TiguriusX Posted July 15, 2025 Share Posted July 15, 2025 On 7/14/2025 at 3:22 AM, DanPesci said: Logan has been great, one game I ran him with the terminators, one game just solo (even though his terminators landed next to him in the end). The +1CP bubble is worth its weight in gold, and ive found his deployment shenanigans great too, really has an opponent double guessing stuff/having to be careful screening out their backfield when i can potentially drop teminators/grey hunters/eradicators into their backfield T2. Got some bad news for you....Logan can only bring "space wolves" in early using his ability Eradicators can't use the trick Another item to be aware of is his ability only works on units in "strategic reserves" That means you have to declare your terminators (or whatever you want to use it on) are expressly using up your 500 point limit of SR instead of generic reserves When I run Logan I run him solo...i only drop him turn 1 if I need to give OC to my fenrisian wolves and no other SW character can get in range Karhedron, DanPesci and Prot 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/386119-prot-does-wolves-again/page/3/#findComment-6121846 Share on other sites More sharing options...
Karhedron Posted July 15, 2025 Share Posted July 15, 2025 That is a bit disappointing about Logan, I must remember to read the fine print. He is not cheap and really wants a Terminator brick to work with, who in turn need Arjac for their killing power. 400 points to really exploit the various synergies and I am not 100% convinced they are worth it. At the very least you need to be playing 2000+ points to be worth considering. Link to comment https://bolterandchainsword.com/topic/386119-prot-does-wolves-again/page/3/#findComment-6121865 Share on other sites More sharing options...
Lord Ragnarok Posted July 17, 2025 Share Posted July 17, 2025 On 7/15/2025 at 7:42 AM, TiguriusX said: Got some bad news for you....Logan can only bring "space wolves" in early using his ability Eradicators can't use the trick Another item to be aware of is his ability only works on units in "strategic reserves" That means you have to declare your terminators (or whatever you want to use it on) are expressly using up your 500 point limit of SR instead of generic reserves When I run Logan I run him solo...i only drop him turn 1 if I need to give OC to my fenrisian wolves and no other SW character can get in range Thanks for this reminder. I forgot about this (don’t play much). And this helps decides my list as I was going down the path of 2x TDAWGs Link to comment https://bolterandchainsword.com/topic/386119-prot-does-wolves-again/page/3/#findComment-6122257 Share on other sites More sharing options...
DanPesci Posted July 17, 2025 Share Posted July 17, 2025 (edited) On 7/15/2025 at 12:42 PM, TiguriusX said: Got some bad news for you....Logan can only bring "space wolves" in early using his ability Eradicators can't use the trick Another item to be aware of is his ability only works on units in "strategic reserves" That means you have to declare your terminators (or whatever you want to use it on) are expressly using up your 500 point limit of SR instead of generic reserves When I run Logan I run him solo...i only drop him turn 1 if I need to give OC to my fenrisian wolves and no other SW character can get in range Ah cheers for that! Id totally missed the Space Wolves part (still very much getting used to half our units not getting rules but some still doing depending on the strat/ability). To be honest id been on the fence about reserving the eradicators anyway - game 1 they didnt have anywhere useful to come in, and game 2 only found a spot due to us plaing on a 6x4 board (were not the most competitive lot lol). The reserves/strat reserves/deepstrike rules also blag my head a bit if I'm honest, always have done so the whole points limits/having to declare the termies as SR to use this I'd totally missed. That does suck quite a lot then as even logan + 5 termies, and a unit of GH with a battle leader is over 500 pts. It seems very odd that his ability wont work on massed terminator lists either Quote What are you arming Bjorn with? I am thinking Frost Cannon but not 100% decided yet. The MM doesn;t hit as hard but does have twice the rate of fire. Ive been running the helfrost, Bjorn tends to babysit my home obective and having 2 heavy flamer profiles as an overwatch/skirmish unit deterrent is ok, but he can then also reach out to midfield stuff late game with the D5 profile if really needed - also my bjorn is the SW contemptor with a custom printed volkite...sooo that passes as a helfrost cannon easier than as a las/MM Edited July 17, 2025 by DanPesci svane jotunsbane and Karhedron 2 Back to top Link to comment https://bolterandchainsword.com/topic/386119-prot-does-wolves-again/page/3/#findComment-6122374 Share on other sites More sharing options...
Prot Posted July 17, 2025 Author Share Posted July 17, 2025 Yea that’s what I’m doing with Bjorn as well. I have him babysitting wolves which seems oddly fluffy and they have OC this way. on Logan: thankfully I’ve only really used this on his own unit but thanks for the warning. Terrible restriction though and nit really apparent in other codexes. It makes me wonder if the long range goal is to stop everyone from borrowing from the main marine codex and using any detachment to full effect ( unless that detachment is in your specific book… ie Gladius) So who is running Headtakers with shields, vs double armed? Karhedron 1 Back to top Link to comment https://bolterandchainsword.com/topic/386119-prot-does-wolves-again/page/3/#findComment-6122422 Share on other sites More sharing options...
