barek Posted July 28, 2025 Share Posted July 28, 2025 Bolter and Fenrisian axe? Or shield and axe? Link to comment https://bolterandchainsword.com/topic/386368-hh3-how-to-equip-grey-slayers/ Share on other sites More sharing options...
Shark in Exile Posted July 31, 2025 Share Posted July 31, 2025 I use one unit of 10 with Bolter and Axe and another of 15 with shield and Axe. thinking of adding another 10 with bolster and axe. Link to comment https://bolterandchainsword.com/topic/386368-hh3-how-to-equip-grey-slayers/#findComment-6125389 Share on other sites More sharing options...
barek Posted August 1, 2025 Author Share Posted August 1, 2025 (edited) Ah! Thank you. How do they compare? Do you get better results with bolter and axe? Does the 'shield save' do you any good? Edited August 1, 2025 by barek Link to comment https://bolterandchainsword.com/topic/386368-hh3-how-to-equip-grey-slayers/#findComment-6125704 Share on other sites More sharing options...
Chyttering Posted August 4, 2025 Share Posted August 4, 2025 Disclaimer: I haven't played a game in 3rd yet, just dipped my toes into writing lists. In 2nd I ran mine in squads of 15: a challenge-oriented huscarl, 4 power spears, a power axe, and 9 with bolters and axes. I pretty much never used the bolters because I was running them every turn to get into combat and didn't want to risk Return Fire shooting snap shots. They ran over tactical squads, destroyers, etc but pretty much evaporated if I tried to take on elite melee units. I think that loadout is going to stay the same in 3rd (they're already painted, after all) but utility will be different. Line (2) means they may end up sitting on objectives rather than racing into combat, so the bolters will potentially be useful to contribute something at range, whereas shields that only work against melee hits would become less attractive. I think their melee status will be about the same as 2nd - great to bully non-melee infantry, but probably even worse at punching up into elite units than they were in 2nd. Power weapons are cheaper on Slayers than on the core melee squads (Despoilers or Assault), and you can take more of them in a squad, but I think it's worth tempering the impulse to give everyone a power axe. You don't need that many to hammer at another line unit, and you're still going to lose a fight with veterans or terminators. barek 1 Back to top Link to comment https://bolterandchainsword.com/topic/386368-hh3-how-to-equip-grey-slayers/#findComment-6126154 Share on other sites More sharing options...
