chapter master 454 Posted June 30, 2025 Share Posted June 30, 2025 Kind of curious. Imperial Knights were clearly meant to be out by now or at the very least follow on from chaos knights right after however, here we are...nary a peep about whats going on. So, to help pass time what are your theories as to what has happened or does anyone have any possible rumours as to what happned. And for a bonus: Do we think the defender kit will also mean we get 3 new questoris variants in the codex? (Plasma gun only, Conversion beamer only and then the one they showed off). Link to comment https://bolterandchainsword.com/topic/386201-sowhat-are-your-theories-as-to-what-happened-to-our-codex-launch/ Share on other sites More sharing options...
Lord_Ikka Posted June 30, 2025 Share Posted June 30, 2025 My guess is that the Emperor's Children leak spoiled some of GW's plans, they weren't meant to come out in spring but probably now or a little later. That might have been why they had a somewhat staggered release of their units rather than a big single one. I think the Defender will be just its own thing, like the Preceptor. I'll probably wind up getting one eventually, but unless their shield ability is something like "Increase the invulnerable save of IMPERIAL KNIGHT models within X inches", I don't see it as something that will be extremely useful. The guns look ok, but the plasma won't be as powerful as the Castellan's and the conversion beamer seems an odd choice for a Knight with the description of being out in front of it's fellows, guarding them (as conversion beamers are better from farther away, or at least get Sustained when shooting afar). I would have much rather had a different Armiger pattern for the Imperials, something good at taking down hordes armed with a weapon like the CK's chaincannons. Link to comment https://bolterandchainsword.com/topic/386201-sowhat-are-your-theories-as-to-what-happened-to-our-codex-launch/#findComment-6119045 Share on other sites More sharing options...
Naryn Posted June 30, 2025 Share Posted June 30, 2025 13 hours ago, chapter master 454 said: And for a bonus: Do we think the defender kit will also mean we get 3 new questoris variants in the codex? (Plasma gun only, Conversion beamer only and then the one they showed off). Unfortunately I doubt it. There are a lot of things rules-wise they should do for us in terms of possible weapon loadouts that they haven't done--weapon mix & matching freely within each armor class (questoris, cerastus, dominus, acastus) would be an easy win for them and cost 0 sprue space, for example. I suspect the plas-only and c-beamer-only variants would be the same. As for release, I suspect something went weird in the release order that booted us out of the queue. Maybe the EC release got pushed up like Lord_Ikka said, or maybe the big sprue Knight Defender parts come on had a mold issue that needed to be fiddled with. Link to comment https://bolterandchainsword.com/topic/386201-sowhat-are-your-theories-as-to-what-happened-to-our-codex-launch/#findComment-6119090 Share on other sites More sharing options...
NTaW Posted July 1, 2025 Share Posted July 1, 2025 I agree that it does feel sort of backward to get updated points without the book being released. GW's true reasons are known only to Tzeentch, but the EC release being moved up seems a reasonable hiccup in their timeline. As redundant as is may seem most the time, I like having the weapon options broken out across a few different datasheets. It offers more variety in abilities which means ever so slightly more variation in list building. Having said that I doubt that the new Knight will be broken up into separate new entries. At best we could perhaps see one or both of its weapons show up in other datasheets, but I agree that it will likely be it's own thing like the Preceptor. On 6/30/2025 at 6:27 AM, Lord_Ikka said: I would have much rather had a different Armiger pattern for the Imperials, something good at taking down hordes armed with a weapon like the CK's chaincannons. If GW tossed out an assault cannon (with pintle flamer of course) Armiger variant I would end up with a larger collection than planned Link to comment https://bolterandchainsword.com/topic/386201-sowhat-are-your-theories-as-to-what-happened-to-our-codex-launch/#findComment-6119198 Share on other sites More sharing options...
Indy Techwisp Posted July 2, 2025 Share Posted July 2, 2025 Thoughts about what happened with the book: They've had to redo the print run for it for some reason. Maybe the crate fell off the boat? Link to comment https://bolterandchainsword.com/topic/386201-sowhat-are-your-theories-as-to-what-happened-to-our-codex-launch/#findComment-6119429 Share on other sites More sharing options...
