Lysimachus Posted July 5, 2025 Share Posted July 5, 2025 Hello Fraters, So, quick question: As we all know, most Tacticus armour kits have those thigh plates (tassets) with the exception of Tactical Intercessors, Desolators and now Grey Hunters and Blood Claws. I've recently bought some GH to kitbash and mix in with my other minis, they're great minis with some lovely details... but I also really quite like the tassets? How would you go about getting/making more of them to glue on to those Marine types that don't have them? I've looked for 3d prints but not found any. (Little note to any 3d designers out there - I don't think I'd be the only one who'd buy these?) Or could you shape them out of plasticard, maybe make a template to cut around? I'm a bit stumped... Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/386231-tassets-for-tacticus-armour/ Share on other sites More sharing options...
Volgon Posted July 5, 2025 Share Posted July 5, 2025 (edited) Primaris Crusader Squads and Sword Brethren kits both come with some of the tassets separated from the legs, so you might be able to pick some up from Ebay or a bits seller depending on your location. Bitzbox doesn't sell them separately but I see a few USA sellers that do. Inner Circle Companions have a few tassets, generally with some attached pouches. Some of them are a bit fancier with a spiked surface. You could maybe repurpose the tilt shields common in Primaris kits to work as tassets too? They won't look exactly the same but maybe with a little modification you could get pretty close. I am also a big fan of tassets so for my renegades I make prolific use of the ones from Chaos Havoc kits. Obviously they have trim so maybe won't fit your aesthetic but they are another option. Also found some pretty basic STLs on Cults. Just search tassets, only a few results on there so should be easy to find. Edited July 5, 2025 by Volgon Firedrake Cordova and Lysimachus 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/386231-tassets-for-tacticus-armour/#findComment-6119792 Share on other sites More sharing options...
Lysimachus Posted July 5, 2025 Author Share Posted July 5, 2025 Great suggestions, thanks! Funny, I looked on Cults a while ago, not sure how I missed those! Volgon 1 Back to top Link to comment https://bolterandchainsword.com/topic/386231-tassets-for-tacticus-armour/#findComment-6119794 Share on other sites More sharing options...
Firedrake Cordova Posted July 6, 2025 Share Posted July 6, 2025 Is it possible to make a mould of them using green/blue stuff? Otherwise, I guess some plasticard if you can bend it to the correct curvature? Lysimachus 1 Back to top Link to comment https://bolterandchainsword.com/topic/386231-tassets-for-tacticus-armour/#findComment-6119826 Share on other sites More sharing options...
Grotsmasha Posted July 6, 2025 Share Posted July 6, 2025 The new multipart Terminators have these as separate parts too. Firedrake Cordova, Volgon and Lysimachus 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/386231-tassets-for-tacticus-armour/#findComment-6119863 Share on other sites More sharing options...
Lysimachus Posted July 6, 2025 Author Share Posted July 6, 2025 Thanks guys! I think the only issue with the TDA ones (other than maybe being a slightly different size?) would be getting spare ones without having to buy a whole body? I think the 3d print from Cults might be a good option, though I'm not sure of how to go about getting them printed? (UK based) Blue stuff mold and make them from GS is definitely a good idea, I've never used blue stuff but I could probably get some and try it out? I think maybe I will try making a pair from plasticard and see how they look. If it is doable, it is almost certainly the cheapest and most easily available option as I've got plenty of card, and even got some plastic tubes of various diameter that might help with creating the curvature? Link to comment https://bolterandchainsword.com/topic/386231-tassets-for-tacticus-armour/#findComment-6119887 Share on other sites More sharing options...
Firedrake Cordova Posted July 6, 2025 Share Posted July 6, 2025 22 minutes ago, Lysimachus said: Blue stuff mold and make them from GS is definitely a good idea, I've never used blue stuff but I could probably get some and try it out? Honestly, I've just painted the area with a thin layer of olive oil and applied Milliput to the area (the olive oil is to prevent sticking). Then I've done the same when pressing green stuff into the mould. Link to comment https://bolterandchainsword.com/topic/386231-tassets-for-tacticus-armour/#findComment-6119891 Share on other sites More sharing options...
Volgon Posted July 6, 2025 Share Posted July 6, 2025 Lots of sellers on Etsy have commission services for printing bits that you provide the STLs for. I'm USA based so I can't recommend a specific seller if you are looking for someone closer to home but just searching for "3D printing service" there and filtering by location should provide some results. I commissioned a pack of 15 helmets for around $14 USD (that's with shipping included) and I could have gotten it even cheaper had I waited an extra day or two for a different seller to get back to me. I think tassets using the Cults STLs would be even cheaper. No harm in reaching out and requesting a quote if plasticard or mold casting doesn't work out. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/386231-tassets-for-tacticus-armour/#findComment-6119917 Share on other sites More sharing options...
space wolf Posted July 21, 2025 Share Posted July 21, 2025 Funnily enough, i was litterally going though this same line of questioning. I bought a bunch of crusader squad bodies that didnt come with the prerequisite tasset parts. Luckily i have an unusued squad of crusaders on sprue. So i cut off one of the tassets, and using a 2 part kneedable epoxy called alumulite (sp?) I made a mold of the front half. (Part is so small figured i didnt need the back part). When this stuff dries its a kind if silicone rubber. So then i took some uv curing resin and poured it in the hole. A few seconds of blasting it with my uv flashlight and BAM! Instant tasset. I can post up some photos if youre interested in going this route. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/386231-tassets-for-tacticus-armour/#findComment-6123536 Share on other sites More sharing options...
