Arms 4. For each Stronghold, you have a MAXIMUM of 3 Vows, you must finish your active vow before pledging to a second or third vow. 5. In addition to the three Vows, any model in the 10pt Category or higher will fit into the "Job's a Big'un" Vow, and will run separate from the 3 Vow limit and have the entirety of the 3 months to be completed. 6. Once recorded, Vows may not be altered, however special considerations may be made upon request. 7. There is no minimum pledge, you may vow 1 model, or your entire collection, but beware, failing your last active vow will invalidate any completed vows you may have already submitted. How do I join in? Each model has a point value based upon its size, and the comparative amount of effort and time it takes to paint said model, listed below are are the points-per-model, more specific lists can be found in each Forums Rally Point thread, but I've added some generic examples below, 1pt Infantry 2pts Cavalry/Bikers 3pts Heavy Weapons Teams / Walkers (Dreadnaughts, Sentinels) 4pts Skimmers / Light Vehicles (Landspeeders, ATV, Armigers) 5pts Small Tanks (Leman Russ, Rhino Variants) 6pts Large Tanks (Rogal Dorn, Sicaran, Land Raider) 8pts Superheavies (Baneblades etc) 10pts Imperial Knight etc Characters 5pts Leader/Character models 10pts Primarchs Note: Characters with Retinue, I.E. Saint Celestine. The Leader model is worth 5pts, the other models are pointed as to their type - for example, Saint Celestine and her bodyguard would be 7 points - 5 for the Saint (leader), 1 each for her 2 seraphim buddies. 40K Scale Titans 20pts Warhound Titan 30pts Reaver Titan 40pts Warbringer Titan 50pts Warlord Titan Terrain 1pt 3 Munitorum Barrels, 4 Munitorum Crates, Zone Mortalis/Gallowdark Column, Octarius Ramshackle Bridges 2pts Aegis Defence Line Section, Aegis Defence Platform, Galvanic Servo-haulers, Thermic Plasma Conduit Section, Imperialis Ruins Wall Section, Zone Mortalis/Gallowdark Wall, Octarius Scrap Heap/Barricade 3pts Fronteris Vox Antenna, Fronteris Auspex Shrine, Thermo-exchanger Shrine, Octarius Oil Rig, Necromunda Fuel Tanks 4pts Munitorum Container, Mechanicus Transterranic Gantry, Galvanic Servo-crane, Big'ead Bossbunka, Skull Alter, Noctilith Crown, Octarius Ramshackle Walls 5pts Tidewall Droneport, Tidewall Shieldline, Feculant Gnarlmaw, Miasmic Malignifier 6pts Fronteris Landing Pad, Mechanicus Forgeshrine, Mechanicus Galvanic Magnavent 8pts Fronteris Hab Bunker, Manufactorum Administratus, 10pts Zone Mortalis Gang Stronghold Note: Custom/Scratchbuilt terrain- use this list as a guide as to how many points tour terrain is worth, but please make sure to mention your terrain is custom when Vowing. You may vow ANY MODEL that is covered by THIS STRONGHOLD, but you must allocate your points to only one SUBFACTION. These Subfactions are the ones listed under the various Strongholds above, and are the various B&C forums/subforums, with 2 exceptions: a) Deathwatch is a valid Subfaction for both the Astartes and Imperium Strongholds, despite not having a dedicated forum/subforum; and b) in the HERESY STRONGHOLD, the Subfactions are "Emperor" and "Warmaster", not the 2 B&C forums listed above. NOTE: Your chosen Subfaction doesn't have to correspond to your vowed models, although it typically does. Please make your vows in this thread in the following format; "I, {insert username}, heed the Call to Arms and pledge to paint {insert units/models} for {xxx pts} for the Glory of the {Subfaction name} and the {Stronghold name} Stronghold on or before 15th September 2025, or bear the badge of failure until year's end." For example: "I, Dr Ruminahui, heed the Call to Arms and pledge to paint 6 possessed, a Master of Possession, Lucius the Eternal and a Necromunda Fuel Tanks for 19 pts for the Glory of the Emperor's Children and the Chaos Stronghold on or before September 15th, or bear the badge of failure until year's end." The post that contains your Vow must include starting pictures that contain all the models from the Vow. Starting models may be in any of the following conditions; In the box On the Sprue Assembled Single Colour Primed Sub-assemblies primed in different colours will be acceptable, I.E. chassis in Leadbelcher, with armour plates in secondary colour. Additionally, you may pledge models you have not yet received I.E. Warhammer: Imperium Subscription, just make sure a image