zulu.tango Posted July 26 Share Posted July 26 Vow completed. The wreckas are ready to smash their way across the stars! Grotsmasha, Antarius, Dr. Clock and 9 others 4 8 Back to top Link to comment https://bolterandchainsword.com/topic/385992-call-to-arms-2025-xenos-stronghold/page/4/#findComment-6124335 Share on other sites More sharing options...
Bouargh Posted July 26 Share Posted July 26 (edited) My second Xenos vow : to be merged with My first Drukhari pledge . - 5 Wraithguards and their Spiritseer – 5 + 5 points - 1 Converted Wayleaper Autarch – 5 points and Master of the Forge entry - 2 Warwalkers – 6 points - 5 Rangers and their token – 6 points - 5 Warspiders and their token – 6 points - 3 Shroudrunners – 6 points Grand total: 39 points Edited July 28 by Dr_Ruminahui Alby the Slayer, Firedrake Cordova, AvePicante and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/385992-call-to-arms-2025-xenos-stronghold/page/4/#findComment-6124383 Share on other sites More sharing options...
AvePicante Posted July 27 Share Posted July 27 And with that, my vow is complete. 8 Ironhead Squats, 1 Sagitaur, and an Einhyr Champion, based and ready! Thank the Votann I'm done and have no plans for a second pledge later this week, right? ...right? WBRBloom, Dr_Ruminahui, Dr. Clock and 9 others 7 1 4 Back to top Link to comment https://bolterandchainsword.com/topic/385992-call-to-arms-2025-xenos-stronghold/page/4/#findComment-6124517 Share on other sites More sharing options...
firestorm40k Posted July 27 Share Posted July 27 Update from me - a little behind where I wanted to be (haven't yet started the bases, which'll be time consuming adding Martian Ironcrust). For the Warriors and Scarabs it's just the bases to do, but I've got to do the Nobles' blades. Hoping to have these done by the 15th next month, as I'd like to squeeze in a second vow of Necrons before the event ends Dr_Ruminahui, Bouargh, Focslain and 8 others 10 1 Back to top Link to comment https://bolterandchainsword.com/topic/385992-call-to-arms-2025-xenos-stronghold/page/4/#findComment-6124602 Share on other sites More sharing options...
Silvereyes Posted July 27 Share Posted July 27 I, Silvereyes, heed the Call to Arms and pledge to paint 10 Kroot Carnivores for 10 points for the Glory of the T'au Empire and the Xenos Stronghold on or before 15th September 2025, or bear the badge of failure until year's end. Recommended this challenge in my introduction thread. I need a bit of a motivation kick to start painting my T'au backlog, and this seems like a good way of doing it. Good luck to everyone else participating. Spoiler firestorm40k, sitnam, zulu.tango and 4 others 6 1 Back to top Link to comment https://bolterandchainsword.com/topic/385992-call-to-arms-2025-xenos-stronghold/page/4/#findComment-6124662 Share on other sites More sharing options...
zulu.tango Posted July 28 Share Posted July 28 (edited) I, zulu.tango, heed the Call to Arms and pledge to paint 10 vespids and a control drone, totaling 11 points for the glory of the Tau Empire and the Greater Good on or before September 17th, or bear the badge of failure until year's end. Edited July 28 by zulu.tango Tallarn Commander, Dr. Clock, Firedrake Cordova and 4 others 7 Back to top Link to comment https://bolterandchainsword.com/topic/385992-call-to-arms-2025-xenos-stronghold/page/4/#findComment-6124751 Share on other sites More sharing options...
