Brother Tyler Posted August 17 Share Posted August 17 I was contacted by a member whose rank reduced for no apparent reason. Looking into it, it appears that the system did something funky, reseting the member's achievement points total to 1 after they performed a certain action (and that's not supposed to happen). At least one other member appears to have been affected in the same way. There may be others that have been affected in this way, however. How can you tell if you're one of the unlucky members that has been affected? Your rank (e.g., Battle-Brother, Veteran, etc.) will be low compared to what you recall and/or when compared to the achievement badges you have earned. You can see all of the achievement badges that you have earned in your profile, and you can see information about the rank progressions here. If things look off, feel free to post a reply in this topic to help us in our investigation. Link to comment https://bolterandchainsword.com/topic/386529-something-weird-going-on-with-ranks/ Share on other sites More sharing options...
Mazer Rackham Posted August 18 Share Posted August 18 Yep, been busted down to Aspirant. Not sure when it happened, so I can't pinpoint it - apologies. Link to comment https://bolterandchainsword.com/topic/386529-something-weird-going-on-with-ranks/#findComment-6128468 Share on other sites More sharing options...
Jolemai Posted August 18 Share Posted August 18 (edited) Clearly Leandros has been at work here. Have you strayed from the teachings of the Codex Astartes? Edited August 18 by Jolemai Brother Tyler 1 Back to top Link to comment https://bolterandchainsword.com/topic/386529-something-weird-going-on-with-ranks/#findComment-6128469 Share on other sites More sharing options...
Brother Tyler Posted August 18 Author Share Posted August 18 At this point it looks like the creation of a club resets a member's achievement points to 1. I'm not sure why the system would do that. Link to comment https://bolterandchainsword.com/topic/386529-something-weird-going-on-with-ranks/#findComment-6128484 Share on other sites More sharing options...
Mazer Rackham Posted August 21 Share Posted August 21 (edited) On 8/18/2025 at 12:34 PM, Jolemai said: Clearly Leandros has been at work here. Have you strayed from the teachings of the Codex Astartes? On 8/18/2025 at 1:49 PM, Brother Tyler said: At this point it looks like the creation of a club resets a member's achievement points to 1. I'm not sure why the system would do that. Ah, it's obviously a command decision from the HLOT, then. Not going to complain - it gives Ork Snipers someone else to shoot at. Edited August 21 by Mazer Rackham Link to comment https://bolterandchainsword.com/topic/386529-something-weird-going-on-with-ranks/#findComment-6128966 Share on other sites More sharing options...
Brother Tyler Posted September 11 Author Share Posted September 11 I've gone through and adjusted the two members who I know were affected to the proper levels. It looks like the achievement to create a club reset their achievement points to 1. I waited a few weeks to observe their successive achievements to see if anything other weird things would happen, but it looks like everything else was normal, so it was just a matter of adding their previous achievement points to their post-jankiness achievement points. I'm now checking to see if any other members were affected so that I can fix their achievement points. I'll leave this topic open so that members can post in here if this happens again in the future. Mazer Rackham 1 Back to top Link to comment https://bolterandchainsword.com/topic/386529-something-weird-going-on-with-ranks/#findComment-6131705 Share on other sites More sharing options...
mini_painting_mike Posted 12 hours ago Share Posted 12 hours ago Hi! As per the previous observations in this thread, unfortunately when I created a club today on the forum (Bunker Bingo Challenge, go check it out ) it knocked my rank straight back down to Aspirant. Is this something that can be fixed, @Brother Tyler? Link to comment https://bolterandchainsword.com/topic/386529-something-weird-going-on-with-ranks/#findComment-6148672 Share on other sites More sharing options...
Brother Tyler Posted 7 hours ago Author Share Posted 7 hours ago 4 hours ago, mini_painting_mike said: Hi! As per the previous observations in this thread, unfortunately when I created a club today on the forum (Bunker Bingo Challenge, go check it out ) it knocked my rank straight back down to Aspirant. Is this something that can be fixed, @Brother Tyler? Fixed mini_painting_mike 1 Back to top Link to comment https://bolterandchainsword.com/topic/386529-something-weird-going-on-with-ranks/#findComment-6148718 Share on other sites More sharing options...
mini_painting_mike Posted 30 minutes ago Share Posted 30 minutes ago 7 hours ago, Brother Tyler said: Fixed Thanks so much! Link to comment https://bolterandchainsword.com/topic/386529-something-weird-going-on-with-ranks/#findComment-6148741 Share on other sites More sharing options...