Lord_Ikka Posted July 3, 2025 Share Posted July 3, 2025 7 hours ago, Indy Techwisp said: They've had to redo the print run for it for some reason. Unless the run was missing entire pages, GW has been perfectly fine with having typos and incorrect info in codices before, so unlikely. 7 hours ago, Indy Techwisp said: Maybe the crate fell off the boat? They've also been ok with having products delayed to certain regions before due to transport issues. Link to comment https://bolterandchainsword.com/topic/386201-sowhat-are-your-theories-as-to-what-happened-to-our-codex-launch/#findComment-6119458 Share on other sites More sharing options...
Karhedron Posted July 3, 2025 Share Posted July 3, 2025 The roadmap strongly implied we would be coming out straight after Chaos Knights. This image is only about 3 months old so either there has been a change of plans or Warcomm made a mistake on the image (it would not be the first time). The only thing I can think of that we have heard about is the HH3.0 leaking early. Whilst this might have changed their marketing approach I cannot see why this would have any effect on the release schedule. One possibility is the 11th edition box set. We are expecting this to drop around this time next year which means production is probably in full swing and may have been for while. Apparently 10th edition had 500K boxes and I can easily see 11th edition having north of 600K. Maybe someone decided a few month ago that 11th edition needed an extra 100K boxes and Knights got bumped to make way for extra capacity. We know that the moulding machines at Lenton are running pretty much flat-out at the moment (to the extent that GW are looking at ways to increase capacity) so any change in quantities could potentially be enough to knock out production elsewhere. Link to comment https://bolterandchainsword.com/topic/386201-sowhat-are-your-theories-as-to-what-happened-to-our-codex-launch/#findComment-6119493 Share on other sites More sharing options...
chapter master 454 Posted July 7, 2025 Author Share Posted July 7, 2025 On 7/3/2025 at 7:04 AM, Lord_Ikka said: Unless the run was missing entire pages, GW has been perfectly fine with having typos and incorrect info in codices before, so unlikely. They've also been ok with having products delayed to certain regions before due to transport issues. and further to that, they are ok with rather major oppsies. The imperial agent codex I have is upside down, the internal pages were put in upside down so clearly the factory that was making them (and was the source of their leak very likely) wasn't high quality nor controlled. The question remains, clearly something went awry but my curiosity is focused on what could of caused such a major issue. Lost shipment could be one but I get the feeling they'd be transparent about if that had happened. The way they talk about it implies there was an issue with the codex, the new boxes for knights OR both. After all, what is the imperial knight battleforce launch boxset going to look like? I don't think we've ever seen this kind of delay on an army before. I get that their timeline was compromised but Imperial Knights were confidently shown to be after/next to chaos knights. Heck, their new defender was previewed FIRST before the ruinator almost implying their confidence in release. I suppose only time will tell, but GW won't ever admit to their issues...though if they do I'd consider that a surprise. Link to comment https://bolterandchainsword.com/topic/386201-sowhat-are-your-theories-as-to-what-happened-to-our-codex-launch/#findComment-6120014 Share on other sites More sharing options...
AvePicante Posted July 18, 2025 Share Posted July 18, 2025 I'm actually shocked it wasn't even mentioned during the Summer Preview. Knights are my second army, so I was watching for them. My thought is that the new Codex has something that would have spoiled the 30k box? Or it spoils the release of the Acastus knights and Atrapos in plastic, so they're delaying the launch until those models are ready. Maybe the launch box is like a single plastic Porphyrion lol Link to comment https://bolterandchainsword.com/topic/386201-sowhat-are-your-theories-as-to-what-happened-to-our-codex-launch/#findComment-6122804 Share on other sites More sharing options...
Vardus Posted July 18, 2025 Share Posted July 18, 2025 The question that needs answering is are the Knights late or are they arriving when they are meant to? We had Chaos Knights, the full release of Space Wolves and now HH3, if Imperial Knights are the next are they really out of sequence? As for the points release and stat changes for IK, well they knew their release schedule and thought that as it's a small number of units it made sense? Also if I'm remembering correctly they started adjusting other Daemon units after the release of the EC codex to start bringing them in line with the EC codex Slaanesh changes. Link to comment https://bolterandchainsword.com/topic/386201-sowhat-are-your-theories-as-to-what-happened-to-our-codex-launch/#findComment-6122844 Share on other sites More sharing options...
