Crablezworth Posted June 9 Share Posted June 9 Making titans feel more like they do in titanicus in li without a total re-write. So, I'm resigned to the fact that trying to actually cost all the titan weapons would just be a nightmare. I've instead focused on expanding titan weapons to have firing modes that represent the titan crew directing more reactor power than normal to weaponry to get a bit more oomph out of it. The system I've come up with isn't perfect, but essentially every gun has a buff of some sort if you risk pushing the reactor to fire it. The risk is heat buildup damaging the titan (causing a wound) I've also introduced a simple rule to represent titan's servitor clades, so basically for every primary weapon a titan elects not to fire when it activates in the combat phase, it gets a D6 repair roll of 4+ it can apply to repairing downed void shields or repairing a wound. These rolls are made immediately after the titan fires its weapons if any that activation/phase. This is also so that if a titan incurs heat damage, it may have a chance to repair some of it right after. Instead of doing entirely new weapon stats/profiles I chose instead a buff that may apply to existing profiles/fire modes, you're effectively replacing if its a stat or adding if its a weapon trait. Example pushing the reactor to fire a conversion beam dissolutor gives any of the 3 fire modes/range bands an extra shot. But if any of those 3 shot rolls are 1's it takes a wound or wounds. But ya basically the idea will be to look at all the titan weapons and think "if I was able to incur more risk for some kind of buff, what would be cool or make a less than popular weapon better". The first example of this in my mind was wanting a plasma blastgun to actually be able to have a blast template. It's worth noting, some of the traits like ripple fire or power capacitor also require that the titan be on first fire and thus have not moved, my thought there was it represent taking the saved motive power from the leg drives and putting it back into weaponry. My only thought there was some weapons to truly benefit might require not moving, I really wish more weapons in general in the game had some kind of buff for not moving or being on first fire. I don't get for example why most barrage weapons don't require not moving in order to fire out of los, but anyway. I certainly don't think all the added buffs are inspired for every weapon, I certainly struggled with some. A lot of my thinking was based on the fact that, for the most part in the games of LI I've played with titans, both myself and opponent pretty much always just too whatever spat as many dice as possible, so largely gatling/megabolter. If LI had a problem in general its that quality of fire rarely trumps quantity unless there's some very specific thing that needs doing like taking down a building. Quake and shock pulse certainly became more applicable with faq but I don't feel like it shifted what people are likely to take. But my thoughts on buffs would be, if something is more quality of fire than high output, giving it a dice or two more or in the case of plasma ability to add small blast. Now part of balancing the lower output weapons with the ones with a lot of shots, and also having basically a single gets hot system for everything, for now rolls of 1 always count/stick and re-rolls risk compounding that. The red dice indicate how many rolls of 1 will cause a wound, for weapons with a lot of shots that's usually 2-3 1's will equal a wound. And the weapon having accurate or ripple fire (re-roll to hit/re-roll 1's to hit) doesn't really help with heat building because initial 1's still count and its possible to roll 1 again which will also count. Basically heat building up exponential and bad and risky. This is also why I added the servitor clades so one can hopefully bank a repair dice for after. I'm not sure how well this will scale up past warlord, a warmaster has a lot of weapons and are already under-costed/costed on a curve. I'm also playing with a way to make titan's deaths more interesting/scary. Early thoughts were dying with a taxed reactor perhaps adding more range to the explosion/area of effect. So for example a titan on its last wound pushes its reactor to buff a weapon in the combat phase and dies accordingly, lets say for sake of argument the weapon caused more than one wound, could be that for every wound incurred from overheat the turn the titan dies it adds like 2 inches to the blast radius or an extra -1 to the ap of the explosion, or simply a higher likelihood of hitting, currently its 4+ but maybe that shifts to 3+. Lots to consider. I also think its worth considering making all titans 1+ save, I didn't want to touch that or add too much too soon as it'd be overwhelming to take in, but I do think down the line that might make sense trying. Lastly I'd like to either change how combat works in terms of what is allowed to charge a titan at all (infantry) or perhaps add a mechanic that lets titans step on scale 1 and 2 models that they can end their movement over with their base. Don't let any of those ideas scare you, obviously rules can be applied in a modular way, I just think its easier to expand than to try and fix point costs. Anyway, the goal was basically to bring back the feeling of heat and repair management without having to use a terminal or do much book keeping. apologist and Deus_Ex_Machina 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/386078-fixing-titans-in-li-to-bring-in-heat-and-repair-elements-like-at-without-much-bookkeeping/ Share on other sites More sharing options...
