The Call to Arms 2025
HERESY STRONGHOLD
Time to bust out those brushes and paints and stand ready to represent your Forum/s of choice and aid them on the path to claim Victory!!!!
What is The Call to Arms, I hear you ask?
The Call to Arms is a multi-forum event designed to  encourage us all to start a new army, or bolster our current forces.
The Forums of the B&C are divided up into five Strongholds;
The Astartes Stronghold
The Imperium Stronghold
The Chaos Stronghold
The Xenos Stronghold
The Heresy Stronghold
These five Strongholds will act as the hub for each of the five main Factions, and will for the 3 Month duration of the Call to Arms, run independently of the four other Strongholds. Each Stronghold may have different targets and goals, and even their own mini/complementary events, all with unique badges and achievements, but at the end of the 3 months, the five Strongholds will face off, and overall winners will be declared.
Dates
Start Date: 15th JUNE 2025
End Date: 15th SEPTEMBER 2025
(Timezone will be GMT -8 [so, North American Pacific Coast time], please make local adjustments for time)
So, how is it all going to work?
1.   As each of the Strongholds are acting (initially) as their own Events, you may choose to focus within a single Stronghold, or participate in all five Strongholds, and any complementary/mini-events that you would like to. Your Vows will be treated independently in each Stronghold, meaning a Failed Vow in one Stronghold will NOT effect Vows in the other Strongholds.
2.  Models pledged to a Stronghold must come from the army books associated with those Forums covered by each Stronghold. The exceptions to this are Titans and models not associated with a given faction (such as Necromunda models and terrain), these models / units may be pledged to any Stronghold.
3.  You may join in any of the Events at any time within the 3 Month time-frame of The Call to Arms
4.  For each Stronghold, you have a MAXIMUM of 3 Vows, you must finish your active vow before pledging to a second or third vow.
5.  In addition to the three Vows, any model in the 10pt Category or higher will fit into the "Job's a Big'un" Vow, and will run separate from the 3 Vow limit and have the entirety of the 3 months to be completed.
6.  Once recorded, Vows may not be altered, however special considerations may be made upon request.
7.  There is no minimum pledge, you may vow 1 model, or your entire collection, but beware, failing your last active vow will invalidate any completed vows you may have already submitted.
How do I join in?
Each model has a point value based upon its size, and the comparative amount of effort and time it takes to paint said model, listed below are are the points-per-model, more specific lists can be found in each Forums Rally Point thread, but I've added some generic examples below,
1pt   Infantry
2pts   Cavalry/Bikers
3pts   Heavy Weapons Teams / Walkers (Dreadnaughts, Sentinels)
4pts   Skimmers / Light Vehicles (Landspeeders, ATV, Armigers)
5pts   Small Tanks (Leman Russ, Rhino Variants)
6pts   Large Tanks (Rogal Dorn, Sicaran, Land Raider)
8pts   Superheavies (Baneblades etc)
10pts  Imperial Knight etc
Characters
5pts   Leader/Character models
10pts Primarchs
Note: Characters with Retinue, I.E. Saint Celestine.  The Leader model is worth 5pts, the other models are pointed as to their type - for example, Saint Celestine and her bodyguard would be 7 points - 5 for the Saint (leader), 1 each for her 2 seraphim buddies.
40K Scale Titans
20pts Warhound Titan
30pts Reaver Titan
40pts  Warbringer Titan
50pts Warlord Titan
Terrain
1pt    3 Munitorum Barrels, 4 Munitorum Crates, Zone Mortalis/Gallowdark Column, Octarius Ramshackle Bridges
2pts   Aegis Defence Line Section, Aegis Defence Platform, Galvanic Servo-haulers, Thermic Plasma Conduit Section, Imperialis Ruins Wall Section, Zone Mortalis/Gallowdark Wall, Octarius Scrap Heap/Barricade
3pts   Fronteris Vox Antenna, Fronteris Auspex Shrine, Thermo-exchanger Shrine, Octarius Oil Rig, Necromunda Fuel Tanks
4pts   Munitorum Container, Mechanicus Transterranic Gantry, Galvanic Servo-crane, Big'ead Bossbunka, Skull Alter, Noctilith Crown, Octarius Ramshackle Walls
5pts   Tidewall Droneport, Tidewall Shieldline, Feculant Gnarlmaw, Miasmic Malignifier
6pts   Fronteris Landing Pad, Mechanicus Forgeshrine, Mechanicus Galvanic Magnavent
8pts   Fronteris Hab Bunker, Manufactorum Administratus,
10pts Zone Mortalis Gang Stronghold
Note: Custom/Scratchbuilt terrain- use this list as a guide as to how many points tour terrain is worth, but please make sure to mention your terrain is custom when Vowing.
