Uprising Posted July 7, 2025 Share Posted July 7, 2025 (edited) I just got a box of scout that I want to use for kill team. How should I build the box? Thinking about this loadout, thoughts? Scouts (10) o Sergeant: Chainsword and Bolt pistol o Hunter: knife and bolt pistol, grappling gun o Tracker: boltgun and auspex o Heavy Gunner: Heavy Bolter o Heavy Gunner: Missile Launchers o Sniper: Sniper o Warrior with Astartes Shotgun o Warrior with Astartes Shotgun o Warrior with Bolt Pistol, Combat Blade o Warrior with Bolt Pistol, Combat Blade Edited July 7, 2025 by Uprising Link to comment https://bolterandchainsword.com/topic/386237-scout-loadout/ Share on other sites More sharing options...
firestorm40k Posted July 7, 2025 Share Posted July 7, 2025 I went similar for my Scouts, just I went for Warriors with Boltguns rather than Pistol/Combat Knives; it depends on whether you want more melee than shooting. I've found the Scout team to be effective at both, though I've gone more on the shooting side. Your choice looks pretty balanced! With mine there was also the consideration that I would use then in 40k - two squads of 5, one for ranged support and one for close range fire fights. Naturally, after I built and painted them, GW gave Scout knives a buff so those would have been the better choice instead of Shotguns..! Uprising and Dr_Ruminahui 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/386237-scout-loadout/#findComment-6120131 Share on other sites More sharing options...
Uprising Posted July 9, 2025 Author Share Posted July 9, 2025 Thank you for the post. I could change out one off the warrior with bolt pistol / blade for a bolter. Gives some variety and would help the project out. firestorm40k 1 Back to top Link to comment https://bolterandchainsword.com/topic/386237-scout-loadout/#findComment-6120376 Share on other sites More sharing options...
