Deus_Ex_Machina Posted August 30 Share Posted August 30 As the title says. Link to comment https://bolterandchainsword.com/topic/386614-does-any-company-have-an-alternative-for-boarding-action-walls-andor-floor-tiles-from-gw/ Share on other sites More sharing options...
ThePenitentOne Posted September 1 Share Posted September 1 What I would do if I wanted to play cheap is build my own- you can cut out pieces of thick corrugated cardboard that are the same size as the walls and have "hatches" in the same locations. You'll need to glue layers of corrugated cardboard together to get them to stand up on their own- if the cardboard is double thickness like the stuff refrigerator boxes are made of, three layers will be enough, but if it's the more common thinner cardboard, you might need more.You can add detaillng made from thinner, uncorrugated cereal box cardboard and pipes made from drinking straws of various thickness (McDonald's straws are fat, Taco Bell are skinnier and elbow straws are the bomb if you can find them).For hatches, what I do is cut hatch-shaped holes in the outer layers, and then leave a blank rectangular cut out wider than the hatch-hole in one of the inner layers. Then you can slide a cardboard rectangle into that cut-away to close the door, and pull it back out to open it again. As a bonus, this means you don't have to ever worry about moving models to accommodate the swing of an opening hatch, because the doors just pull straight up.It sounds cheap, and it is. Most of the stuff you need to build it, you can accumulate for free over three months or so... Faster if you go looking for empty boxes from retailers- many places will give away their boxes if you ask. You can also buy boxes for moving and stuff- the advantage there is that it's all exactly the same thickness and you can get it all at once... But the disadvantage is that it isn't free.There's another design for 3d boards that involves putting thick, identical squares on the floor of the board with gaps between them that you can shove a layer of cardboard into- the squares on the floor will hold the wall upright even if it's too thin to stand on its own. In this method, you put a lot of time into the floor, but once it's done, you can cut more walls than you'll ever need in a single day, because they only have to be one layer thick, unless they include sliding hatches as described above. When I built my first 3d Space Hulk board in the late 90's this is the method I used. On door walls, for the outer layers, I used cereal box cardboard because I didn't need extra thickness to help the wall stand. This allows the door walls to be almost the same thickness as the single layer walls without doors. Just remember that you don't want to add any cereal box detailing to the part of the wall that has to fit into the floor groove.If you're using official printed missions, you need to cut your walls to match the commercial stuff, and/ or make sure that your floor grooves are placed in such a way that they allow to build all of the board layouts you want to create. But honestly? If you build your own board pieces, it's really easy to write your own missions. You have the freedom to make whatever size and shape of boards you want.That Space Hulk Board I built in the 90's? It was awesome- I divided it into 2'x2' sections. Each section had 10x10 2.25" sections with roughly 1-2mm gaps between them. I built 8 such tiles, and for most games we used 6 of them, which allowed us to build a 4'x6' board. But what's cool is that we didn't HAVE to lay them out that way- one time we used 4 tiles to build a 4'x4' square, and then we placed the other floor tiles in a long corridor leading to it. We also built L-shaped boards and all kinds of cool weird layouts. I wish I still had the board because I could post a Youtube video, but I left it at the Youth Center I was working at because the members of the gaming club at the center helped build it. Sadly, we didn't document the process of it's creation or any of the games played on it, because back in the 90's, internet and scial media were nowhere near as ubiquitous as they are now. Brother Tyler, bloodhound23, Antarius and 2 others 3 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/386614-does-any-company-have-an-alternative-for-boarding-action-walls-andor-floor-tiles-from-gw/#findComment-6130495 Share on other sites More sharing options...
No Foes Remain Posted September 2 Share Posted September 2 Battle Systems does some sets, both space station and city ones for either kill team or Necromunda. I still need to build my set that I got from their kickstarter many years ago.... Deus_Ex_Machina 1 Back to top Link to comment https://bolterandchainsword.com/topic/386614-does-any-company-have-an-alternative-for-boarding-action-walls-andor-floor-tiles-from-gw/#findComment-6130675 Share on other sites More sharing options...
Brother Tyler Posted September 2 Share Posted September 2 Cardboard provides the cheapest option for DIY. Two other options you can consider are wood (especially balsa) and plasticard. You can often find relatively cheap wood options at hobby stores. Plasticard is the most expensive option, but there are a variety of thickness and texture options available if you want to liven things up a bit. Plasticard is also the best option in terms of painting and quality (offset by the cost and work involved, of course). Some retailers of plasticard include Litko and Evergreen Scale Models. More expensive options are available from some retailers. Death Ray Designs, for example, has the Deadbolt's Derelict and Navis Mortim terrain sets. These are both MDF terrain sets. I don't think that either comes with floor tiles, however. Deus_Ex_Machina 1 Back to top Link to comment https://bolterandchainsword.com/topic/386614-does-any-company-have-an-alternative-for-boarding-action-walls-andor-floor-tiles-from-gw/#findComment-6130676 Share on other sites More sharing options...
