Token Posted September 13, 2025 Share Posted September 13, 2025 Anyone tried having Ratlings in a Taurox, with the mechanised detatchment? Zooming about, popping out and firing? Maybe retreating if someone gets to close? Would their ability, to move after firing, let them enter the transport again, or would you need a stratagem for that? With charaters being so good at boosting, taking them out should be good. They will still hit on 3s and wound regular marines on 3+, becaurse of the boost from exiting a transport and firing? They cannot get orders in any way? So no + to hit? In some earlier editions, Ratlings took up two spaces each, in a transport, but I have not seen this in this edition? Lots of questions, thought it could be fun. Link to comment https://bolterandchainsword.com/topic/386678-ratlings-in-a-taurox/ Share on other sites More sharing options...
sairence Posted September 14, 2025 Share Posted September 14, 2025 On 9/13/2025 at 11:56 AM, Token said: Would their ability, to move after firing, let them enter the transport again, or would you need a stratagem for that? I tries it a few times, and it's certaibly cute. A bit too expensive to really be great, especially with the Taurox having gotten more expensive. To answer your question, yes, they can get back in with their ability as long as all models are within 3". it's a different phase to when they disembarked, so no issues. Main problem is that 10 sniper shots are only semi-reliable. 10 shots on 3+ = 7.3 hits Wounding on 3+= 4.5ish wounds Without cover saving on 5s = 3 wounds, so 6 damage So in mech, they can on average take out a basic marine character in the open. Gets a bit better if you pop their once per game lethals, but much worse if there's cover, higher toughness or you run them in another detach. And that costs you 175p to pull off, while being very vulnerable to overwatch. Don't get me wrong, it's fun, and I've yet to play into an opponent who didn't on some level want the little murderhobos to suceed. But not quite a magic bullet either. :) Deus_Ex_Machina 1 Back to top Link to comment https://bolterandchainsword.com/topic/386678-ratlings-in-a-taurox/#findComment-6131979 Share on other sites More sharing options...
Token Posted September 15, 2025 Author Share Posted September 15, 2025 Ah, math shows its not that good then. I like mechanised becaurse it seems fun, popping out and firing and moving about alot. Not sure how effective it actually is. But having them getting in a transport again, with their ability, sounds cool. Link to comment https://bolterandchainsword.com/topic/386678-ratlings-in-a-taurox/#findComment-6132252 Share on other sites More sharing options...