is edited in to your Vow post once you've received the models, and make a post indicating that you have done so. Your Vow is considered complete when you declare it so, and post completed pictures of all models contained within the Vow. Although "Complete" is to your own standard, we would like you to aim for GW's "Battle Ready", with the miniatures based. If basing is something you don't do, or won't be doing within the Event's timeline, please return the bases to flat black or brown as this will greatly enhance the Completed presentation. Required Completion Pictures: Please include 1 image with a complete shot of the entire Vow, I also encourage everyone to include additional images for each squad/unit in the vow,. Once you have made your vow, pop this badge of Participation into your Signature, Will there be any awards? Yes!! There will be Badges and Achievements within the Astartes Stronghold. Note, all badges/ranks/achievements are a different thing and entirely separate from the ranks and achievements tracked by the forum software. Event Failed: Spawn 10 points: Chosen 25 points Aspiring Champion 45 points: Champion 75 points: Lord 100+ points: Warmaster Artificer - Top 1, 2, or 3 best painted models from each Forum, chosen by the forum Moderators, Administrators and Librarians. Princeps - Awarded to all completed 40K scale Titans Chaos Champion - Awarded to the Frater who individually paints the most points worth of models in the Chaos Stronghold Champions of the Horde - The Subfaction for each Stronghold with the highest overall points worth of models Champion of the Call - The Subfaction for each Stronghold that has the Highest Participation vs. Completion Percentage. As to the overall competition between the Strongholds, there will also be Badges awarded for the following; Masters of the Horde - The Stronghold that completes the highest overall points worth of models. Masters of the Call - The Stronghold that has the Highest Participation vs. Completion Percentage. Master Artificer - Voted best painted Model, chosen from the 5 Stronghold Artificers. In addition to the Badges and Achievements above, there will be additional Awards for the following 4 categories. At this stage there are no physical prizes like last year, but that *MAY* change by the end of the Event. Favourite Young Blood - This category is for Participants who have been building and/or painting models for less than 12 months. Anyone wishing to participate as A Young Blood will need to specifically declare that are are doing so when making their Vows. At the conclusion of the Event all Young Blood Entries will be placed into a Poll for the B&C at large to vote on and pick a Favourite. The voting criteria for this category is not about picking the best painted model, but the model that inexplicably pulls a smile on your face, one that makes you think, damn that's cool.. Master of the Forge - Best Conversion or Kit-bash. Anyone wishing to participate for the Master of the Forge Badge and Prize will need to specifically declare that they are doing so when they vow the model. Stronghold Artificer - Awarded to five Participants, one from each Stronghold for the Best Painted Model in from the Stronghold, chosen by the Frater via Poll. Grand Marshal - Individual with the Most Points of Models Painted across all Strongholds That's it, you've done it, you've made it to the end!!! If you have any questions or queries, contact me, @Dr_Ruminahui and I'll be more than happy to help you out. F.A.Q.s Q- If I have models with different coloured heads or shoulder pads, can they be primed different colours IE. Black templars or Eldar Guardians? A- Yes, this is acceptable. Q- I want to paint Traitor Guard, is there a way to pledge them to Chaos? A- Yes, for the purposes of Traitor Guard, the Astra Militarum units may be pledged to Chaos. The Realm of Chaos is the most appropriate forum. Q- Are 3D prints allowed? A- Yes, as long as they are board appropriate, 3D prints can be pledged to the Call to Arms. Use the points associated with the unit they represent. THIS THREAD WILL REMAIN LOCKED UNTIL JUNE 15, 2025, AT WHICH TIME VOWS MAY COMMENCE Edited May 29, 2025 by Dr_Ruminahui gaurdian31 and Grotsmasha 2 Back to top Link to comment https://bolterandchainsword.com/topic/385991-call-to-arms-2025-chaos-stronghold/ Share on other sites More sharing options...
