Inquisitor_Lensoven Posted July 18, 2025 Share Posted July 18, 2025 21 hours ago, Orange Knight said: If by situational, you mean it will probably be used every time they make an attack? Aggressors are short ranged units. It's extremely easy to position them in such a way as to almost always trigger the ability if they are in range of making a shooting attack. Also, let's not under-estimate the impact of twin linked for the Fists. 6 Aggressors will inflict the same number of wounds in close combat against a toughness 8 or higher unit as 10 Terminators. 6 Aggressors also do better in shooting than 10 Terminators. So it's a significantly more offensive unit, point for point. If you’re shooting only at the nearest target for no other reason than it activates your special rule, but I’m not shooting at cultists 6” away when there beserkers or something that’s a much scarier melee threat 7 or 8” away. On 7/17/2025 at 12:50 PM, HeadlessCross said: The problem with your numbers is you're ignoring the points entirely. Points are pretty irrelevant when discussing which is better at shooting. points to change which is better at it. WARMASTER_ 1 Back to top Link to comment https://bolterandchainsword.com/topic/386233-new-terminator-box-rumour/page/5/#findComment-6122564 Share on other sites More sharing options...
DemonGSides Posted July 18, 2025 Share Posted July 18, 2025 1 hour ago, Inquisitor_Lensoven said: If you’re shooting only at the nearest target for no other reason than it activates your special rule, but I’m not shooting at cultists 6” away when there beserkers or something that’s a much scarier melee threat 7 or 8” away. You should be playing your aggressors better. 1 hour ago, Inquisitor_Lensoven said: Points are pretty irrelevant when discussing which is better at shooting. points to change which is better at it. Points are quite literally always relevant. I don't care if it's infinite power fist attacks if it costs 2001 points; it's worthless by virtue of it not being practical to bring. Link to comment https://bolterandchainsword.com/topic/386233-new-terminator-box-rumour/page/5/#findComment-6122582 Share on other sites More sharing options...
Malakithe Posted July 18, 2025 Share Posted July 18, 2025 Can we finally have storm bolters with some AP on them? Inquisitor_Lensoven 1 Back to top Link to comment https://bolterandchainsword.com/topic/386233-new-terminator-box-rumour/page/5/#findComment-6122584 Share on other sites More sharing options...
HeadlessCross Posted July 18, 2025 Share Posted July 18, 2025 1 hour ago, Inquisitor_Lensoven said: If you’re shooting only at the nearest target for no other reason than it activates your special rule, but I’m not shooting at cultists 6” away when there beserkers or something that’s a much scarier melee threat 7 or 8” away. Well guess what? Aggressor shooting is also Twin Linked! It's also either immune to Hit Modifiers + Cover or has an additional blast attack. You also might still want to attack the Cultists in your example anyway so... Link to comment https://bolterandchainsword.com/topic/386233-new-terminator-box-rumour/page/5/#findComment-6122585 Share on other sites More sharing options...
Inquisitor_Lensoven Posted July 18, 2025 Share Posted July 18, 2025 15 minutes ago, DemonGSides said: You should be playing your aggressors better. Points are quite literally always relevant. I don't care if it's infinite power fist attacks if it costs 2001 points; it's worthless by virtue of it not being practical to bring. Points add relativity, does nothing for objectivity. Link to comment https://bolterandchainsword.com/topic/386233-new-terminator-box-rumour/page/5/#findComment-6122586 Share on other sites More sharing options...
HeadlessCross Posted July 18, 2025 Share Posted July 18, 2025 1 hour ago, Inquisitor_Lensoven said: Points are pretty irrelevant when discussing which is better at shooting. points to change which is better at it. It matters 100% because if Terminators were 100 points for all 5 they'd have better shooting. Link to comment https://bolterandchainsword.com/topic/386233-new-terminator-box-rumour/page/5/#findComment-6122587 Share on other sites More sharing options...
Inquisitor_Lensoven Posted July 18, 2025 Share Posted July 18, 2025 1 minute ago, HeadlessCross said: Well guess what? Aggressor shooting is also Twin Linked! It's also either immune to Hit Modifiers + Cover or has an additional blast attack. You also might still want to attack the Cultists in your example anyway so... Maybe, but probably will want to try to thin that bigger threat out a bit before charging it in most scenarios. Link to comment https://bolterandchainsword.com/topic/386233-new-terminator-box-rumour/page/5/#findComment-6122588 Share on other sites More sharing options...