YoungWolf7 Posted July 28 Share Posted July 28 I, YoungWolf7, heed the Call to Arms and pledge to paint the following models for 38 points for the Glory of the Orks subfaction and the Xenos Stronghold on or before 15th September 2025, or bear the badge of failure until year's end. Vow #2: 1 Jawbreaka (Megatrakk Scrapjet proxy?) [5] ***Master of the Forge Entry*** 2 Ork Big Meks w/ Shokk Attack Guns [10] 2 Grot Assistants [2] 1 Ork Painboy [5] 1 Grot Orderly [1] 3 Weirdboys [15] [38 points total] Jawbreaka doesn't really fit into proxying any predefined Ork model. Closest thing would really be a Battlewagon/Gunwagon, but it's on the same size base as a buggy. Buggies are all 5 points, the Battlewagon is listed as 6. I'm not going to quibble over a single point. Spoiler Firedrake Cordova, Dr_Ruminahui, Dr. Clock and 3 others 5 1 Back to top Link to comment https://bolterandchainsword.com/topic/385992-call-to-arms-2025-xenos-stronghold/page/4/#findComment-6124806 Share on other sites More sharing options...
Dr_Ruminahui Posted July 28 Author Share Posted July 28 (edited) Reporting Page updated - please review to ensure your entry is correct (subfaction, link, models vowed, point value, entry into Master of the Forge). Wow, lots of completions this week in Xenos. Also good to see the revows. @Bouargh 1. Can you please put in your completion post photos of all the completed models, either together or separately? You'll want to include the best close up you have of your Master of the Forge entry. 2. You only get one Master of the Forge Entry per stronghold - do you want it to be your Archon or your Autarch? 3. Tokens are only .5 pnts each, so I have your vow down as 38 pnts rather than 39. @zulu.tango 1. You have to chose one subforum for all your vows, even if the models you are painting aren't for that subforum (its basically just the subforum you are representing for this event) - see my explanation here. So, your orks and tau need to be pledged to the same subforum. I currently have everything under orks, but let me know if you want to vow everything to Tau instead or a different subforum. 2. Is the vespid controller a "model" in game terms, or just a token that indicates some rule is in effect or available? @YoungWolf7 - 5 sounds fine for the jawbreaker, but if you want to share a picture of it next to a battlewagon I can consider if it should be 6 instead. For now, I have it as 5. Edited July 28 by Dr_Ruminahui YoungWolf7 and Grotsmasha 2 Back to top Link to comment https://bolterandchainsword.com/topic/385992-call-to-arms-2025-xenos-stronghold/page/4/#findComment-6124809 Share on other sites More sharing options...
YoungWolf7 Posted July 28 Share Posted July 28 (edited) 42 minutes ago, Dr_Ruminahui said: @YoungWolf7 - 5 sounds fine for the jawbreaker, but if you want to share a picture of it next to a battlewagon I can consider if it should be 6 instead. For now, I have it as 5. @Dr_Ruminahui The closest things I have to compare it to are a modified 6x6 Battlewagon and a Megatrakk proxy. Like I said, I'm not stressed about it. It is a lot of work for a 5 point model though. ;) Spoiler Edited July 28 by YoungWolf7 Dr_Ruminahui 1 Back to top Link to comment https://bolterandchainsword.com/topic/385992-call-to-arms-2025-xenos-stronghold/page/4/#findComment-6124820 Share on other sites More sharing options...
Dr_Ruminahui Posted July 28 Author Share Posted July 28 Thanks. Lets keep it at 5, then - it seems about smack dab between the two of them. YoungWolf7 1 Back to top Link to comment https://bolterandchainsword.com/topic/385992-call-to-arms-2025-xenos-stronghold/page/4/#findComment-6124823 Share on other sites More sharing options...
Bouargh Posted July 28 Share Posted July 28 1 hour ago, Dr_Ruminahui said: @Bouargh 1. Can you please put in your completion post photos of all the completed models, either together or separately? You'll want to include the best close up you have of your Master of the Forge entry. 2. You only get one Master of the Forge Entry per stronghold - do you want it to be your Archon or your Autarch? 3. Tokens are only .5 pnts each, so I have your vow down as 38 pnts rather than 39. 1. Just posted pics there: https://bolterandchainsword.com/topic/385867-event-call-to-arms-2025-drukhari/?do=findComment&comment=6124830 And reproduced here: Spoiler 2. I will in that case keep the Archon. 3. Noted. I missed that. Alby the Slayer and Dr_Ruminahui 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/385992-call-to-arms-2025-xenos-stronghold/page/4/#findComment-6124831 Share on other sites More sharing options...
