Spiny Norman Posted July 8, 2025 Share Posted July 8, 2025 What sort of power/speed rating should I be looking for in a rotary tool? Amazon have a few in the Prime Day Deals so I'm tempted to pick one up, but I want to make sure I get the right one! Thanks! Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/386242-dremelrotary-tool-advice/ Share on other sites More sharing options...
sbarnby71 Posted July 8, 2025 Share Posted July 8, 2025 In my experience you don't need super fast. I have a plug in one and I tend to use it on setting 1 of 5, I also have a rechargeable one that is like a pen and that is just fine for small detail work. Go for one that has variable speed and a lot of attachments and try and get something as small as possible so it's easy to use - also you don't need Dremel branded, the cheap ones are fine enough around the £20 mark. Spiny Norman and Firedrake Cordova 2 Back to top Link to comment https://bolterandchainsword.com/topic/386242-dremelrotary-tool-advice/#findComment-6120213 Share on other sites More sharing options...
sbarnby71 Posted July 8, 2025 Share Posted July 8, 2025 This is the one I got 5+ years ago for about £20, I use it all the time Spiny Norman and Firedrake Cordova 2 Back to top Link to comment https://bolterandchainsword.com/topic/386242-dremelrotary-tool-advice/#findComment-6120223 Share on other sites More sharing options...
Karhedron Posted July 8, 2025 Share Posted July 8, 2025 My only advice is avoid the Parkside ones. Cheap and shoddy. You don't need to spend a fortune but sometimes getting the cheapest on the market is a false economy. Firedrake Cordova, Spiny Norman and DemonGSides 3 Back to top Link to comment https://bolterandchainsword.com/topic/386242-dremelrotary-tool-advice/#findComment-6120225 Share on other sites More sharing options...
andes Posted July 8, 2025 Share Posted July 8, 2025 I didn't use mine anywhere near as much as I expected to. Can't remember the last time I fired it up... The problem I had was that even on the lowest setting it ran fast enough to melt the plastic rather than cut cleanly. Of course, I could just be an oaf but caveat emptor. If you just want to drill holes, maybe check out the WOW Stick drill. That thing rocks. Firedrake Cordova and Spiny Norman 2 Back to top Link to comment https://bolterandchainsword.com/topic/386242-dremelrotary-tool-advice/#findComment-6120234 Share on other sites More sharing options...
Spiny Norman Posted July 8, 2025 Author Share Posted July 8, 2025 Thanks everyone that's really helpful. The main thing I want it for right now is for hollowing out neck sections for head swaps, so like a round tipped engraving/carving tool. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/386242-dremelrotary-tool-advice/#findComment-6120235 Share on other sites More sharing options...
sbarnby71 Posted July 8, 2025 Share Posted July 8, 2025 Whatever one you get, practice on some spare plastic so you get used to the speed and also be aware that as others have said it can melt the plastic, so do short contacts with the tip so you don't overheat and melt the plastic, if you do the tip gets coated in plastic goo that goes hard pretty quick. Spiny Norman 1 Back to top Link to comment https://bolterandchainsword.com/topic/386242-dremelrotary-tool-advice/#findComment-6120247 Share on other sites More sharing options...
Firedrake Cordova Posted July 8, 2025 Share Posted July 8, 2025 Would adding a little water to the surface help with the melting issue? (assuming the surface is shaped in a way that means it doesn't immediately run off...) Link to comment https://bolterandchainsword.com/topic/386242-dremelrotary-tool-advice/#findComment-6120249 Share on other sites More sharing options...
Evil Eye Posted July 15, 2025 Share Posted July 15, 2025 I recently got a Dremel Stylo+ and it's very good. Not hugely powerful but for our scale it works fine and it's very comfortable to use. Also completely compatible with all Dremel accessories despite the small size. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/386242-dremelrotary-tool-advice/#findComment-6121848 Share on other sites More sharing options...
