Deus_Ex_Machina Posted September 1, 2025 Share Posted September 1, 2025 I need a space ship interior for my future Shattered Legions 500 pts. force. At first there was the notion of buying the boarding action box from GW although later in the decision making process structural rollers came up to create sci-fi designs on the walls and/or floor tiles. So here is now my question to all of you who have used such implements: How good are they? And what is the preferred material to work with to achieve the best results? Link to comment https://bolterandchainsword.com/topic/386621-your-experience-with-structural-rollers/ Share on other sites More sharing options...
Solution LameBeard Posted September 1, 2025 Solution Share Posted September 1, 2025 33 minutes ago, Deus_Ex_Machina said: I need a space ship interior for my future Shattered Legions 500 pts. force. At first there was the notion of buying the boarding action box from GW although later in the decision making process structural rollers came up to create sci-fi designs on the walls and/or floor tiles. So here is now my question to all of you who have used such implements: How good are they? And what is the preferred material to work with to achieve the best results? Do you mean like the Green Stuff World rolling pins? With the special rings to create an even thickness, textured surface on some kind of putty? Might be worth asking in the modelling section. Deus_Ex_Machina 1 Back to top Link to comment https://bolterandchainsword.com/topic/386621-your-experience-with-structural-rollers/#findComment-6130558 Share on other sites More sharing options...
Deus_Ex_Machina Posted September 1, 2025 Author Share Posted September 1, 2025 12 minutes ago, LameBeard said: Do you mean like the Green Stuff World rolling pins? With the special rings to create an even thickness, textured surface on some kind of putty? Might be worth asking in the modelling section. Yes. Maybe a mod could replace the thread. Link to comment https://bolterandchainsword.com/topic/386621-your-experience-with-structural-rollers/#findComment-6130562 Share on other sites More sharing options...
Deus_Ex_Machina Posted September 1, 2025 Author Share Posted September 1, 2025 I watched a video of a guy using a Green Stuff World structure roller on styrofoam. You need to press hard and roll it once across the surface material. The problem is that during your roll your application of force may vary as you are not a machine. This will result in a surface which is uneven. Link to comment https://bolterandchainsword.com/topic/386621-your-experience-with-structural-rollers/#findComment-6130570 Share on other sites More sharing options...
LameBeard Posted September 2, 2025 Share Posted September 2, 2025 Yeah hence the rings - push hard and they stop you pushing harder: But that would might for something like miliput, not expanded polystyrene. Link to comment https://bolterandchainsword.com/topic/386621-your-experience-with-structural-rollers/#findComment-6130672 Share on other sites More sharing options...
