LameBeard Posted August 19, 2025 Share Posted August 19, 2025 I have some figures that I wanted to base bigger than 25mm and smaller than 32mm, and obtained some 28mm ish bases. I also obtained a few Kroot bits. i saw that according to the website, Kroot Farstalkers are on 28.5mm except one is on 32mm and one is on 28mm. What the heck is going on there - one model is on a very marginally smaller base? Which one? Or is this a typo on the GW site? But the main question is, for official GW bases, are there genuinely both 28mm and 28.5mm, can you tell the difference in person, and which models tend to come with which, if there is a rule of thumb? Link to comment https://bolterandchainsword.com/topic/386541-gw-base-size-question-kroot-example/ Share on other sites More sharing options...
Brother Anderson Posted August 19, 2025 Share Posted August 19, 2025 To be honest I struggle to tell the difference between 28.5mm and 25mm, so if there is one that's 28 I don't think anyone could tell the difference even if you told them! LameBeard and Grotsmasha 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/386541-gw-base-size-question-kroot-example/#findComment-6128706 Share on other sites More sharing options...
Solution Dr_Ruminahui Posted September 4, 2025 Solution Share Posted September 4, 2025 The wierd base size for the Kroot Farstalkers are indeed a thing, as the issue has come up elsewhere on the interner. Looking at the Kroot Farstalker instructions sheets, it looks like the 28mm is for one of the kroothounds - though why the marginally smaller base, and why only one of the hounds, remain mysteries. LameBeard 1 Back to top Link to comment https://bolterandchainsword.com/topic/386541-gw-base-size-question-kroot-example/#findComment-6130851 Share on other sites More sharing options...
kabaakaba Posted September 4, 2025 Share Posted September 4, 2025 Thats GW base size magic like IG models all same size go from 25 to 32, Link to comment https://bolterandchainsword.com/topic/386541-gw-base-size-question-kroot-example/#findComment-6130869 Share on other sites More sharing options...
LameBeard Posted September 4, 2025 Author Share Posted September 4, 2025 7 hours ago, Dr_Ruminahui said: The wierd base size for the Kroot Farstalkers are indeed a thing, as the issue has come up elsewhere on the interner. Looking at the Kroot Farstalker instructions sheets, it looks like the 28mm is for one of the kroothounds - though why the marginally smaller base, and why only one of the hounds, remain mysteries. So the 32mm is for the leader then? Link to comment https://bolterandchainsword.com/topic/386541-gw-base-size-question-kroot-example/#findComment-6130897 Share on other sites More sharing options...
Dr_Ruminahui Posted September 4, 2025 Share Posted September 4, 2025 (edited) According to the instruction, yes - if you look at his instructions, there is a little "32mm" in a small gray circle next to the base. Edited September 4, 2025 by Dr_Ruminahui LameBeard 1 Back to top Link to comment https://bolterandchainsword.com/topic/386541-gw-base-size-question-kroot-example/#findComment-6130922 Share on other sites More sharing options...
Evil Eye Posted September 5, 2025 Share Posted September 5, 2025 On 8/19/2025 at 5:28 PM, LameBeard said: But the main question is, for official GW bases, are there genuinely both 28mm and 28.5mm, can you tell the difference in person, and which models tend to come with which, if there is a rule of thumb? For a difference that small, you're only going to notice if you directly compare the bases against each other. It won't be visually noticable and it certainly won't make any difference whatsoever in game. Though to be honest base sizes fluctuate so much between model updates these days (and don't actually make really any impact on the game unless you do something ridiculous like put your Hormagaunts on 60mms) that I wouldn't worry too much anyway. It is a very strange decision to be sure, though- 28.5mm for a single model doesn't make a lot of sense. At least a 32mm for the leader gives a bit of an instant visual cue as to his status. LameBeard 1 Back to top Link to comment https://bolterandchainsword.com/topic/386541-gw-base-size-question-kroot-example/#findComment-6131072 Share on other sites More sharing options...