You may vow ANY MODEL that is covered by THIS STRONGHOLD, but you must allocate your points to only one SUBFACTION.  These Subfactions are the ones listed under the various Strongholds above, and are the various B&C forums/subforums, with 2 exceptions:
   a) Deathwatch is a valid Subfaction for both the Astartes and Imperium Strongholds, despite not having a dedicated forum/subforum; and
   b) in the HERESY STRONGHOLD, the Subfactions are "Emperor" and "Warmaster", not the 2 B&C forums listed above.
NOTE: Your chosen Subfaction doesn't have to correspond to your vowed models, although it typically does.
Please make your vows in this thread in the following format;
"I, {insert username}, heed the Call to Arms and pledge to paint {insert units/models} for {xxx pts} for the Glory of the {Subfaction name} and the {Stronghold name} Stronghold on or before 15th September 2025, or bear the badge of failure until year's end."
For example:
"I, Dr Ruminahui, heed the Call to Arms and pledge to paint 6 legionaires, a praetor, a rhino and a Necromunda Fuel Tanks for 19 pts for the Glory of the Warmaster and the Heresy Stronghold on or before September 15th, or bear the badge of failure until year's end."
The post that contains your Vow must include starting pictures that contain all the models from the Vow.
Starting models may be in any of the following conditions;
  • In the box
  • On the Sprue
  • Assembled
  • Single Colour Primed
  • Sub-assemblies primed in different colours will be acceptable, I.E. chassis in Leadbelcher, with armour plates in secondary colour.
Additionally, you may pledge models you have not yet received I.E. Warhammer: Imperium Subscription, just make sure a image is edited in to your Vow post once you've received the models, and make a post indicating that you have done so.
Your Vow is considered complete when you declare it so, and post completed pictures of all models contained within the Vow. Although "Complete" is to your own standard, we would like you to aim for GW's "Battle Ready", with the miniatures based. If basing is something you don't do, or won't be doing within the Event's timeline, please return the bases to flat black or brown as this will greatly enhance the Completed presentation.
Required Completion Pictures: Please include 1 image with a complete shot of the entire Vow, I also encourage everyone to include additional images for each squad/unit in the vow,.
Once you have made your vow, pop this badge of Participation into your Signature,
Will there be any awards?
Yes!!  There will be Badges and Achievements within the Astartes Stronghold.  Note, all badges/ranks/achievements are a different thing and entirely separate from the ranks and achievements tracked by the forum software.
Event Failed: Servitor
10 points:  Legionaire
25 points  Sergeant
45 points:  Consul
75 points:   Praetor
100+ points:  Master of the Legion
Artificer - Top 1, 2, or 3 best painted models from each Forum, chosen by the forum Moderators, Administrators and Librarians.
Princeps - Awarded to all completed 40K scale Titans
Heresy Champion - Awarded to the Frater who individually paints the most points worth of models in the Heresy Stronghold
Champions of the Horde - The Subfaction for each Stronghold with the highest overall points worth of models
Champion of the Call - The Subfaction for each Stronghold that has the Highest Participation vs. Completion Percentage.
As to the overall competition between the Strongholds, there will also be Badges awarded for the following;
Masters of the Horde - The Stronghold that completes the highest overall points worth of models.
Masters of the Call - The Stronghold that has the Highest Participation vs. Completion Percentage.
Master Artificer - Voted best painted Model, chosen from the 5 Stronghold Artificers.
In addition to the Badges and Achievements above, there will be additional Awards for the following 4 categories. At this stage there are no physical prizes like last year, but that *MAY* change by the end of the Event.
Favourite Young Blood - This category is for Participants who have been building and/or painting models for less than 12 months. Anyone wishing to participate as A Young Blood will need to specifically declare that are are doing so when making their Vows. At the conclusion of the Event all Young Blood Entries will be placed into a Poll for the B&C at large to vote on and pick a Favourite. The voting criteria for this category is not about picking the best painted model, but the model that inexplicably pulls a smile on your face, one that makes you think, damn that's cool..