Dr_Ruminahui Posted June 1, 2025 Author Share Posted June 1, 2025 (edited) PARTICIPANTS TOTAL STRONGHOLD RESULTS - Pledged: 843 pnts / Completed: 560 pnts / Secured: 560 pnts / 66.43% Completed - 18 Participants, 13 (72.22%) completed all Chaos vows Chaos Demons - Pledged: 181 pnts / Completed: 133 pnts / Secured: 133 pnts / 73.48 % Completed Participants: (3 Total, 2 Secured - 66.67%) Antarius - Vow 1: 74 points - Complete; Vow 2: 39 points - Complete 40x Plaguebearers3x Beasts of Nurgle4x Heralds1x Daemon Prince 12x Plague Drones2x Heralds1x Daemon Prince Scion - Vow 1: 20 pnts - Complete 1x Kytan demon engine 1x Lord of change nusphigor - Vow 1: 48 pnts - Incomplete 1x daemon prince 15x cultists 5x flamers of tzeentch 7x pink horrors 16x blue horrors Chaos Knights - Pledged: 171 pnts / Completed: 151 pnts / Secured: 151 pnts / 88.30% Completed Participants: (3 Total, 2 Secured - 66.67%) Agnostic Doggo - Vow 1: 66 pnts - Complete 14x Wardogs 1x Tyrant Boc - Vow 1: 85 pnts - Complete 1x Knight lancer 1x Knight despoiler 1x Knight abhorrent class (type TBA) 4x Wardogs18 12x Noise marines (6 noise marines replaced by 2x Lord Kakaphonists for same point value) 10x Tormentors/infractors 6x Flawless blades 1x Lord exultant Iron Warrior w/ Servo Arm - Vow 1: 20 pnts - Incomplete 2x Abhorrent knights Heretic Astartes - Pledged: 94 pnts / Completed: 94 pnts / Secured: 94 pnts / 100.00% Completed Participants: (4 Total, 4 Secured - 100.00%) Cryptix - Vow 1: 32 pnts - Complete 1x Master of Possession22x Possessed1x Sorcerer in Terminator armor gaurdian31 - Vow 1: 15 pnts - Complete 1x Chaos terminator lord1x Master of executions1x Warpsmith WBRBloom - Vow 1: 42 pnts - Complete 13x Heretic Astartes 2x Havocs 1x Daemon Prince 1x Chaos Predator 1x Obliterator 1x Chaos Lord in Terminator Armour 1x Chaos Lord 1x Chaos Sorcerer Volgon - Vow 1: 5 pnts with MofF entry - Complete 1x Dark Apostle [Master of the Forge] Death Guard - Pledged: 76 pnts / Completed: 0 pnts / Secured: 0 pnts / 0.00% Completed Participants: (1 Total, 0 Secured - 0.00%) Metzombie - Vow 1: 76 pnts - Incomplete 40x Plague Marines1x Blightlord terminator1x Lord of Poxes1x Lord of Virulence1x Biologus Putrifier1x Foul Blightspawn1x Malignant Plaguecaster1x Plague Surgeon1x Demonprince Emperor's Children - Pledged: 36 pnts / Completed: 36 pnts / Secured: 36 pnts / 100.00% Completed Participants: (1 Total, 1 Secured - 100.00%) Dr_Ruminahui - Vow 1: 36 pnts - Complete 10x Infractors 6x Noise Marines 2x Lord Exaulted 1x Lord Kakaphony 1x Rhino Thousand Sons - Pledged: 28 pnts / Completed: 0 pnts / Secured: 0 pnts / 0.00% Completed Participants: (1 Total, 0 Secured - 0.00%) Norman Paperman - Vow 1: 28 pnts - Incomplete 1x Plagueburst Crawler 5x Blightlord Terminators 1x Lord of Poxes 2x Sekhetar Robots 5x Scarab Occult Terminators 1x Exalted Sorceror World Eaters - Pledged: 17 pnts / Completed: 17 pnts / Secured: 17 pnts / 100.00% Completed Participants: (1 Total, 1 Secured - 100.00%) Dr. Clock - Vow 1: 17 pnts - Complete 1x 'Skarbrand' 1x 'Slaughterbound'1x'Bloodcrusher' Realm of Chaos - Pledged: 240 pnts / Completed: 129 pnts / Secured: pnts / 53.75% Completed Participants: (4 Total, 3 Secured - 75.00%) Madao - Vow 1: 62 pnts - Complete Dark Commune Firebrand 2 Rogue psykers 5x Accursed Cultists (small) 3x Accursed Cultists (large) 27x Cultists Sitnam - Vow 1: 16 pnts - Complete; Vow 2: 24 pnts with MotF entry - Complete; Vow 3: 11 pnts - Complete 1x scout sentinel 1x chimera 1x doomhammer 10 x Cultists4 x Dark Commune Retinue + Cult Demagogue [Master of the Forge] 1 x Cultist Firebrand 4x roughriders 1x sentinel Tallarn Commander - Vow 1: 10 pnts - Complete, Vow 2: 6 pnts with MotF Entry - Complete 2x Predator Annihilators 1x Defiler [Master of the Forge] Teetengee - Vow 1: 111 pnts with MotF entry - Incomplete 1x Grey Seer with Venom-Exterminator (Character) 1x Clawlord on Cyber-rat (Juggerlord Equivalent)1x Grey Seer on (and off) Crawling Cacophony (Triarch Stalker Equivalent) - [Master of the Forge] 1x Archwarplock Engineer (Character) 1x Clan Assassin with Warpstone Arquebus (Character) 1x Warplock Engineer (Character) 1x Clawleader in Power Armor (Character) 10x Thundervermin (Infantry) 1x Crisis-Track (Krios Equivalent) 1x Ratling Stalker (Doomstalker Equivalent) 3x Jezzail-Bot Teams (1 rat, 1 gun each) 10x Clanrats (Overseer with Blast pistol, 9 Blasters) (Infantry) 10x Clanrats (Overseer with Autopistol, 8 Autoguns, 1 Grenade Launcher) (Infantry) 10x Clanrats (Overseer with revolver, 9 Shotguns) (Infantry) 10x Clanrats (Overseer with Pistol, 1 Web Pistol, 8 Pistols) (Infantry) 3x Rat Ogryns (Ogryn equivalent) 1x Drillbeetle (Walker) Edited September 17, 2025 by Dr_Ruminahui gaurdian31 and Tallarn Commander 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385991-call-to-arms-2025-chaos-stronghold/#findComment-6113398 Share on other sites More sharing options...
Dr_Ruminahui Posted June 15, 2025 Author Share Posted June 15, 2025 (edited) * ALL STRONGHOLDS ARE NOW OPEN, YOU CAN NOW MAKE YOUR VOWS * Happy painting! Be sure to cheer on your fellow stronghold participants! As a reminder, all vows must be completed by September 15th. Edited June 15, 2025 by Dr_Ruminahui Tallarn Commander and gaurdian31 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385991-call-to-arms-2025-chaos-stronghold/#findComment-6116252 Share on other sites More sharing options...
Dr_Ruminahui Posted June 15, 2025 Author Share Posted June 15, 2025 I might as well kick this off - "I, Dr_Ruminahui, heed the Call to Arms and pledge to paint: 10x Infractors (10 pnts) 6x Noise Marines (6 pnts) 2x Lord Exaulted (10 pnts) 1x Lord Kakaphony ( 5 pnts) 1x Rhino (5 pnts) for 36points for the Glory of the Emperor's Children and the Chaos Stronghold on or before 15th September 2025, or bear the badge of failure until year's end." Alby the Slayer, W.A.Rorie, Boc and 8 others 8 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/385991-call-to-arms-2025-chaos-stronghold/#findComment-6116283 Share on other sites More sharing options...
Agnostic Doggo Posted June 15, 2025 Share Posted June 15, 2025 Time to risk that mark of shame! "I, Agnostic Doggo, heed the Call to Arms and pledge to paint 14 Wardogs (56 pnts) and One Tyrant Knight (10 pnts) for 66 pts for the Glory of the Knights of the 8 pointed Table and the Chaos Stronghold on or before 15th September 2025, or bear the badge of failure until year's end." Spoiler More shots of in progress spraying available but figured this is enough for Pledge Boc, Norman Paperman, Dr_Ruminahui and 7 others 5 3 2 Back to top Link to comment https://bolterandchainsword.com/topic/385991-call-to-arms-2025-chaos-stronghold/#findComment-6116307 Share on other sites More sharing options...
