MoriyaSchism Posted September 14, 2025 Share Posted September 14, 2025 (edited) I ran into a bit of a hurdle with my conversions so I'm looking for a way to expedite the making of cabling on power armour. Are there any companies that sell flexible cabling I can use to replicate the style of cables you see on Mark 5, 6 and 7 power armour? It doesn't have to be cable either, a custom green stuff press mold or roller for ribbed piping would be good too. I'm trying to recreate this style of cable. Any help would be greatly appreciated. Edited September 14, 2025 by MoriyaSchism Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/386684-looking-for-a-solution-for-power-armour-pipes-and-cables/ Share on other sites More sharing options...
Solution Grotsmasha Posted September 14, 2025 Solution Share Posted September 14, 2025 (edited) I think it's either / both Zinge Industries and Greenstuff World sell greenstuff rollers for cable making. I think you could get very close by rolling a cable and after letting it sit a little, flatten it into a rectangular shape vs. a round one. EDIT: Flexible Resin Cables from Zinge Cablle Rollers from Greenstuff World Edited September 14, 2025 by Grotsmasha Firedrake Cordova and MoriyaSchism 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/386684-looking-for-a-solution-for-power-armour-pipes-and-cables/#findComment-6132168 Share on other sites More sharing options...
Karhedron Posted September 15, 2025 Share Posted September 15, 2025 Guitar wire might work best. MoriyaSchism 1 Back to top Link to comment https://bolterandchainsword.com/topic/386684-looking-for-a-solution-for-power-armour-pipes-and-cables/#findComment-6132175 Share on other sites More sharing options...
MoriyaSchism Posted September 15, 2025 Author Share Posted September 15, 2025 14 hours ago, Grotsmasha said: I think it's either / both Zinge Industries and Greenstuff World sell greenstuff rollers for cable making. I think you could get very close by rolling a cable and after letting it sit a little, flatten it into a rectangular shape vs. a round one. EDIT: Flexible Resin Cables from Zinge Cablle Rollers from Greenstuff World Yeah, that should work. I will try both. Thanks. 12 hours ago, Karhedron said: Guitar wire might work best. It seems Zinge Industries sells something similar. Thanks for the suggestion. Link to comment https://bolterandchainsword.com/topic/386684-looking-for-a-solution-for-power-armour-pipes-and-cables/#findComment-6132300 Share on other sites More sharing options...
Firedrake Cordova Posted September 15, 2025 Share Posted September 15, 2025 18 hours ago, Karhedron said: Guitar wire might work best. At the very least, it might be possible to use one of the wound strings to create a greenstuff mould (as greenstuff may be easier to work with). Link to comment https://bolterandchainsword.com/topic/386684-looking-for-a-solution-for-power-armour-pipes-and-cables/#findComment-6132386 Share on other sites More sharing options...
Bung Posted September 26, 2025 Share Posted September 26, 2025 On 9/14/2025 at 8:09 PM, MoriyaSchism said: I ran into a bit of a hurdle with my conversions so I'm looking for a way to expedite the making of cabling on power armour. Are there any companies that sell flexible cabling I can use to replicate the style of cables you see on Mark 5, 6 and 7 power armour? It doesn't have to be cable either, a custom green stuff press mold or roller for ribbed piping would be good too. I'm trying to recreate this style of cable. Any help would be greatly appreciated. The easiest and most available solution are small zip ties. I used them to replicate the cabling on the legs for MK V Marines. Flexible and you can use plastic glue. Firedrake Cordova, Grotsmasha, Felix Antipodes and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/386684-looking-for-a-solution-for-power-armour-pipes-and-cables/#findComment-6133858 Share on other sites More sharing options...
Grotsmasha Posted September 26, 2025 Share Posted September 26, 2025 37 minutes ago, Bung said: The easiest and most available solution are small zip ties. I used them to replicate the cabling on the legs for MK V Marines. Flexible and you can use plastic glue. That's ingenius, thanks for sharing Link to comment https://bolterandchainsword.com/topic/386684-looking-for-a-solution-for-power-armour-pipes-and-cables/#findComment-6133860 Share on other sites More sharing options...
MoriyaSchism Posted September 26, 2025 Author Share Posted September 26, 2025 2 hours ago, Bung said: The easiest and most available solution are small zip ties. I used them to replicate the cabling on the legs for MK V Marines. Flexible and you can use plastic glue. That sounds interesting too. Might try that too. Link to comment https://bolterandchainsword.com/topic/386684-looking-for-a-solution-for-power-armour-pipes-and-cables/#findComment-6133876 Share on other sites More sharing options...
jokaero weaponsmith Posted September 29, 2025 Share Posted September 29, 2025 You can use green stuff and a fine toothed comb. Roll out tubes of green stuff between sheets of hard plastic to desired thickness then roll tubes between plastic and comb to create the cabling. Using green stuff and pressing the cable tie to make the rib detailing on the mark five is less fiddly than the cable tie it’s self Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/386684-looking-for-a-solution-for-power-armour-pipes-and-cables/#findComment-6134128 Share on other sites More sharing options...