Dr_Ruminahui Posted July 28 Author Share Posted July 28 (edited) Thanks, @Bouargh. By the end of the event, could you get a good picture of the MotF Archon on her own? That puts you in the base place to show it off for the voting. Your dark elves look great for a bunch of degenerate pointy ears (spoken as a collector and painter of degenerate round ears ). Edited July 28 by Dr_Ruminahui Bouargh 1 Back to top Link to comment https://bolterandchainsword.com/topic/385992-call-to-arms-2025-xenos-stronghold/page/4/#findComment-6124856 Share on other sites More sharing options...
AvePicante Posted August 2 Share Posted August 2 I, AvePicante, heed the Call to Arms and pledge to paint one Hekaton Land Fortress (6), two Ironhead Squat Scout Trikes (2ea) with included drones (?), one Ironhead Squats Vartijian Exo Driller (?), ten Tau Pathfinders (1ea) plus three drones (?), one Aeldari Farseer (5) one Parasite of Mortrex (5), and one Winged Hive Tyrant (10) for a minimum of 40 points, for the Glory of the Nix Mons Mining Company, the Leagues of Votann, and the Xenos Stronghold, on or before 15th September 2025, or bear the badge of failure until year's end. Our pioneering trips have been fruitful, and the Hernkyn of the Nyx Mons have returned with an impressive retinue, including captured forced of the Great Devourer, a Tau Pathfinder team all too trusting of what they call "Demiurge," and the surviving member of an Aeldari troupe who found their way into our space. Resources gained from this endeavor will fuel the birth of many future Kin. I would like to submit my Winged Hive Tyrant as my Job's a Big'un I am unsure of what cost to give the Driller as it does not have a Votann equivalent, it is bigger than an Einhyr Champion so can I get away with 5? I am happy to provide reference pics. I also believe I read drones only count for 0.5 points, is that accurate? If so, a total of 47.5 points. Firedrake Cordova, firestorm40k, Grotsmasha and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/385992-call-to-arms-2025-xenos-stronghold/page/4/#findComment-6125722 Share on other sites More sharing options...
Dr_Ruminahui Posted August 4 Author Share Posted August 4 @AvePicante, Job's a Big One vow is a seperate vow, so I've put the Hive Tyrant on his own at 10 points. As for the others, the Driller is 2 points (same size-ish as a chaos obliterator, which is 2 - he'd have to be dreadnaught size to be 3 (or a 40K character equivalent to be 5), and the drones, being tokens, are 1/2 pnt each, making your total for the rest of your vow 34.5. AvePicante 1 Back to top Link to comment https://bolterandchainsword.com/topic/385992-call-to-arms-2025-xenos-stronghold/page/4/#findComment-6125982 Share on other sites More sharing options...
Dr_Ruminahui Posted August 4 Author Share Posted August 4 Reporting Page updated - please review to ensure your entry is correct (subfaction, link, models vowed, point value, entry into Master of the Forge). AvePicante 1 Back to top Link to comment https://bolterandchainsword.com/topic/385992-call-to-arms-2025-xenos-stronghold/page/4/#findComment-6125984 Share on other sites More sharing options...