Master of the Forge - Best Conversion or Kit-bash. Anyone wishing to participate for the Master of the Forge Badge and Prize will need to specifically declare that they are doing so when they vow the model.
Stronghold Artificer - Awarded to five Participants, one from each Stronghold for the Best Painted Model in from the Stronghold, chosen by the Frater via Poll.
Grand Marshal - Individual with the Most Points of Models Painted across all Strongholds
That's it, you've done it, you've made it to the end!!!
If you have any questions or queries, contact me,  @Dr_Ruminahui and I'll be more than happy to help you out.
F.A.Q.s
Q- If I have models with different coloured heads or shoulder pads, can they be primed different colours IE. Black templars or Eldar Guardians?
A- Yes, this is acceptable.
Q- I want to paint Traitor Guard, is there a way to pledge them to Chaos?
A- Yes, for the purposes of Traitor Guard, the Astra Militarum units may be pledged to Chaos. The Realm of Chaos is the most appropriate forum.
Q- Are 3D prints allowed?
A- Yes, as long as they are board appropriate, 3D prints can be pledged to the Call to Arms. Use the points associated with the unit they represent.
THIS THREAD WILL REMAIN LOCKED UNTIL JUNE 15, 2025, AT WHICH TIME VOWS MAY COMMENCE
Edited by Dr_Ruminahui
PARTICIPANTS
TOTAL STRONGHOLD RESULTS - Pledged: 1413 pnts / Completed: 837 pnts / Secured: 837 pnts / 59.24% Completed - 18 Participants, 12 (66.67%) completed all Heresy vows
The Emperor - Pledged: 778 pnts / Completed: 588 pnts / Secured: 588 pnts / 75.58% Completed
Participants (13 Total, 8 Secured - 61.54%):
Blissful Brushes - Vow 1: 1 pnt - Complete
1x tactical marine
Deux Ex Machina - Vow 1: 25 pnts - Complete; Vow 2: 30 points - Complete 1, 2, 3
 10x rotor cannon gunners
1x praevian
2x apothecaries
3x rhinos
1x praetor
1x moritat
1x librarian
Iron Father Ferrum - Vow 1: 15 pnts - Incomplete
10x Immortals
1x Cataphractii Praetor
librisrouge - Vow 1: 16 pnts - Complete
13x custodians
1x dreadnought
lokkorex - Vow 1: 32 pnts - Incomplete
8x Armiger Moirax
Mandragola - Vow 1: 27 pnts - Complete 1, 2
30K
1x Saturnine Dreadnaught
LI
4x Leviathans
8x [Redacted]
4x [Redacted]
1x [Redacted]
richmarine - Vow 1: 62 pnts - Complete 1, 2, 3
10x Assault Marines
5x Lascannon Marines
5x Mor Deythan
10x Dark Fury's
9x Despoilers
5x Tactical Marines
1x Iron Father
1x Contemptor (3)
10x Despoilers
SgtSharp - Vow 1: 410 pnts - Complete 1, 2
28mm
128 Valhallans with lasguns (128 pts)
5 Valhallans with meltaguns (5 pts)
6 Valhallans with grenade launchers (6 pts)
2 valhallans with plasma guns (2pts)
2 valhallans with nucio-vox (2pts)
13 pistol + chainsword Sgt valhallans (13pts)
2 Valhallans with hand flamer + powersword (2pts)
11 heavy weapon teams (33 pts)
2 force commanders (1 col. Chenkov, 1 hand flamer/chainsword officer) (10 pts)
2 Malcador tanks (12 pts)
1 dracosan (6 pts)
1 Valdor (6pts)
2 Russes (10pts)
1 carnadon (5 pts)
Aurox (5 pts)
3 rapier teams (9 pnts)
9 velataris Light Sentinels (18 pts)
Kratos (6 pts)
Sol aux legate Marshal (5 pts)
7 man Tactical command squad (7 points)
surgion primus aven jovas (or what ever his name actually is ) (5 points@)
auto gourney (1pt)
5 medical ordalies/ medics (5 pts)
36 lasrifles (36 points)
3 misc. velataris vanguard section models (3 points)
