OverchargeThis! Posted July 28, 2025 Share Posted July 28, 2025 I'm going to build 6 Bullgryns. To your experience, is the slab shield (+1 Wounds) or the brute shield (4+ invulnerable save) better? I tend to lean in the direction of the brute shield. I am getting ready to assemble and paint a squad of these guys, and want to figure out which of the two shield types I should build them with. Thanks. Link to comment https://bolterandchainsword.com/topic/386359-bullgryn-question-which-shield-type-is-better/ Share on other sites More sharing options...
Emperor Ming Posted July 28, 2025 Share Posted July 28, 2025 You can mix them right? half and half? Thou id never use them now they cant be ordered Link to comment https://bolterandchainsword.com/topic/386359-bullgryn-question-which-shield-type-is-better/#findComment-6124722 Share on other sites More sharing options...
DemonGSides Posted July 28, 2025 Share Posted July 28, 2025 10 hours ago, OverchargeThis! said: I'm going to build 6 Bullgryns. To your experience, is the slab shield (+1 Wounds) or the brute shield (4+ invulnerable save) better? I tend to lean in the direction of the brute shield. I am getting ready to assemble and paint a squad of these guys, and want to figure out which of the two shield types I should build them with. Thanks. Invuln is going to be more impactful in my opinion. 1 wound is easy to pick up, especially considering the guns that are being aimed at them. Two damage weapons are still going to need 2 shots to kill them, and I feel like 2 damage is more likely to be aimed at them to take them out, so I think the invuln increase is better as it'll make each of those shots less likely to impact, as AP1/2/3 is plentiful across almost all armies. Bouargh 1 Back to top Link to comment https://bolterandchainsword.com/topic/386359-bullgryn-question-which-shield-type-is-better/#findComment-6124786 Share on other sites More sharing options...
sairence Posted July 29, 2025 Share Posted July 29, 2025 18 hours ago, DemonGSides said: Invuln is going to be more impactful in my opinion. 1 wound is easy to pick up, especially considering the guns that are being aimed at them. Two damage weapons are still going to need 2 shots to kill them, and I feel like 2 damage is more likely to be aimed at them to take them out, so I think the invuln increase is better as it'll make each of those shots less likely to impact, as AP1/2/3 is plentiful across almost all armies. Bullgry have -1 damage. 2 damage weapons do the same as 1 damage weapons to them. The 4++ is going to be better for them most of the time, because you want them to tank dedicated melee units before they get to your shooty stuff. If you run a big unit, mixing in one or two Slabs could be nice though. Link to comment https://bolterandchainsword.com/topic/386359-bullgryn-question-which-shield-type-is-better/#findComment-6124930 Share on other sites More sharing options...
DemonGSides Posted July 29, 2025 Share Posted July 29, 2025 2 hours ago, sairence said: Bullgry have -1 damage. 2 damage weapons do the same as 1 damage weapons to them. The 4++ is going to be better for them most of the time, because you want them to tank dedicated melee units before they get to your shooty stuff. If you run a big unit, mixing in one or two Slabs could be nice though. Oh fair I didn't even think about the ability, just the damage breakpoints. My points still stand tho; 2 damage (3 in their case) still kills them in two hits regardless of which shield is chosen, so to me the 4+ is the only real choice. There's so very little D4 weaponry out there it's not worth considering, since it would fall to D3. I think mixing is just a trap. Gonna want to use an invulnerable when you only have health increase available and it's gonna be like having no extra health anyways. Link to comment https://bolterandchainsword.com/topic/386359-bullgryn-question-which-shield-type-is-better/#findComment-6124958 Share on other sites More sharing options...