Jorin Helm-splitter Posted July 21, 2025 Share Posted July 21, 2025 (edited) I've been running a lot of headtakers in my lists, and I've stopped trying to compare the two loadouts. At this point they're practically different data sheets in my mind. The dual wielding headtakers are more of a one-use point & click unit. If having a cheap trade unit appeals to you, they're pretty good at it, although in my limited experience they really need advance and charge. I think that there is more of a debate between headtakers with shields and bladeguard than there is between the two loadouts. For what it's worth I've been running 3 units of headtakers in my most of my lists and I'm running 2 units with shields, and one with paired weapons. Edited July 22, 2025 by Jorin Helm-splitter Prot and Karhedron 2 Back to top Link to comment https://bolterandchainsword.com/topic/386119-prot-does-wolves-again/page/3/#findComment-6123402 Share on other sites More sharing options...
Prot Posted July 21, 2025 Author Share Posted July 21, 2025 I'd assume these are 3 man units? I have to agree... they're almost like two different dataslates at this point. Since I am playing Sagas, and I like Ragnar with BC's, I'm running mostly shields. Again I might be biased because I'm playing against a high volume of marine killing armies. Votann is another example. Tons of cover denial, higher AP, 2 damage weapons. I often infiltrate the 3 man shield units. But I do love my 6 man shield unit with the Wolf Priest. They can be really tough to get rid of. Personally I have been taking the Wolves add on units with them. My armies tend to get a bit small and elite, and everything is fairly expensive with the lack of 5 man units in the codex. At this point I may just make 2 squads, 6 dudes each, with each loadout! Karhedron 1 Back to top Link to comment https://bolterandchainsword.com/topic/386119-prot-does-wolves-again/page/3/#findComment-6123428 Share on other sites More sharing options...
Karhedron Posted July 21, 2025 Share Posted July 21, 2025 43 minutes ago, Prot said: At this point I may just make 2 squads, 6 dudes each, with each loadout! Good call. I already have 6 BGVs that I have heavily wolfed-up so I will probably run those as Headtakers with shields (and priest) and build my actual Headtakers with dual weapons. Prot 1 Back to top Link to comment https://bolterandchainsword.com/topic/386119-prot-does-wolves-again/page/3/#findComment-6123442 Share on other sites More sharing options...
Jorin Helm-splitter Posted July 22, 2025 Share Posted July 22, 2025 At the moment I'm running 12 headtakers. I've also been experimenting with a unit of 6 headtakers with shields lead by a Wolf Priest. I've only ran them once, but they did pretty well in that game. Karhedron and Prot 2 Back to top Link to comment https://bolterandchainsword.com/topic/386119-prot-does-wolves-again/page/3/#findComment-6123557 Share on other sites More sharing options...
Karhedron Posted August 14, 2025 Share Posted August 14, 2025 I also just tried 6 Headtakers with Shields and a Priest. I loaded them into an Impulsor and I have to say that I was very impressed. I was fighting Tau and their tally during the battle was: Longstrike Stealth Team Pathfinders Finished off a Hammerhead after my Land Raider had softened it up a bit They did great work, I was running them as Beastslayers so between Lethal Hits, Chosen Quarry and +1 to Wound from the Priest, they didn't have trouble even when facing T10+ targets. The priest was able to resurrect enough casualties to keep them at fighting strength until the end of the battle. This was helped by my opponent probably slightly overtooling against vehicles. This is probably as a result of the strong Knight meta at the moment, a Riptide might have taken a bigger chunk out of them. As it was, I got T1 and zoomed my Impulsor forward on one flank. Although Longstrike blew it away, they jumped out close enough to pull off a T2 charge and there was not enough Tau with LOS on that flank to take them out. I have the Priest Helm of the Beastslayer because I had a few point left over. Honestly I don't think it was worth it on a unit with a 3+/4++ save as it only kicks in against AP-1 attacks. This Enhancement is better on other squads but since it was all I had for the points, I took it anyway. Beastslayer is good on Stratagems but not so good on Enhancements I think so named Characters or Captains to power your strats are probably good. Still, I am pleased that my initial hunch of Headtakers and Priest having good synergy is working out so far. Prot 1 Back to top Link to comment https://bolterandchainsword.com/topic/386119-prot-does-wolves-again/page/3/#findComment-6127889 Share on other sites More sharing options...