1 cerastas knight castigator (10 pts)
1 cerastas knight Acheron (10 pts)
(360 pts sub total)
epic scale:
12 Dracosans (24 pts)
2 medusa (2 pts)
1 hellhammer (3 pts)
1 pyphorion (3 pts)
2 Lancers (4 pts)
4 sicarans (8 pts)
6 pedator tanks (6 points)
(50 pts sub total)
Shard of Magnus - Vow 1: 54 pnts - Incomplete
20x tactical legionaries
1x centurion
1x rhino
2x sicarans
6x sky-hunter jetbikes
Sven Ironhand - Vow 1: 3 pnts - Complete
3x Indomitus Terminators
time_of_flight - Vow 1: 3 pnts - Complete; Vow 2: 11 pnts - Complete
3x Saturnine Terminators
1x Landraider Spartan
1x Siege Breaker
Trokair - Vow 1: 24 pnts - Incomplete
24x Epic scale Leman Russ battle tanks
W.A.Rorie - Vow 1: 65 pnts - Incomplete
30x Assault Marines
10x Dark Furies,
10x Destroyers
1x Chaplain
1x Mortiat
1x Legion Champion
The Warmaster - Pledged: 635 pnts / Completed: 249 pnts / Secured: 249 pnts / 39.21% Completed
Participants (5 Total, 3 Secured - 60.00%):
Cryptix - Vow 1: 43 pnts - Complete
1x Archmagos Myrmidax
12x Myrmidons
6x Blood Slaughterers
2x Thanatars
Dwango - Job's a Big One: 10 pnts - Complete; Vow 1: 99 pnts with MotF entry- Complete; Vow 2: 15 pnts - Complete; Vow 3: 28 pnts - Complete
1x Display board
2x Craters
2x Ruins
9x Tracks
1x Praetor
1x Tech marine [MotF]
3x Apothecary
2x Deredeo dreadnoughts
49x Marines
1x Captain Tarvitz
1x Captain Lucius
1x EC Praetor
6x craters
4x large rock pillars
GodEmperorOfMankind - Vow 1: 365 pnts - Incomplete
40x Medusan Immortals (40)
20x recon marines with Bolters (20)
20x Tactical Marines (20)
10x Dominator terminators (10)
10x Cataphractii Terminators (10)
10x Justaerin Terminators (10)
2x Landspeeder Javelins (6)
15x Dreadnoughts (Mix of contemptors, Deredeos, leviathans and castaferrum) (45)
10x Rhinos (50)
10x Drop pods (50)
3x Spartans (18)
5x Land raiders (30)
3x Sicarans (18)
3x Kratos (18)
2x large Terrain pieces (20)
Lautrec the Embraced - Vow 1: 34 pnts - Complete; Vow 2: 10 pnts - Complete; Job's a Big One: 10 pnts - Complete
3x Captains
9x Veterans
10x Indomitus Terminators
10x Assault Marines
10x Tactical Marines
Lord Marshal - Vow 1: 21 pnts - Incomplete
10x Tactical marines
1x Rhino
1x Kratos
  • 2 weeks later...
First on the walls of Terra! Ave dominus Nox!
I, Lautrec the Embraced, heed the Call to Arms and pledge to paint:
- 3 Captains,  kitbashed: 2 named Praetors (Kheron Ophion, 'the Coward' & Nakrid Thole) +1 Jump Captain w/ hammer
- 9 Veterans
- 10 Indomitus Terminators
for 34pts for the Glory of the Warmaster and the Heresy Stronghold on or before 15th September 2025, or bear the badge of failure until year's end.
Spoiler
This one's a bit top-heavy, and rather later heresy/scouring theme, I'm saving some Mk3-4 for potential second, early-heresy vow:
20250615_105642.thumb.jpg.887cba5463b972e1ee4142b5162b59f8.jpg20250615_105913.thumb.jpg.c11b20f64152d6b725c2b1b4278baa32.jpg20250615_110111.thumb.jpg.fc85a255a7f2d89cccf461d565d2e320.jpg
(obviously terminators are not yet primed, I've bought them as crimson fists, didn't bother to remove the paint and started converting...)
But Lautrec, you say, aren't these 40k storm bolters? (...i'm sorry)
*well, actually, these are totally *not* storm bolters but rather the elusive Nostramo-Caedes Pattern Storm Combi-Bolters...
