Joe Posted July 9 Share Posted July 9 Downloads page has been updated with all relevant information. The new Drop Pod rules are in there, plus a designer's note. Dr_Ruminahui and Karhedron 2 Back to top Link to comment https://bolterandchainsword.com/topic/386247-balance-dataslate-july-2025/ Share on other sites More sharing options...
Indy Techwisp Posted July 9 Share Posted July 9 Surprised no-ones commented in here yet. TSons had the Tzaangor Detachment get needed so MVBs aren't overpowered in it, but we got Firing Deck back on our Rhinos and the Risen Rubricae enhancement now allows an attached character to infiltrate with the Rubricae Squad/s chosen. Also T'au got their new Spotting rule reworded so Kroot still can't use it and you can't spot the same unit multiple times, but you can now spot on activation so you can select something that bailed from a destroyed transport and Kayon got a designer's note explaining which rounds the rule applies to. Dr_Ruminahui, N1SB and Bat33.1 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/386247-balance-dataslate-july-2025/#findComment-6120442 Share on other sites More sharing options...
Bat33.1 Posted July 9 Share Posted July 9 Unless I'm missing something I can't see any changes to Death Guard? Points look unchanged and nothing to see in the update, the way some people were talking the sky was falling in when DG codex dropped Karhedron and N1SB 2 Back to top Link to comment https://bolterandchainsword.com/topic/386247-balance-dataslate-july-2025/#findComment-6120522 Share on other sites More sharing options...
Dark Shepherd Posted July 9 Share Posted July 9 RIP rapid fire hunter killer missiles on space wolf vehicles brother Vorn_GarDos and Ming the Merciless 2 Back to top Link to comment https://bolterandchainsword.com/topic/386247-balance-dataslate-july-2025/#findComment-6120538 Share on other sites More sharing options...
DemonGSides Posted July 9 Share Posted July 9 1 hour ago, Bat33.1 said: Unless I'm missing something I can't see any changes to Death Guard? Points look unchanged and nothing to see in the update, the way some people were talking the sky was falling in when DG codex dropped The Knight Menace has taken over as the current competitive boogeyman so the DG being slightly over-tuned is no longer a "chicken little" situation. If they nerf knights without taking anything to the DG then you'll probably start hearing those same voices start piping up again. DG just needs some points adjustments. It's okay for a force to be strong, just gotta balance how much of it shows up on the field. Bat33.1 and N1SB 2 Back to top Link to comment https://bolterandchainsword.com/topic/386247-balance-dataslate-july-2025/#findComment-6120541 Share on other sites More sharing options...
Inquisitor_Lensoven Posted July 10 Share Posted July 10 Seems like a lot of changes to SW…are they even on shelves yet? Link to comment https://bolterandchainsword.com/topic/386247-balance-dataslate-july-2025/#findComment-6120552 Share on other sites More sharing options...
sairence Posted July 11 Share Posted July 11 On 7/9/2025 at 10:37 PM, Bat33.1 said: Unless I'm missing something I can't see any changes to Death Guard? Points look unchanged and nothing to see in the update, the way some people were talking the sky was falling in when DG codex dropped It's an Errata/FAQ, so just corrections/clarifications. Aka "this is how it's meant to work". You're looking for the balance dataslate, which is where actual rule changes and balance adjustments happen. That'a going to be a little while before we get the next one. Karhedron, Bat33.1 and Ming the Merciless 3 Back to top Link to comment https://bolterandchainsword.com/topic/386247-balance-dataslate-july-2025/#findComment-6120919 Share on other sites More sharing options...
