L30n1d4s Posted August 3 Share Posted August 3 (edited) I am starting to think that 10 Sword Brethren, all with Chainswords, riding in a Land Raider Crusader with a Marshal and Lieutenant leading them, is a pretty ridiculous unit. Now that they get 6A each, hitting at WS2+, a 10 man squad puts out 60 attacks at S4 AP-1 Dmg1. Coming out of a LR Crusader, they get to reroll Hits and wounds of 1, they get Lethal Hits (from the Lieutenant) and Sustained Hits 1 (built into their chainswords), they get critical Hits on 5+s (from the Marshall), and they have +1 to wound against anything T4 or higher (from Accept Any Challenge). Taken all together, I think this unit can be a "hammer" squad that can take out enemy flagship units when required. For example, against an Imperial Knight, this squad averages 46 x AP-1 wounds, so about 23 unsaved wounds (and that is without the Marshall's and Lieutenant's attacks factored in). Against Deathshroud Terminators, the same squad averages 60 x AP-1 wounds, so 5 dead Deathshrouds (throw in their shooting and the Marshall and Lieutenant attacks and you likely will kill the whole squad and maybe even the character leading them). Even against a super tough unit, like Necron C'tan, this squad averages about 15 unsaved wounds, so enough to kill it outright in a single fight phase. Finally, against any horde infantry, like Orks or Guard or GSC or Nids, this unit obviously should be able to wood chipper through almost anything they hit. Bottom line, I think this unit might be a hidden gem within the new BT codex and I am excited to try it out, especially combined with some of the other great new tools (like BT Repulsors, the new Helbrecht, new EC, etc.) Edited August 3 by L30n1d4s Link to comment https://bolterandchainsword.com/topic/386417-chainsword-sword-brethren/ Share on other sites More sharing options...
HeadlessCross Posted August 3 Share Posted August 3 The main thing to keep in mind is that, the moment you run into an AoC equivalent strat, youre stuck back at AP-. The real question is do you want the Sustained Hits from the Chainswords or the Lethal Hits from the Power Weapons. L30n1d4s 1 Back to top Link to comment https://bolterandchainsword.com/topic/386417-chainsword-sword-brethren/#findComment-6125921 Share on other sites More sharing options...
Sir Clausel Posted August 3 Share Posted August 3 I have thought about it that to. As said before the AoC equivalent is a real thing and will stop it pretty hard. So i thought it might be good to go with Grimaldus instead? Its a little cheaper since its only the one character. He has build in reroll hits and can give them +1 ap? He also gives them a few extra wounds with an invulnerable save so will make them a little tankier. But you will lose damage overall im pretty sure. But i still think they will hit pretty hard. L30n1d4s and jimbo1701 2 Back to top Link to comment https://bolterandchainsword.com/topic/386417-chainsword-sword-brethren/#findComment-6125941 Share on other sites More sharing options...
L30n1d4s Posted August 3 Author Share Posted August 3 (edited) Good points on both counts here.... I guess the best way to run this would be Gladius, where you can get an extra -1AP from Strats. Edited August 6 by L30n1d4s Sir Clausel 1 Back to top Link to comment https://bolterandchainsword.com/topic/386417-chainsword-sword-brethren/#findComment-6125966 Share on other sites More sharing options...
HeadlessCross Posted August 6 Share Posted August 6 On 8/3/2025 at 1:03 PM, Sir Clausel said: I have thought about it that to. As said before the AoC equivalent is a real thing and will stop it pretty hard. So i thought it might be good to go with Grimaldus instead? Its a little cheaper since its only the one character. He has build in reroll hits and can give them +1 ap? He also gives them a few extra wounds with an invulnerable save so will make them a little tankier. But you will lose damage overall im pretty sure. But i still think they will hit pretty hard. Reroll hits is mostly useless for a unit that hits on 2+ natively. CastellanDeMolay 1 Back to top Link to comment https://bolterandchainsword.com/topic/386417-chainsword-sword-brethren/#findComment-6126492 Share on other sites More sharing options...
Sir Clausel Posted August 6 Share Posted August 6 Not if you have sustained or lethals Link to comment https://bolterandchainsword.com/topic/386417-chainsword-sword-brethren/#findComment-6126495 Share on other sites More sharing options...
HeadlessCross Posted August 7 Share Posted August 7 20 hours ago, Sir Clausel said: Not if you have sustained or lethals It actually still is because you're not natively going to reroll a good amount. Just going for a regular ol' +1 to wound or a Fights First will work out better. If you want to fish like that, you might as well just do a large Crusader squads instead. Link to comment https://bolterandchainsword.com/topic/386417-chainsword-sword-brethren/#findComment-6126674 Share on other sites More sharing options...
Medjugorje Posted August 7 Share Posted August 7 simply not true. If you have lethals and fight a knight.... rerolls and lethals are a very strong combo, esp. with WS 2+ Sir Clausel 1 Back to top Link to comment https://bolterandchainsword.com/topic/386417-chainsword-sword-brethren/#findComment-6126724 Share on other sites More sharing options...
Sir Clausel Posted August 7 Share Posted August 7 And when you can get crits on 5+ the rerolls become massive! Link to comment https://bolterandchainsword.com/topic/386417-chainsword-sword-brethren/#findComment-6126743 Share on other sites More sharing options...