Scion Posted June 15, 2025 Share Posted June 15, 2025 Yippie! Let's go for it again! And I promise I will give some more updates this year around @Dr_Ruminahui Although I got a early question? I really want to paint my Kaitan ravager and a lord of change as a first start off vow to get into the paint flow. How do I process the points? to both World eater and chaos daemon subfactions or something else? Thanks, Scion Dr_Ruminahui, gaurdian31 and Tallarn Commander 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/385991-call-to-arms-2025-chaos-stronghold/#findComment-6116318 Share on other sites More sharing options...
Norman Paperman Posted June 15, 2025 Share Posted June 15, 2025 (edited) Here we go! I, Norman Paperman, heed the call to arms and pledge to paint: 1x Plagueburst Crawler (4p) 5x Blightlord Terminators (5p) 1x Lord of Poxes (5p) 2x Sekhetar Robots (4p) 5x Scarab Occult Terminators (5p) 1x Exalted Sorcerer (5p) Twenty-eight (28) points for the glory of the Thousand Sons and the Chaos Stronghold before the 15th of September, or bear the badge of failure until the year's end. Sorcerer sprue. (Current vow only includes one) Edited June 16, 2025 by Norman Paperman Added sorc sprue Grotsmasha, Dr. Clock, Tallarn Commander and 5 others 5 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/385991-call-to-arms-2025-chaos-stronghold/#findComment-6116341 Share on other sites More sharing options...
Dr_Ruminahui Posted June 15, 2025 Author Share Posted June 15, 2025 (edited) 6 hours ago, Scion said: Although I got a early question? I really want to paint my Kaitan ravager and a lord of change as a first start off vow to get into the paint flow. How do I process the points? to both World eater and chaos daemon subfactions or something else? You can vow whatever you want that belongs in the Chaos Stronghold - so knight, demons, marines, traitor guard, cult legions, necromunda figures, terrain, etc. Then chose whatever subfaction you feel is the centre of gravity of the models you are painting or of your participation in the hobby as a whole. So, that could be World Eaters, Demons or whichever chaos subfaction you think fits best - we don't divide points nor vows between subfactions (so, all your vows in a given stronghold are for the same subfaction). Edited June 15, 2025 by Dr_Ruminahui Scion, Tallarn Commander and gaurdian31 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/385991-call-to-arms-2025-chaos-stronghold/#findComment-6116367 Share on other sites More sharing options...
Dr_Ruminahui Posted June 15, 2025 Author Share Posted June 15, 2025 3 hours ago, Norman Paperman said: (I forgot to put the sorceror sprue in the pic) Just edit your post with a new photo to include it, or to include it as a seperate photo, or cut it from your vow - all vows need to have a starting picture of each vowed model. Tallarn Commander, Norman Paperman and gaurdian31 1 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385991-call-to-arms-2025-chaos-stronghold/#findComment-6116368 Share on other sites More sharing options...
Scion Posted June 15, 2025 Share Posted June 15, 2025 (edited) "I, Scion, heed the Call to Arms and pledge to paint a kytan daemon engine of khorne and a Lord of change for 20 points for the Glory of the Chaos Daemons and the Chaos Stronghold on or before 15th September 2025, or bear the badge of failure until year's end." Edited June 15, 2025 by Scion gaurdian31, Tallarn Commander, sitnam and 4 others 4 3 Back to top Link to comment https://bolterandchainsword.com/topic/385991-call-to-arms-2025-chaos-stronghold/#findComment-6116385 Share on other sites More sharing options...
Dr_Ruminahui Posted June 15, 2025 Author Share Posted June 15, 2025 Thanks Scion, though that's 20 points as each of those models is worth 10 points. Tallarn Commander, Scion and gaurdian31 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/385991-call-to-arms-2025-chaos-stronghold/#findComment-6116390 Share on other sites More sharing options...