Blindhamster Posted July 18, 2025 Share Posted July 18, 2025 1 hour ago, Inquisitor_Lensoven said: Points are pretty irrelevant when discussing which is better at shooting. Except they arent irrelevant. Because points dictate how much of something you can have. for the cost of 10 terminators, you get 9 aggressors with change. for the cost of 5 terminators you get 3 aggressors and an apothecary biologis or almost a gravis captain. ergo, you can't compare the units without taking points into account. The best comparison really is the 10 vs 9. which is 27 boltstorm gauntlet shots + 9d6 (31 average) fragstorm grenade shots vs realistically 32 stormbolter shots + 12 assault cannon shots most of the time. The aggressors are probably AP -1 most of the time (regardless of what you said, you're likely to move them to make the most of the rule) and are also twin linked, so realistically much better quality shots AND better quantity of shots. similarly on the melee front, whilst the aggressors only have 27 melee attacks instead of the 30 of the terminators, the aggressors again have twin linked. Link to comment https://bolterandchainsword.com/topic/386233-new-terminator-box-rumour/page/5/#findComment-6122589 Share on other sites More sharing options...
Inquisitor_Lensoven Posted July 18, 2025 Share Posted July 18, 2025 2 hours ago, Malakithe said: Can we finally have storm bolters with some AP on them? Honestly I wouldn’t mind AP0 if it was 4 base attacks with RF2 bolt weapons were designed to shred no power armored targets. assault cannon should definitely be AP-1 though. 2 hours ago, Blindhamster said: Except they arent irrelevant. Because points dictate how much of something you can have. for the cost of 10 terminators, you get 9 aggressors with change. for the cost of 5 terminators you get 3 aggressors and an apothecary biologis or almost a gravis captain. ergo, you can't compare the units without taking points into account. The best comparison really is the 10 vs 9. which is 27 boltstorm gauntlet shots + 9d6 (31 average) fragstorm grenade shots vs realistically 32 stormbolter shots + 12 assault cannon shots most of the time. The aggressors are probably AP -1 most of the time (regardless of what you said, you're likely to move them to make the most of the rule) and are also twin linked, so realistically much better quality shots AND better quantity of shots. similarly on the melee front, whilst the aggressors only have 27 melee attacks instead of the 30 of the terminators, the aggressors again have twin linked. Where are you getting 27 melee attacks for aggressors? each model gets 3, in a 6 man squad that’s 18 attacks… not really arguing aggressors are more lethal, but the post that initiated this whole thing made it sound like there were tons of options available to marine players that give PF access, therefore terminators bad. theres 1 unit that does that, and it’s less durable than terminators so it’s well balanced. Not to mention aggressors aren’t exactly an auto-pick. Malakithe 1 Back to top Link to comment https://bolterandchainsword.com/topic/386233-new-terminator-box-rumour/page/5/#findComment-6122590 Share on other sites More sharing options...
Indy Techwisp Posted July 18, 2025 Share Posted July 18, 2025 9 minutes ago, Malakithe said: Can we finally have storm bolters with some AP on them? Do they not have AP-1? I thought they did. Link to comment https://bolterandchainsword.com/topic/386233-new-terminator-box-rumour/page/5/#findComment-6122592 Share on other sites More sharing options...
DemonGSides Posted July 18, 2025 Share Posted July 18, 2025 (edited) 10 minutes ago, Indy Techwisp said: Do they not have AP-1? I thought they did. Nah. Scarab Occult Terminators are just leagues ahead of the other Terminator equivalents (At least for shooting). Edited July 18, 2025 by DemonGSides Link to comment https://bolterandchainsword.com/topic/386233-new-terminator-box-rumour/page/5/#findComment-6122595 Share on other sites More sharing options...
LittlePlasticHomies Posted July 18, 2025 Share Posted July 18, 2025 Rare Valrak miss - probably a matter of time at this point. Link to comment https://bolterandchainsword.com/topic/386233-new-terminator-box-rumour/page/5/#findComment-6122716 Share on other sites More sharing options...
Indy Techwisp Posted July 18, 2025 Share Posted July 18, 2025 13 minutes ago, LittlePlasticHomies said: Rare Valrak miss - probably a matter of time at this point. Did Valrak say it was coming this preview in the video? Link to comment https://bolterandchainsword.com/topic/386233-new-terminator-box-rumour/page/5/#findComment-6122752 Share on other sites More sharing options...
Inquisitor_Lensoven Posted July 18, 2025 Share Posted July 18, 2025 3 hours ago, DemonGSides said: You should be playing your aggressors better. Points are quite literally always relevant. I don't care if it's infinite power fist attacks if it costs 2001 points; it's worthless by virtue of it not being practical to bring. So you think aggressors are better shooting than a landraider because they’re cheaper? Link to comment https://bolterandchainsword.com/topic/386233-new-terminator-box-rumour/page/5/#findComment-6122768 Share on other sites More sharing options...
LittlePlasticHomies Posted July 18, 2025 Share Posted July 18, 2025 6 minutes ago, Indy Techwisp said: Did Valrak say it was coming this preview in the video? Good point and that I don’t recall. I may have amalgamated rumors in my mind Link to comment https://bolterandchainsword.com/topic/386233-new-terminator-box-rumour/page/5/#findComment-6122772 Share on other sites More sharing options...
