Deus_Ex_Machina Posted September 21, 2025 Share Posted September 21, 2025 I have built three 30K rhinos for the Call to Arms event this year. Overall they were easier to put together than their predecessors but there is still room for improvement. For instance why aren´t there grooves for EVERY option in the vehicle kit? I am speaking about searchlight, hunter-killer missile, smoke launcher and bulldozer blade? There are only two hard points and that´s that. Not good enough for a kit which originated from the 80s. In comparison there is no ambiguity in putting vehicles together in Legions Imperialis. So GW can do it, if they wanted to. Link to comment https://bolterandchainsword.com/topic/386740-not-enough-grooves-on-imperial-vehicle-kits/ Share on other sites More sharing options...
Sky Potato Posted September 21, 2025 Share Posted September 21, 2025 I’d imagine because they’re optional, and they don’t want to leave those mounting points visible if people don’t build the kits with all the options fitted. Toxichobbit, CL_Mission, Antarius and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/386740-not-enough-grooves-on-imperial-vehicle-kits/#findComment-6133122 Share on other sites More sharing options...
NovemberIX Posted September 21, 2025 Share Posted September 21, 2025 Oppositely, I wish there weren't grooves on the 30K Rhino for the headlights. One of the things I did when I built my resin ones was not add the lights because I didn't like the placement, but the new plastic kits have that indent on the armor. An indent for the dozer blade or tow hooks isn't too bad, but I figure that has more to do with sprue design than anything. Link to comment https://bolterandchainsword.com/topic/386740-not-enough-grooves-on-imperial-vehicle-kits/#findComment-6133143 Share on other sites More sharing options...
Xenith Posted September 28, 2025 Share Posted September 28, 2025 What do you mean by grooves? I'm confused between that and mounting points. Do you mean cupolas, or the nubbins like on the 40k rhino and predator ? Link to comment https://bolterandchainsword.com/topic/386740-not-enough-grooves-on-imperial-vehicle-kits/#findComment-6134093 Share on other sites More sharing options...
Magos Takatus Posted October 2, 2025 Share Posted October 2, 2025 Now that I've got that out of my system, perhaps it's because the original Rhino kit was supposed to be modular and you could attach things pretty much wherever you wanted? Now that we have lore for the Standard Template Constructs, you'd think equipment mounting would be more, y'know, standardised? Having put together some models recently where the location of the pieces is very ambiguous, I miss having definite mounting pegs and grooves in models. I assembled that Warcry team with the weird bestial vampires and one of them had a damn crater I had to fill because the parts just did not want to fit together with any certainty, they just slid against each other. when I mention pegs, however, don't confuse that for GW's "push-fit models", which they seem to interpret as "squash the parts together with every ounce of your strength and pray you don't crush every detail on the model in the process-fit models" Link to comment https://bolterandchainsword.com/topic/386740-not-enough-grooves-on-imperial-vehicle-kits/#findComment-6134591 Share on other sites More sharing options...
