Lysimachus Posted September 22, 2025 Share Posted September 22, 2025 (edited) Hello Fraters, A very quick question that I'm hoping someone with the new Logan mini might be able to answer - how tall in mm is his tactical cliff? I will be building a counts-as Grimnar with the new Iron Hand Caanok Var body as a base. From what I can tell, Logan himself isn't massively bigger than a regular (new) Terminator, so Caanok should be ok, but I'm not sure about all the scenic bits? My very loose attempt at eyeballing it says the bottom of Logan's feet are maybe(?) 25-30mm above the top of the base, but I'd like to be sure... Thanks in advance for any help anyone can give! Edited September 22, 2025 by Lysimachus Link to comment https://bolterandchainsword.com/topic/386747-height-of-grimnars-tactical-cliff/ Share on other sites More sharing options...
Wispy Posted September 22, 2025 Share Posted September 22, 2025 use minicompare.info, they have rulers https://minicompare.info/?logan-grimnar-2025-terminator-scenic=&logan-grimnar-2025-terminator= Apokalypsi, Harald Fairmane and Lysimachus 1 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/386747-height-of-grimnars-tactical-cliff/#findComment-6133313 Share on other sites More sharing options...
Solution Moonstalker Posted September 23, 2025 Solution Share Posted September 23, 2025 11 hours ago, Lysimachus said: Hello Fraters, A very quick question that I'm hoping someone with the new Logan mini might be able to answer - how tall in mm is his tactical cliff? I will be building a counts-as Grimnar with the new Iron Hand Caanok Var body as a base. From what I can tell, Logan himself isn't massively bigger than a regular (new) Terminator, so Caanok should be ok, but I'm not sure about all the scenic bits? My very loose attempt at eyeballing it says the bottom of Logan's feet are maybe(?) 25-30mm above the top of the base, but I'd like to be sure... Thanks in advance for any help anyone can give! Measured using my calipers. 23mm to the highest point of the rock, 20mm is about the height of the rock for his back foot. Hard to get a better reading than that with the wolf in the way. Lysimachus 1 Back to top Link to comment https://bolterandchainsword.com/topic/386747-height-of-grimnars-tactical-cliff/#findComment-6133338 Share on other sites More sharing options...
Lysimachus Posted September 23, 2025 Author Share Posted September 23, 2025 Exactly what I needed, thank you @Moonstalker! Link to comment https://bolterandchainsword.com/topic/386747-height-of-grimnars-tactical-cliff/#findComment-6133347 Share on other sites More sharing options...