Tallarn Commander Posted June 15, 2025 Share Posted June 15, 2025 "I, Tallarn Commander, heed the Call to Arms and pledge to paint 2 Chaos Predator Annihilators for 10 points for the Glory of the Realm of Chaos and the Chaos Stronghold on or before 15th September 2025, or bear the badge of failure until year's end." Pair of Predators Boc, Grotsmasha, W.A.Rorie and 3 others 3 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/385991-call-to-arms-2025-chaos-stronghold/#findComment-6116407 Share on other sites More sharing options...
Boc Posted June 15, 2025 Share Posted June 15, 2025 (edited) I, Boc, heed the Call to Arms and pledge to paint one Knight Lancer, one Knight Despoiler, one Knight Abhorrent (not sure yet what I'm building it as), 4 war dogs, 18 noise Marines, 10 infractors/tormentors, 6 flawless blades, and one Lord Exultant for 85 points for the Glory of the Realm of Chaos and the Chaos Knights on or before 15th September 2025, or bear the badge of failure until year's end. Edited June 15, 2025 by Boc Grotsmasha, Agnostic Doggo, Tallarn Commander and 4 others 5 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385991-call-to-arms-2025-chaos-stronghold/#findComment-6116441 Share on other sites More sharing options...
Dr_Ruminahui Posted June 15, 2025 Author Share Posted June 15, 2025 (edited) 1 hour ago, Boc said: [...] for the Glory of the Realm of Chaos and the Chaos Knights [...] That's quite the vow, Boc - I look forward to many bloody skulls bases in the future. Is your subfaction of choice Realm of Chaos or Chaos Knights? I assume you meant Chaos Stronghold rather than Realm of Chaos (aka chaos mortals), but thought I would check. Anyway, I have you in knights for now - let me know if I should move it. Edited June 15, 2025 by Dr_Ruminahui gaurdian31 1 Back to top Link to comment https://bolterandchainsword.com/topic/385991-call-to-arms-2025-chaos-stronghold/#findComment-6116457 Share on other sites More sharing options...
Boc Posted June 15, 2025 Share Posted June 15, 2025 1 hour ago, Dr_Ruminahui said: Is your subfaction of choice Realm of Chaos or Chaos Knights? I assume you meant Chaos Stronghold rather than Realm of Chaos Chaos Knights, i blame a bad copy paste from @Tallarn Commander's vow haha Dr_Ruminahui, gaurdian31 and Tallarn Commander 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/385991-call-to-arms-2025-chaos-stronghold/#findComment-6116470 Share on other sites More sharing options...
sitnam Posted June 16, 2025 Share Posted June 16, 2025 "I, sitnam, heed the Call to Arms and pledge to paint one counts as Scout Sentinel, one counts as Chimera, and one Doomhammer for 16 points for the glory of the Realm of Chaos and the Chaos Stronghold on or before 15th September 2025, or bear the badge of failure until year's end." Spoiler Norman Paperman, Boc, Tallarn Commander and 2 others 3 2 Back to top Link to comment https://bolterandchainsword.com/topic/385991-call-to-arms-2025-chaos-stronghold/#findComment-6116478 Share on other sites More sharing options...
Cryptix Posted June 16, 2025 Share Posted June 16, 2025 "I, Cryptix, heed the Call to Arms and pledge to paint one Master of Possession, 22 Possessed, and a Sorcerer in Terminator Armor for 32 points for the glory of the Heretic Astartes and the Chaos Stronghold on or before 15th September 2025, or bear the badge of failure until year's end." using the event to kickstart off my new word bearers army, goal is to get another army that can get dual use in 30k and 40k after my Dusk Raiders drifted away from that ideal by a bit. There was supposed to be a helbrute in the Vow as well but we started a crusade and I needed it in my initial roster so it got painted early W.A.Rorie, Dr_Ruminahui, sitnam and 4 others 5 2 Back to top Link to comment https://bolterandchainsword.com/topic/385991-call-to-arms-2025-chaos-stronghold/#findComment-6116484 Share on other sites More sharing options...
gaurdian31 Posted June 16, 2025 Share Posted June 16, 2025 (edited) I plan on getting me pledge pictures in tomorrow, it'll be a Chaos Terminator Lord, Master of Executions and Warpsmith to start. "I, gaurdian31, heed the Call to Arms and pledge to paint: Chaos Terminator Lord, Master of Executions and Warpsmith for 15 points for the Glory of the Word Bearers and the Chaos Stronghold on or before 15th September 2025, or bear the badge of failure until year's end." Spoiler Time to start using up all my reactions! Edited June 17, 2025 by gaurdian31 Added picture of vow and updated the vow for Word Bearers Tallarn Commander, Boc, sitnam and 2 others 4 1 Back to top Link to comment https://bolterandchainsword.com/topic/385991-call-to-arms-2025-chaos-stronghold/#findComment-6116564 Share on other sites More sharing options...