Karhedron Posted July 19, 2025 Share Posted July 19, 2025 10 hours ago, Vardus said: The question that needs answering is are the Knights late or are they arriving when they are meant to? The roadmap that was released back in March appeared to show IKs immediately after CKs. The roadmap was accurate in other regards such as the CSM Legions and Space Wolves. This strongly implies that IKs were scheduled to follow CKs and something happened to change that. DemonGSides 1 Back to top Link to comment https://bolterandchainsword.com/topic/386201-sowhat-are-your-theories-as-to-what-happened-to-our-codex-launch/#findComment-6122983 Share on other sites More sharing options...
Vardus Posted July 19, 2025 Share Posted July 19, 2025 But if they are the next release they are straight after the CK's. The roadmaps never show the follow on release of the full range and codex of an Army Box release and then when you add in AoS and HH3 things get stretched out. Link to comment https://bolterandchainsword.com/topic/386201-sowhat-are-your-theories-as-to-what-happened-to-our-codex-launch/#findComment-6123011 Share on other sites More sharing options...
NTaW Posted July 19, 2025 Share Posted July 19, 2025 20 hours ago, AvePicante said: I'm actually shocked it wasn't even mentioned during the Summer Preview. I thought the same, though there's still the chance it still gets announced for preorder tomorrow I suppose. 20 hours ago, Vardus said: The question that needs answering is are the Knights late or are they arriving when they are meant to? Looking at the roadmap, nothing "after" them has been released yet. We've just seen models and combat patrols for GK and BT. Then for 'on the horizon', we've now seen Votann as well as the 1st founding characters and combat squads. Link to comment https://bolterandchainsword.com/topic/386201-sowhat-are-your-theories-as-to-what-happened-to-our-codex-launch/#findComment-6123103 Share on other sites More sharing options...
Indy Techwisp Posted July 19, 2025 Share Posted July 19, 2025 Maybe it's coming at NOVA? Link to comment https://bolterandchainsword.com/topic/386201-sowhat-are-your-theories-as-to-what-happened-to-our-codex-launch/#findComment-6123141 Share on other sites More sharing options...
NTaW Posted July 20, 2025 Share Posted July 20, 2025 Oof, confirmed last in line for the release schedule. Next week's preorder article. Link to comment https://bolterandchainsword.com/topic/386201-sowhat-are-your-theories-as-to-what-happened-to-our-codex-launch/#findComment-6123251 Share on other sites More sharing options...
Vardus Posted July 20, 2025 Share Posted July 20, 2025 (edited) Yep, now defo MIA. Edited July 20, 2025 by Vardus spelling, doh! Link to comment https://bolterandchainsword.com/topic/386201-sowhat-are-your-theories-as-to-what-happened-to-our-codex-launch/#findComment-6123252 Share on other sites More sharing options...
NTaW Posted July 31, 2025 Share Posted July 31, 2025 Just tossing it out there, Questoris Knights have been removed from the GW store for almost a week now. It was mentioned that there would be a repack with the Preceptor/Canis sprue in one box and the new Knight one in the other. Last preorder was 30k, I figure this coming preorder will be AoS. Fingers crossed we see Knights released mid August. Focslain and Karhedron 2 Back to top Link to comment https://bolterandchainsword.com/topic/386201-sowhat-are-your-theories-as-to-what-happened-to-our-codex-launch/#findComment-6125401 Share on other sites More sharing options...
Focslain Posted July 31, 2025 Share Posted July 31, 2025 (edited) I'm kind of hoping, it's going to stink if we don't get our codex until winter since next summer is 11th edition. Edited July 31, 2025 by Focslain Link to comment https://bolterandchainsword.com/topic/386201-sowhat-are-your-theories-as-to-what-happened-to-our-codex-launch/#findComment-6125422 Share on other sites More sharing options...
Emperor Ming Posted July 31, 2025 Share Posted July 31, 2025 I was looking at knights actually as an easy low model army to get into, but being last or lastish isnt great Link to comment https://bolterandchainsword.com/topic/386201-sowhat-are-your-theories-as-to-what-happened-to-our-codex-launch/#findComment-6125444 Share on other sites More sharing options...