Orange Knight Posted July 18, 2025 Share Posted July 18, 2025 3 hours ago, Inquisitor_Lensoven said: Where are you getting 27 melee attacks for aggressors? each model gets 3, in a 6 man squad that’s 18 attacks… What's stopping someone from bringing another unit of 3 Aggressors? You still have points to spare. That's the comparison being made. Also having two units gives your more flexibility and control over the battlefield. Karhedron 1 Back to top Link to comment https://bolterandchainsword.com/topic/386233-new-terminator-box-rumour/page/5/#findComment-6122793 Share on other sites More sharing options...
Chapter Master Valrak Posted July 18, 2025 Author Share Posted July 18, 2025 45 minutes ago, LittlePlasticHomies said: Rare Valrak miss - probably a matter of time at this point. Spoiler Dark Shepherd, darkhorse0607, painting.for.my.sanity and 2 others 4 1 Back to top Link to comment https://bolterandchainsword.com/topic/386233-new-terminator-box-rumour/page/5/#findComment-6122805 Share on other sites More sharing options...
Indy Techwisp Posted July 18, 2025 Share Posted July 18, 2025 Hey Valrak. Did the rumour source mention what kind of Thunderclaws the new Assault Terminators have if they have them? Link to comment https://bolterandchainsword.com/topic/386233-new-terminator-box-rumour/page/5/#findComment-6122812 Share on other sites More sharing options...
Marshal Reinhard Posted July 18, 2025 Share Posted July 18, 2025 Thunderclaws stormhammers and lightningshields ThaneOfTas, Armchair Warlord, painting.for.my.sanity and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/386233-new-terminator-box-rumour/page/5/#findComment-6122832 Share on other sites More sharing options...
HeadlessCross Posted July 18, 2025 Share Posted July 18, 2025 42 minutes ago, Inquisitor_Lensoven said: So you think aggressors are better shooting than a landraider because they’re cheaper? Well which Land Raider are we talking about? 3×3 Aggressors w/ the Flamestorms is the same cost as a Redeemer. 9d6+9 S4 AP-1 D1 TL vs 2d6+6 S6 AP-2 D2 is something we can absolutely compare, and when we see who comes out on top we can see which is better for the price. To help you figure this out better, is a 75 point lascannon better than a 100 point lascannon. Yes or no? Link to comment https://bolterandchainsword.com/topic/386233-new-terminator-box-rumour/page/5/#findComment-6122841 Share on other sites More sharing options...
Blindhamster Posted July 18, 2025 Share Posted July 18, 2025 4 hours ago, Inquisitor_Lensoven said: Where are you getting 27 melee attacks for aggressors? each model gets 3, in a 6 man squad that’s 18 attacks… Re-read, because points are relevant, you can get 9 aggressors for the cost of 10 terminators.. ergo 3x9 is... 27 Link to comment https://bolterandchainsword.com/topic/386233-new-terminator-box-rumour/page/5/#findComment-6122857 Share on other sites More sharing options...
Osteoclast Posted July 19, 2025 Share Posted July 19, 2025 Throwing things into the Adept Roll app for some mathhammer: Against MEQ shooty Aggressor squad averages 10.8 damage and 5.4 dead models for 9.3 point per damage point. Flamer Aggressors are 11.3W, 5.6K, and 8.8 PDP. Termies with assault cannon (statistically best) are 8.9K, 17.8W, and 9.6 PPD. Melta Centurions are 7.2K, 21.4W, and 7 PPD. Flameturions are 6.7K, 17.3W, and 8.7 PPD. Against TEQ: Shootygressor: 2.3K, 6.9W, 14.5 PPD. Flamegressor: 2.6K, 7.8W, 12.8 PPD. Cyclone Termies: 3.5K, 11W, 15.5 PPD. Melta Centurions: 4.5K, 15.1W, 9.9 PPD Flameturions: 3.6K, 10.9W, 13.8 PPD This one gave the -1 AP to the Aggressors. In all cases, the shooting is honestly negligible, it’s mostly the fists doing the work. Ignoring melee and going for best variant for my sanity: MEQ: Flamegressor: 1.7K, 3.4W, 29.4 PPD. Termies: 1.9k, 3.9W, 43.6 PPD. Melturions: 3.3K, 9.8W, 15.3 PPD TEQ Flamegressor: 0.8K, 2.5W, 40 PPD Termies: 0.7K, 2.7W, 63 PPD Melturions: 1.6K, 6.3W, 23.8 PPD In summary: Embrace the chonk marines, for they are the true path. Terminator squads are slightly better than Aggressors for TEQs, but you’re really paying a premium for a little bit better shooting range and one stowed TEQ kill; survivability is really where the conversation is at imo. Of course, it does kind of suggest that the names are a clue as to role, with Aggressors being better suited for getting in people’s faces (and I think it’s a no brainer that a 6 man aggressor squad, or squad plus gravis captain is a better offensive use of land raider than terminator squad), while terminators will be better for holding a secured point (or surprise securing with deep strike). ZeroWolf, DemonGSides and Karhedron 3 Back to top Link to comment https://bolterandchainsword.com/topic/386233-new-terminator-box-rumour/page/5/#findComment-6122956 Share on other sites More sharing options...