No Foes Remain Posted September 2 Share Posted September 2 Speaking of MDF, I'm pretty sure TT Combat does some zone mortalis ones as well now that I think about it. Deus_Ex_Machina 1 Back to top Link to comment https://bolterandchainsword.com/topic/386614-does-any-company-have-an-alternative-for-boarding-action-walls-andor-floor-tiles-from-gw/#findComment-6130678 Share on other sites More sharing options...
MARK0SIAN Posted September 2 Share Posted September 2 (edited) 2 hours ago, No Foes Remain said: Speaking of MDF, I'm pretty sure TT Combat does some zone mortalis ones as well now that I think about it. It does indeed and I can heartily recommend it. The value for money compared to GW stuff is insane! This is my set: Edited September 2 by MARK0SIAN No Foes Remain, Gorgoff, Brother Tyler and 3 others 3 1 2 Back to top Link to comment https://bolterandchainsword.com/topic/386614-does-any-company-have-an-alternative-for-boarding-action-walls-andor-floor-tiles-from-gw/#findComment-6130703 Share on other sites More sharing options...
Helbrechts_Sword_Servitor Posted October 8 Share Posted October 8 Apart from the pre-painted MDF (which is the best option in my opinion), there's loads of STL files to make a printed board. For instance: Facility tiles - 3D wargaming terrain・ STL File for 3D printing・Cults A friend printed some for me, and I've been painting them. The red doors actualy slide up. Link to comment https://bolterandchainsword.com/topic/386614-does-any-company-have-an-alternative-for-boarding-action-walls-andor-floor-tiles-from-gw/#findComment-6135610 Share on other sites More sharing options...
Uprising Posted October 9 Share Posted October 9 On 9/2/2025 at 1:16 PM, MARK0SIAN said: It does indeed and I can heartily recommend it. The value for money compared to GW stuff is insane! This is my set: These look great. Do you have a link to the product? I check out the site and can not find it sadly. Link to comment https://bolterandchainsword.com/topic/386614-does-any-company-have-an-alternative-for-boarding-action-walls-andor-floor-tiles-from-gw/#findComment-6135725 Share on other sites More sharing options...
DanPesci Posted October 9 Share Posted October 9 36 minutes ago, Uprising said: These look great. Do you have a link to the product? I check out the site and can not find it sadly. If you go to the TT Scenics section of the menu, then the Industrial Hive category, the various 'iron laybrinth' bits are on page 2: https://ttcombat.com/collections/industrial-hive?page=2 +1 recommendation for the TT Combat stuff, I have a load of the gothic cathedral stuff (obvs not relevant to this thread but great regardless) Uprising 1 Back to top Link to comment https://bolterandchainsword.com/topic/386614-does-any-company-have-an-alternative-for-boarding-action-walls-andor-floor-tiles-from-gw/#findComment-6135741 Share on other sites More sharing options...
MARK0SIAN Posted October 9 Share Posted October 9 6 hours ago, Uprising said: These look great. Do you have a link to the product? I check out the site and can not find it sadly. This is the specific set in the pictures I posted: https://ttcombat.com/products/iron-labyrinth-bundle?srsltid=AfmBOorg4HzX1V9QJAPyaUf5eub3sgVeEMB27pJu-K3Ejj9dbV_7W3AH But they do lots of other compatible sets too. The only thing to be wary of is some of the bits which are painted white on the store pictures (the various pipes) are actually cardboard, not mdf so they’re quite flimsy. However I just replaced them with some cuts of thick dowel and it worked fine. Uprising 1 Back to top Link to comment https://bolterandchainsword.com/topic/386614-does-any-company-have-an-alternative-for-boarding-action-walls-andor-floor-tiles-from-gw/#findComment-6135907 Share on other sites More sharing options...
Magos Takatus Posted October 10 Share Posted October 10 If you have access to a 3d printer then Saucermen Studios do several modular terrain sets. The one I purchased for my own use, their DarkHyve Assault set is stackable for Necromunda-style scenery but the walls, junctions and doors would probably work fairly well for Boarding actions. https://saucermenstudios.com.au/product-tag/darkhyve-assault Though I stacked them up into a large building and some flat buildings with platforms on top, you can probably see their potential. I've got so much scenery to paint now. lol Link to comment https://bolterandchainsword.com/topic/386614-does-any-company-have-an-alternative-for-boarding-action-walls-andor-floor-tiles-from-gw/#findComment-6136026 Share on other sites More sharing options...