Dr_Ruminahui Posted August 4 Author Share Posted August 4 (edited) - STATE OF THE EVENT - WE ARE NOW 1/2 WAY DONE (as of August 1) Half way into the event, and its time for some more stats! Since the 2 week mark, we have 9 new participants (total of 69) and are up 25 vows (to 96), and have inceased our vowed points by 660.5 (to 3,752). We are also doubled our Master of the Forge entries (to 10) and still have no Young Bloods. If you think I have missed anything or anyone, please let me know here or by message. Leading stronghold in vowed points is still heresy at 1270 (which is up 103 pnts). They also still have to 2 highest strongest subfactions in terms of vowed points - For the Emperor at 709 (up 93) and For the Warmaster at 582 (up 10). Although its still anybody's game (such that it isn't particularly meaningful at this point), the Imperium still has the highest completion rate of 32.06% of pledged points completed, though Xenos is close on its heels at 31.56%. The other 3 are far behind at 15.83% (Astartes), 7.01% (Chaos) and Heresy in the rear with 4.96%). In terms of raw points of completed vows (rather than %), Xenos is in the lead with 287, followed by Astartes at 103 and the rest still in the double digit - 67 for Imperium, 63 for Heresy and Chaos at the tail with 50. Deathwatch in the Imperium forum is still the only subforum with a 100% completion rate. @Antarius still has the most completed points, having completed 3 vows in two strongholds worth 174 pnts (up 61 points and 1 vow from the 2 week point). In terms of vote diverstity, however, @Dr. Clock is in the lead, with vows in 4 of the 5 Strongholds - the next closest are the 10 members with vows in 2 strongholds. Highest total vows is still @SgtSharp, with his massive vow of 419 for the Emperor in the Heresy forum, followed by, in the same stronghold, by 365 for the Warmaster from @GodEmperorOfMankind. All the subfactions have persons vowing their models to them, except Genestealer Cultists, Adepta Sorroritas, Adeptus Mechanicus and Imperial Knights. Is great to see all the fantastic models being painted, and I look forward to seeing what all comes out by my next update a month from now! Edited August 4 by Dr_Ruminahui Alby the Slayer, firestorm40k, AvePicante and 2 others 2 3 Back to top Link to comment https://bolterandchainsword.com/topic/385992-call-to-arms-2025-xenos-stronghold/page/4/#findComment-6125992 Share on other sites More sharing options...
zulu.tango Posted August 4 Share Posted August 4 On 7/28/2025 at 12:21 PM, Dr_Ruminahui said: @zulu.tango 1. You have to chose one subforum for all your vows, even if the models you are painting aren't for that subforum (its basically just the subforum you are representing for this event) - see my explanation here. So, your orks and tau need to be pledged to the same subforum. I currently have everything under orks, but let me know if you want to vow everything to Tau instead or a different subforum. 2. Is the vespid controller a "model" in game terms, or just a token that indicates some rule is in effect or available? @Dr_Ruminahui - Everything under orks is fine, and the control drone is a physical model, bottom right of my vow picture Link to comment https://bolterandchainsword.com/topic/385992-call-to-arms-2025-xenos-stronghold/page/4/#findComment-6126078 Share on other sites More sharing options...
Dr_Ruminahui Posted August 4 Author Share Posted August 4 (edited) @zulu.tango - just looked vespid up in the 40K rules, and the drone, while model, doesn't have its own profile and just denotes a piece of wargear. As such, its a "token" and is 1/2 a point - so I've marked you down for 10.5. Thanks for the subfaction confirmation. Edited August 4 by Dr_Ruminahui Link to comment https://bolterandchainsword.com/topic/385992-call-to-arms-2025-xenos-stronghold/page/4/#findComment-6126081 Share on other sites More sharing options...
firestorm40k Posted August 8 Share Posted August 8 Vow complete! Well, first one anyway Calling these done, as I want to get started on a 2nd vow 30 Warriors, 12 Scarabs, 2 Lords and 1 Royal Warden done Rusted Boltgun, Dr. Clock, Alby the Slayer and 4 others 5 2 Back to top Link to comment https://bolterandchainsword.com/topic/385992-call-to-arms-2025-xenos-stronghold/page/4/#findComment-6126866 Share on other sites More sharing options...