Edited by Lautrec the Embraced
I, Dwango, heed the Call to Arms and pledge to paint:
Craters (2pts each) x2
Ruins (3pts each) x2
Tracks (1pts each) x9
Praetor x1
Tech marine x1
Apothecary X3
Deredeo dreadnought x2
Marines x49
One Istvaan 3 display board (jobs a big un)
for 109pts for the Glory of the Warmaster and the Heresy Stronghold on or before 15th September 2025, or bear the badge of failure until year's end.
I, Sgtsharp, shall once again, heed the call to arms and pledge to paint
28mm
1 dracosan (6 pts)
1 Valdor (6pts)
2 Russes (10pts)
1 carnadon (5 pts)
Aurox (5 pts)
3 rapier teams (9 points?)
Kratos (6 pts)
auto gourney (1pt)
(360 pts sub total)
epic scale:
2 madusa (2 pts)
1 pyphorion (3 pts)
2 Lancers (4 pts)
4 sicarans (8 pts)
(50 pts sub total)
for 410 points for the Emperor and the Heresy stronghold on or before the 15th of september or bear the badge of failure until the end of the year.
20250615_102904.thumb.jpg.9376efa0ca1bed252e6cd3aad82f78e8.jpg20250615_102907.thumb.jpg.0d3e8cc6465dccd26abc8345cd45ff12.jpg20250615_110734.thumb.jpg.db64d548a29d3bfc69ceeb957a3f612f.jpg20250615_110834.thumb.jpg.299776a36b1afb8917eec6ec4c43403b.jpg20250615_111003.thumb.jpg.88919c5ea9c05887b35bf3de1b9256af.jpg20250615_111649.thumb.jpg.0c0b52e636833cf39227c68e3ad73c96.jpg20250615_113046.thumb.jpg.4f9e4af519c6120023f91c35edb803e2.jpg20250615_113415.thumb.jpg.b0f19a7c11ed2ea685d0d6571dea1062.jpg20250615_120711.thumb.jpg.11e34f5063d018c7ab754de94471365b.jpg
Edited by SgtSharp
adding images
  • Like 7
  • Love 1
  • Support 5
"I, Trokair, heed the Call to Arms and pledge to paint 24 Solar Auxilia Leman Russ for 24 pts for the Glory of the Emperor and the Epic Scaled Heresy Stronghold on or before 15th September 2025, or bear the badge of failure until year's end."
16 of the Ruses are built ( 4 each of Normal, Vanquisher, Exterminator and Annihilator), 8 are still on sprue (4 Demolisher and 4 Executioner).
In the background are all the other unbuilt Sola Auxilia stuff I have that might get to for a later vow. The 4 horizontal sprues are the Solar Auxillia ones form the big starter set, the 2 vertical are Baneblades, and still in boxses are some more super heavies, some support stuff and some Arvuses.
large.CalltoArms2025Start.png.70f0ba604e
@SgtSharp, what's your hobby intent with the Valhallans?  Are they intended to be part of your Imperial Army force (and painted as such), or do you intend to field them in 40K?  If the latter, you should vow them seperately in the Imperial forum.
I, LokkoRex, heed the Call to Arms and pledge to paint 8 Armiger Moirax for 32 points for the Glory of the Emperor and the Heresy Stronghold on or before 15th September 2025, or bear the badge of failure until year's end.
Note: One box of War Dogs is on the way through the mail, will edit in a picture once it's arrived! The Moirax upgrade parts for them are in the picture though!
EDIT: As promised, here's a pic of the freshy picked up second box of War Dogs!
Edited by lokkorex
Added picture of missing parts for earlier made Vow.
I, Shard of Magnus, head the Call to Arms and pledge to paint 20 tactical legionaries, 1 centurion, 1 rhino, 2 sicarans, and 6 sky-hunter jetbikes for 54 pts for the Glory of the Emperor, the Khagan, and the Heresy Stronghold on or before 17th September 2025, or bear the badge of failure until the end of the year.
Spoiler
large.IMG_3547.jpeg.386ac5d519feaea7939a
I had intended to get much more than this assembled and primed before the event started but life said no. This lot will give a benchmark on the time I need to finish painting different types and what to do with the rest of my pledges.
