Helbrechts_Sword_Servitor Posted September 2, 2025 Share Posted September 2, 2025 The Detachment rule for Godhammer is: Shock and Awe: ■ Each time an ADEPTUS ASTARTES unit from your army declares a charge, if it disembarked from a TRANSPORT this turn, after selecting the targets of that charge, select one of those targets; that enemy unit must take a Battle-shock test. The rule for assault terminators is: Terminatus Assault: Each time this unit ends a Charge move, each enemy unit within Engagement Range of this unit must take a Battle-shock test. Does this mean that I can force two battleshock tests? Link to comment https://bolterandchainsword.com/topic/386627-godhammer-shock-and-awe-assault-terminators-two-battleshocks/ Share on other sites More sharing options...
DemonGSides Posted September 3, 2025 Share Posted September 3, 2025 Yes. There's no over arching rule preventing multiple battle-shock tests, just specific rules that might mention not making extra tests. The outcomes from either do not effect the other; one failure between the two, regardless of order, still results in battle-shock. They'd have to succeed twice to not become battle-shocked. Dr_Ruminahui 1 Back to top Link to comment https://bolterandchainsword.com/topic/386627-godhammer-shock-and-awe-assault-terminators-two-battleshocks/#findComment-6130796 Share on other sites More sharing options...
kabaakaba Posted September 3, 2025 Share Posted September 3, 2025 This two tests are in different parts of charge phase, first on declare charge if disembarked and the second after end of charge move. no problem Link to comment https://bolterandchainsword.com/topic/386627-godhammer-shock-and-awe-assault-terminators-two-battleshocks/#findComment-6130798 Share on other sites More sharing options...
Helbrechts_Sword_Servitor Posted September 5, 2025 Author Share Posted September 5, 2025 Thanks, that's what I thought. I'm trying to see the interactions between the first battleshock and the Fire Overwatch strat. What goes first? The Shock and Awe, or the Overwatch after I disembarked? I think it's the Fire Overwatch, which is a bummer. Link to comment https://bolterandchainsword.com/topic/386627-godhammer-shock-and-awe-assault-terminators-two-battleshocks/#findComment-6131040 Share on other sites More sharing options...