WBRBloom Posted June 16, 2025 Share Posted June 16, 2025 (edited) "I, WBRBloom, heed the Call to Arms and pledge to paint: 8x Heretic Astartes (bolters) (8 points) 5x Heretic Astartes (Bolter and Chainswords) (5 points) 2x Chaos Space Marines Havocs (old metal miniatures) (2 points) 1x Daemon Prince of Chaos Undivided (old metal miniature) ( 5 points) 1x Chaos Predator (5 points) 1x Obliterator (2 points) 1x Chaos Lord in Terminator Armour (5 points) 1x Chaos Lord with Mark of Nurgle (5 points) 1x Chaos Sorcerer with Mark of Nurgle (5 points) for 42 points for the Glory of the Black Legion, Chaos Undivided and the Chaos Stronghold on or before 15th September 2025, or bear the badge of failure until year's end." Edited June 17, 2025 by WBRBloom Formatting and counting. Scion, gaurdian31, sitnam and 5 others 5 3 Back to top Link to comment https://bolterandchainsword.com/topic/385991-call-to-arms-2025-chaos-stronghold/#findComment-6116583 Share on other sites More sharing options...
Dr_Ruminahui Posted June 16, 2025 Author Share Posted June 16, 2025 @WBRBloom - the obliterator is 2 points (not 3), so your vow is 42 points and I've recorded it as such. gaurdian31 and WBRBloom 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385991-call-to-arms-2025-chaos-stronghold/#findComment-6116694 Share on other sites More sharing options...
WBRBloom Posted June 17, 2025 Share Posted June 17, 2025 9 hours ago, Dr_Ruminahui said: @WBRBloom - the obliterator is 2 points (not 3), so your vow is 42 points and I've recorded it as such. Thank you @Dr_Ruminahui, amended! Dr_Ruminahui and gaurdian31 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385991-call-to-arms-2025-chaos-stronghold/#findComment-6116746 Share on other sites More sharing options...
gaurdian31 Posted June 17, 2025 Share Posted June 17, 2025 Alright, got my before picture added! Dr_Ruminahui 1 Back to top Link to comment https://bolterandchainsword.com/topic/385991-call-to-arms-2025-chaos-stronghold/#findComment-6116840 Share on other sites More sharing options...
gaurdian31 Posted June 17, 2025 Share Posted June 17, 2025 I also fixed my vow (I copied @Dr_Ruminahui) and changed it to Word Bearers (Heretic Astartes). My apologies for the confusion as I thought I had changed it when I added the characters I was vowing. Also sorry for the double post, I wanted to make sure it was seen. Link to comment https://bolterandchainsword.com/topic/385991-call-to-arms-2025-chaos-stronghold/#findComment-6116919 Share on other sites More sharing options...
Dr_Ruminahui Posted June 17, 2025 Author Share Posted June 17, 2025 4 hours ago, gaurdian31 said: I also fixed my vow (I copied @Dr_Ruminahui) and changed it to Word Bearers (Heretic Astartes). My apologies for the confusion as I thought I had changed it when I added the characters I was vowing. Also sorry for the double post, I wanted to make sure it was seen. Thanks for letting me know. Fixed on the participants page. gaurdian31 1 Back to top Link to comment https://bolterandchainsword.com/topic/385991-call-to-arms-2025-chaos-stronghold/#findComment-6116966 Share on other sites More sharing options...
sitnam Posted June 18, 2025 Share Posted June 18, 2025 So I scanned the rules and I couldn't find it, do we want to be posting our WIP posts/blog updates to these Stronghold threads? We did before in the past CtA's WBRBloom and gaurdian31 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385991-call-to-arms-2025-chaos-stronghold/#findComment-6117073 Share on other sites More sharing options...