Focslain Posted July 31, 2025 Share Posted July 31, 2025 35 minutes ago, Emperor Ming said: I was looking at knights actually as an easy low model army to get into, but being last or lastish isnt great Honestly you can still start, the Noble Lance detachment is pretty decent and I doubt it will change much when the codex drops. Same with the stats and abilities of our units. So grab yourself 2 boxes of armigars and a questoris box or two checks website from your local FLGS (hopefully) and you got an army to start with. Fine tuning might cost you another questoris if you don't mag the weapons first. Sweet Gibus, almost everything in the knight line is out of stock, what the frak... Emperor Ming and Karhedron 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/386201-sowhat-are-your-theories-as-to-what-happened-to-our-codex-launch/#findComment-6125456 Share on other sites More sharing options...
NTaW Posted August 1, 2025 Share Posted August 1, 2025 18 hours ago, Emperor Ming said: I was looking at knights actually as an easy low model army to get into, but being last or lastish isnt great This was part of the driving force behind my own budding Knight collection. I don't think having a Codex really impacts building an army though, so long as you're magnetizing weapons on your Questoris. Armigers I'm not bothering to magnetize, though at times swapping between the two options seems to be the only way to move 10-30 points around in a list. There's also a hope that Codices aren't replaced with 11th. It's not unprecedented for a Codex to bridge editions, though we'll have to wait and see what GW decides to do. Ming the Merciless and Karhedron 2 Back to top Link to comment https://bolterandchainsword.com/topic/386201-sowhat-are-your-theories-as-to-what-happened-to-our-codex-launch/#findComment-6125595 Share on other sites More sharing options...
Karhedron Posted August 1, 2025 Share Posted August 1, 2025 (edited) 4 hours ago, NTaW said: There's also a hope that Codices aren't replaced with 11th. It's not unprecedented for a Codex to bridge editions, though we'll have to wait and see what GW decides to do. I think this is actually pretty likely. GW seems to be in a habit of alternating major and minor revisions. Major revisions are even numbered and throw out what went before, invalidating previous codices (e.g. 8th and 10th editions). Minor revisions are more like a consolidation of rules errata that have accumulated and some tidying up that does not change the basic stats (e.g. 7th and 9th editions). I am sure popular factions like Marines will get new codices in 11th edition. This will cover new units inevitably introduced in the starter box as well as buffing them to thrive in the new edition. Other factions will make do with their existing codices until GW decides they have some shiny new models to sell for that faction. For example, Eldar got a big range refresh in 10th edition so I see them as being closer to the back of the queue for any updates in 11th. On the other hand, Orks are rumoured to be "baddie" faction in the 11th edition start set so I can see their codex dropping quickly alongside space marines. Edited August 1, 2025 by Karhedron DemonGSides, Emperor Ming and NTaW 3 Back to top Link to comment https://bolterandchainsword.com/topic/386201-sowhat-are-your-theories-as-to-what-happened-to-our-codex-launch/#findComment-6125641 Share on other sites More sharing options...
Karhedron Posted August 4, 2025 Share Posted August 4, 2025 Scuttlebutt according to Valrak is that there was something wrong with the new Defender sprue so the batch had to be redone. I don't know if it was a problem during production or with the mold itself. If the latter then that could be expensive to fix. Link to comment https://bolterandchainsword.com/topic/386201-sowhat-are-your-theories-as-to-what-happened-to-our-codex-launch/#findComment-6126171 Share on other sites More sharing options...
NTaW Posted August 4, 2025 Share Posted August 4, 2025 Oof that would be a good reason for the (presumed) delay. That could be a very long delay if repackaging needs to happen, even longer if it has to do with the mold. Shame there will still be a split between getting the Preceptor sprue and the Defender sprue. It'd be cool if the Defender sprue came with a generic pilot to fill up the space, though two unique weapons may just do it. Focslain and Karhedron 2 Back to top Link to comment https://bolterandchainsword.com/topic/386201-sowhat-are-your-theories-as-to-what-happened-to-our-codex-launch/#findComment-6126174 Share on other sites More sharing options...
