JeffJedi Posted September 9, 2025 Share Posted September 9, 2025 (edited) So there are 8 silver paints in the main range some base and some layer and one Dray paint. Online and in WD you will find by far the most common usage is Leadbealcher with Nuln Oil wash and a Stormhost Silver highlight. When and where do you find use for the other silvers? Stormhost Silver Ironbreaker Rungfang Steel Leadbealcher Necron Compound Iron Hands Steel Iron Warriors Grey Knights Do you use unusual washes to enhance the colors? Do you make mixes? Edited September 9, 2025 by JeffJedi Link to comment https://bolterandchainsword.com/topic/386662-games-workshops-silver-paints-and-their-usages/ Share on other sites More sharing options...
Madao Posted September 9, 2025 Share Posted September 9, 2025 (edited) Just don't bother with GW and buy Gunmetal and Steel (air variants) from Vallejo, they are way better to work with (and mix them to get midtones) I am using necron compound though, it is nice for bringing the shine back from dark metal Edited September 9, 2025 by Madao JeffJedi 1 Back to top Link to comment https://bolterandchainsword.com/topic/386662-games-workshops-silver-paints-and-their-usages/#findComment-6131555 Share on other sites More sharing options...
Sky Potato Posted September 9, 2025 Share Posted September 9, 2025 This is how I use each of the colours Stormhost Silver - highlighting the cutting edge of blades. I want to try edge highlighting silver surfaces before applying contrast or clear paints, I think I’ll use stormhost for that. Ironbreaker - as a basecoat on Necrons before applying an all over coat of Basilicanum Grey contrast. Also as a general light highlight on stuff like chainmail once it’s been nuln oil washed. Finally, as a base for silver as decorative patterns on armour Runefang Steel - I only really use this if I can’t find my Stormhost when I look for it Leadbealcher - general “working” metal - chainmail, exhaust pipes, the vents of marine power packs. That sort of thing. Wash with nuln, light brush over with Ironbreaker. Necron Compound - drybrush over black for a bit of variation. I also think this is Runefang Steel pigment, but in a different medium for drybrushing. Iron Hands Steel - the metal on weapons - gun barrels, swords, chainsword teeth and the like. Again, washed with Nuln, and then cutting surfaces touched up with Stormhost Iron Warriors - Mainly as a dark silver for decoration and armour trim - I do my 30k Night Lords armour trim in iron warriors for example. I also drybrush this over black for tank tracks. Grey Knights - use it on my Knights for the armour panels. Corvus Black or Macragge Blue panels, with a Grey Knights trim. I wash this with Drakenhof Nightshade before relayering with Grey Knights then a light touch up of Ironbreaker. Firedrake Cordova and JeffJedi 2 Back to top Link to comment https://bolterandchainsword.com/topic/386662-games-workshops-silver-paints-and-their-usages/#findComment-6131572 Share on other sites More sharing options...
Firedrake Cordova Posted September 10, 2025 Share Posted September 10, 2025 I think that the large array is largely for differing tones and levels of brightness. From what I remember, the progression was originally Leadbelcher -> Ironbreaker -> Runefang Steel, and then GW added Stormhost Silver as a brighter option. Subsequently, Iron Warriors (darker than Leadbelcher), Grey Knights Steel (bluish), and Iron Hands Steel (brownish tone) got introduced. You almost certainly don't need all of them, and some can be made by mixing others with inks (or Contrast/Shade). Vallejo has a similarly baffling large number of "silvers" in it's Metal Color line. From what I remember, the metallics with a hard white cap on them are a different formulation to the others (and are more expensive). JeffJedi 1 Back to top Link to comment https://bolterandchainsword.com/topic/386662-games-workshops-silver-paints-and-their-usages/#findComment-6131594 Share on other sites More sharing options...
Cleon Posted September 10, 2025 Share Posted September 10, 2025 So personally it depends what I'm painting. I hate blending/mixing metallics so have a few different set ups. If it's mechanical gubbins then I'll usually start with Iron Warriors, then depending on the texture give it a shade/filter with Nuln or Basilicum grey and use Iron Hands Steel as a highlight. If it's steel plate, or a more well presented metal I'll base in Leadbelcher, use Runefang or Runefang as my standard highlight depending which silver I want and go up to Stormhost silver for blade edges, ornamental silver and lenses. Grey Knights Steel I find is too blue for general purpose, and rarely have a use for outside of my nemesis force weapons, Necron Compound I used once and will never touch the drys again. Also I use the two thin coats triad (sir Coates, Plate Armour and Mithril Blade) but I rarely bother with the mithril as they are quite bright anyway, but I wouldn't use them on anything bigger than a small infantry armour plate as they are finnicky in getting a good coverage and prone to going bitty, JeffJedi and Firedrake Cordova 2 Back to top Link to comment https://bolterandchainsword.com/topic/386662-games-workshops-silver-paints-and-their-usages/#findComment-6131665 Share on other sites More sharing options...
ggergnayr Posted October 1, 2025 Share Posted October 1, 2025 Like most folks, Leadbelcher and a nuln oil wash for hard working metal, gun barrels etc. I use Stormhost primarily as a base for contrast or oil wash colored metallics. Link to comment https://bolterandchainsword.com/topic/386662-games-workshops-silver-paints-and-their-usages/#findComment-6134511 Share on other sites More sharing options...
sitnam Posted October 1, 2025 Share Posted October 1, 2025 I pretty much have stuck with Iron Hands steel for my base layer silver, with stormhost silver as a bright highlight for armor and such. It is a fair bit brighter then leadbelcher, but I think it takes to shades/contrasts super well. I've tried some TTC silver (cant remember the exact paint, not at home) but I dont remember being super impressed. I just havent found a need for other silvers, and it works well enough for me. I particularly like it with some of the new shades, such as Tyran blue Link to comment https://bolterandchainsword.com/topic/386662-games-workshops-silver-paints-and-their-usages/#findComment-6134534 Share on other sites More sharing options...
