kabaakaba Posted June 4 Share Posted June 4 Today I read that current primaris psyker and tech-priest should be on 32mm. How it's restricted? If my on 25-28 mm bases for example. I use one what I have cause both are old metal minis I get without bases. Link to comment https://bolterandchainsword.com/topic/386059-model-base-restrictions/ Share on other sites More sharing options...
Dr_Ruminahui Posted June 4 Share Posted June 4 Depends where you are playing. With your mates, what they allow. At a tourney, ask the tournament organizer. GW used to have a rule of thumb that you could field any mini on the base it came with from GW, allowing you to field models on their original base sizes when the bases have changed over the years (for example, ork boyz have changed from 25mm to 32mm, I think). I'm not sure whether the new base size direction from GW is meant to change that or not. Link to comment https://bolterandchainsword.com/topic/386059-model-base-restrictions/#findComment-6114233 Share on other sites More sharing options...
kabaakaba Posted June 4 Author Share Posted June 4 (edited) There is circus with IG bases size. Cause cadian command squad on 28.5, scions com squad on 25 and krieg 28 to 32. and then castellan on 28 but psyker on 32. Idiocy. IDK if I gonna play at all, just trying wanna understand how it should be. Edited June 4 by kabaakaba Link to comment https://bolterandchainsword.com/topic/386059-model-base-restrictions/#findComment-6114242 Share on other sites More sharing options...
Solution Dr_Ruminahui Posted June 4 Solution Share Posted June 4 (edited) Well, if there is variance between models, then you need to find the specific model and determine which base it currently sold with and intended to go on. And use that. If its an older model, you can probably put it on a base it was previously sold to go on, but you are probably safer putting it on the current base, especially if you bought the model without a base. Edited June 4 by Dr_Ruminahui kabaakaba 1 Back to top Link to comment https://bolterandchainsword.com/topic/386059-model-base-restrictions/#findComment-6114254 Share on other sites More sharing options...
DemonGSides Posted June 5 Share Posted June 5 Now that GW has a tournament companion for base sizes, I'd just default to that at any question. If you've got a mini on an old base, no one's really gonna care. If they're within a size difference then there's really not much concern. If you're planning on playing organized competitive play, lean towards what the GW doc says. Otherwise it's not that big of a deal. Dr_Ruminahui and kabaakaba 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/386059-model-base-restrictions/#findComment-6114351 Share on other sites More sharing options...
Dr_Ruminahui Posted June 5 Share Posted June 5 The document to which DemonGSides refers is this one - Astra Millitarum is on pages 20-21. kabaakaba 1 Back to top Link to comment https://bolterandchainsword.com/topic/386059-model-base-restrictions/#findComment-6114421 Share on other sites More sharing options...
kabaakaba Posted June 5 Author Share Posted June 5 2 minutes ago, Dr_Ruminahui said: The document to which DemonGSides refers is this one - Astra Millitarum is on pages 20-21. Yeap, this doc is why I raged with all this different base sizes. Link to comment https://bolterandchainsword.com/topic/386059-model-base-restrictions/#findComment-6114422 Share on other sites More sharing options...
Dr_Ruminahui Posted June 5 Share Posted June 5 That's fair. That said, outside of tournament play, I don't think you need to be too worried about matching your models to that document, but it is a useful resource for getting bases on models that don't have them or if you are considering rebasing your existing models. kabaakaba and DemonGSides 2 Back to top Link to comment https://bolterandchainsword.com/topic/386059-model-base-restrictions/#findComment-6114430 Share on other sites More sharing options...
Lord_Ikka Posted June 6 Share Posted June 6 As a TO, the most important base size issue is related to Auras and melee. Larger base sizes mean larger auras, so any model with an aura should be on the appropriate sized base. For melee, larger base sizes mean that less models can get into combat. I always lean towards making sure models are on current production base size or smaller, especially if the model is from an older production run that had smaller sizes (such as certain SM characters on 32mm rather than 40mm bases). kabaakaba and Dr_Ruminahui 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/386059-model-base-restrictions/#findComment-6114477 Share on other sites More sharing options...
Dr_Ruminahui Posted June 6 Share Posted June 6 I think the melee issue is a bit more complicated than that - so while generally true, it is not always so because while the larger frontage means less models can get within 1", the larger "backage" can potentially increase the models that can get in. This is particularly the case for oval bases, where the long sides can allow for more models get attacks in, especially in choke points or other areas that limit the contact area between the 2 involved units. That doesn't refute your point, though, that auras and melee are the primary areas to be aware of the affect of larger bases. I would add to that screening - a unit on larger bases can take up a larger area and therefore deny larger areas from enemy deepstrike or movement - so, chaff units will be better at that role if their bases are "up sized". Link to comment https://bolterandchainsword.com/topic/386059-model-base-restrictions/#findComment-6114623 Share on other sites More sharing options...
kabaakaba Posted June 6 Author Share Posted June 6 Got it. Still it's all sportsmanship things. Dr_Ruminahui 1 Back to top Link to comment https://bolterandchainsword.com/topic/386059-model-base-restrictions/#findComment-6114636 Share on other sites More sharing options...