@Dwango, do you want the display board to be a seperate "Job's a Big One Vow" or part of your 109 point vow?  Vowing it seperately as a "Job's a Big One" means you don't need to finish the display board before you start on another vow, but it does mean you can't later vow something else later as a JaBO.  Anyway, I've lumped them together for now - let me know if that is wrong.
@SgtSharp - got it, I've included them in your insane 30K vow.
I, Cryptix, heed the Call to Arms and pledge to paint 1 Archmagos Myrmidax, 12 Myrmidons, 6 Blood Slaughterers, and 2 Thanatars for 43 points for the Glory of the Warmaster and the Heresy Stronghold on or before 15th September 2025, or bear the badge of failure until year's end.
Counting the thanatars as being in the 4 pt category rather than 3 pts since they're Armiger sized, let me know if that's wrong and I'll correct.
Damn @SgtSharp that's one hell of a vow!
As Emperor I'm going to have to lend my support to the loyalists. I shall marshal my forces and post tonight once I decide what to vow. I'll have to make a suitably large contribution I feel
@Dr_Ruminahui how much is this terrain worth? Knight for scale
Edited by GodEmperorOfMankind
Add pics
They don't seem super detailed, so how about 10 points each?  Message me and we can debate it further.
10 points a terrain piece seems reasonable, large but like you say, not super detailed. Equating each to a 10man squad seems about right. Cheers
I, The @GodEmperorOfMankind, heed the Call to Arms and pledge to paint:
40 Medusan Immortals (40)
20 recon marines with Bolters (20)
20 Tactical Marines (20)
10 Dominator terminators (10)
10 Cataphractii Terminators (10)
10 Justaerin Terminators (10)
2 Landspeeder Javelins (6)
15 Dreadnoughts (Mix of contemptors, Deredeos, leviathans and castaferrum) (45)
10 Rhinos (50)
10 Drop pods (50)
3 Spartans (18)
5 Land raiders (30)
3 Sicarans (18)
3 Kratos (18)
2 large Terrain pieces (20)
for a total of  365 pts
For the Glory of the Warmaster and the Heresy Stronghold on or before September 15th, or bear the badge of failure until year's end
Spoiler
Pictures will be inserted as I pull out of storage/build/buy/print these models
x20 Immortals:
x10 Dominators:
x20 recons with bolters:
x15 Dreadnoughts, x7 rhinos:
x10 drop pods:
x3 Kratos, x2 Sicarans , x1 Spartan, x1 Landraider:
x2 Javelins:
x2 large buildings:
not quite as bold as @SgtSharp,  but assuming I get through all of that, I can always make another pledge! Can't let him think he's gonna walk away Heresy Champion for a 2nd year without a fight
added starting pics
  • Like 6
  • Love 1
  • Support 2
Alright, let's see if I can actually complete a vow this year.
 I, Lord Marshal, heed the Call to Arms and pledge to paint:
  • x10 Tactical Marines
  • x1 Rhino
  • x1 Kratos
...for 21 pts for the Glory of the Warmaster and the Heresy Stronghold on or before 15th September 2025, or bear the badge of failure until year's end.
Spoiler
Edited by Lord Marshal
I, librisrouge, head the Call to Arms and pledge to paint 13 custodians and 1 dreadnought for 16 pts for the Glory of the Emperor, the Imperium of Mankind, Heresy Stronghold, and in defiance of the Warmaster on or before 15th September 2025, or bear the badge of failure until the end of the year.
Edited by librisrouge
@GodEmperorOfMankind, something kind of humourous about the God Emperor making his vow for the Warmaster. :laugh:  And yes, if you complete your first vow you can make another - in fact, each member can make 3 "normal vows" plus one "Job's  Big One" vow which is for a larger model (10+ pnts) that you can paint alongside your other vows (and is the only way to be working on two vows at once in the same stronghold).
You can do that in every stronghold, so in theory you could have 20 vows over the course of CtA, though that seems a bit... ambitious... especially given the scale of your starting vow. :biggrin:
@librisrouge, I'm not sure how you get 54 points - my total is 13x1 pnts for the custodes (13) and 1x3 pnts for the dread (3) for a total of 16.
I got it by not doing the math at all. I copied the pledge of another poster, edited it, and forgot to change the points.
:facepalm:
Register a new account
Sign in