firestorm40k Posted August 8 Share Posted August 8 ...and (excuse the double post ) here is my second vow: I, Firestorm40k, heed the Call to Arms and pledge to paint the following: 10 x Immortals 5 x Deathmarks 3 x Wraiths 2 x Heavy Destroyers for 27 points, for the Glory of High Phaeron Nepharekh's Celestial Hegemon and the Xenos Stronghold, on or before 15th September 2025, or bear the badge of failure until year's end. As with my first vow, these have been primed black then sprayed with Leadbelcher. Time to get dry-brushing..! Rusted Boltgun, AvePicante, sitnam and 4 others 7 Back to top Link to comment https://bolterandchainsword.com/topic/385992-call-to-arms-2025-xenos-stronghold/page/4/#findComment-6126870 Share on other sites More sharing options...
Dr_Ruminahui Posted August 13 Author Share Posted August 13 Reporting Page updated - please review to ensure your entry is correct (subfaction, link, models vowed, point value, entry into Master of the Forge). AvePicante and firestorm40k 2 Back to top Link to comment https://bolterandchainsword.com/topic/385992-call-to-arms-2025-xenos-stronghold/page/4/#findComment-6127652 Share on other sites More sharing options...
Bouargh Posted August 15 Share Posted August 15 (edited) My second vow in the Xenos FOrum is now complete: I will have to give asecond round of photo shots for the Master of the FOrge entry I included in the first vow, but I think I am done for this year. Except change of mind... Once agian a great emulation and a good summer painting rate thanks to CtA! Edited August 15 by Dr_Ruminahui Added photo Grotsmasha, Dr. Clock and Dr_Ruminahui 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/385992-call-to-arms-2025-xenos-stronghold/page/4/#findComment-6128057 Share on other sites More sharing options...
Kora'tau Posted August 15 Share Posted August 15 This post was recognized by Dr_Ruminahui! "Congratulations on completing your vows for the Xenos Stronghold during Call to Arms 2025" Kora'tau was awarded the badge 'Call to Arms 2025 Xenos' and 1 points. Vow Completed. I have finished the 10 lootas, a warboss, a mek, and 2 bomb squigs. Took me longer than i was anticipating but life got in the way more than expected. Sadly I wont be making any other vows, due to time. The last pic is showing my now 2 meks side by side, just so no one thinks i just reused my first mek. Did a nice head swap on the second mek. Grotsmasha, Bouargh, Khulu and 5 others 4 4 Back to top Link to comment https://bolterandchainsword.com/topic/385992-call-to-arms-2025-xenos-stronghold/page/4/#findComment-6128168 Share on other sites More sharing options...
Alby the Slayer Posted August 18 Share Posted August 18 (edited) This post was recognized by Dr_Ruminahui! "Congratulations on completing your vows for the Xenos Stronghold during Call to Arms 2025" Alby the Slayer was awarded the badge 'Call to Arms 2025 Xenos' and 1 points. Vow completed! Krist'hel, Archon of the Kabal of the Last Hatred and her retinue in the Tantalus is ready to skin some unfortunate preys and use their soul for some unmentoniable act! It was a fun project, I love the Drukhari and this event was a great motivator to create this project which was in my mind for quite some time now. Next time I will try to make more points for the stronghold. Additional pictures (private parts of the slaves are pixaleted): Spoiler Edited August 29 by Alby the Slayer Dr. Clock, Bouargh, Dr_Ruminahui and 7 others 4 6 Back to top Link to comment https://bolterandchainsword.com/topic/385992-call-to-arms-2025-xenos-stronghold/page/4/#findComment-6128462 Share on other sites More sharing options...
Dr_Ruminahui Posted August 19 Author Share Posted August 19 Reporting Page updated - please review to ensure your entry is correct (subfaction, link, models vowed, point value, entry into Master of the Forge). Link to comment https://bolterandchainsword.com/topic/385992-call-to-arms-2025-xenos-stronghold/page/4/#findComment-6128750 Share on other sites More sharing options...
