jimbo1701 Posted October 19, 2025 Share Posted October 19, 2025 Hi all. I’m constructing some heresy models to proxy as 40K. Some things are pretty easy to do direct swaps for but others less so. I went to look for the points values for the heresy models on the community site and since they’ve been reorganized into faction packs am struggling to find them. Also, does anyone know if the saturnine stuff got 40K rules at any point as I couldn’t see this anywhere. (Presuming a no) thanks in advance. Link to comment https://bolterandchainsword.com/topic/386946-using-heresy-minis-as-proxys-in-40k/ Share on other sites More sharing options...
Solution NTaW Posted October 19, 2025 Solution Share Posted October 19, 2025 Points values are all in the Munitorum Field Manual, with Legends entries at the end of the document. The faction packs have the Datasheets for all Legends units at the end as well, the Space Marine one has most/all the Heresy-era stuff. Here's a link to the WC site for ease of access: https://www.warhammer-community.com/en-gb/downloads/warhammer-40000/ jimbo1701 1 Back to top Link to comment https://bolterandchainsword.com/topic/386946-using-heresy-minis-as-proxys-in-40k/#findComment-6137430 Share on other sites More sharing options...
jimbo1701 Posted October 19, 2025 Author Share Posted October 19, 2025 2 hours ago, NTaW said: Points values are all in the Munitorum Field Manual, with Legends entries at the end of the document. The faction packs have the Datasheets for all Legends units at the end as well, the Space Marine one has most/all the Heresy-era stuff. Here's a link to the WC site for ease of access: https://www.warhammer-community.com/en-gb/downloads/warhammer-40000/ Thanks for that. Found the points values now they’re just a bit jumbled up. Seems the saturnine stuff doesn’t have 40K rules still which is a shame. NTaW 1 Back to top Link to comment https://bolterandchainsword.com/topic/386946-using-heresy-minis-as-proxys-in-40k/#findComment-6137454 Share on other sites More sharing options...
Craig Posted October 20, 2025 Share Posted October 20, 2025 15 hours ago, jimbo1701 said: Also, does anyone know if the saturnine stuff got 40K rules at any point as I couldn’t see this anywhere. (Presuming a no) thanks in advance. You could be heretical and proxy the Saturnine box for chaos like I am. – 1x Saturnine Praetor - Daemon prince – 1x Centurion in MKII power armour - chaos lord – 1x Saturnine Dreadnought - hellbrute – 6x Saturnine Terminators - obliterators – 40x Legionaries in MKII power armour - legionnaires I got some heavy weapons upgrades to turn one of the legionnaire squads in to 2 havoc squads. There's not far off a 2k army in the box. It's not going to win you any tournaments but if you're proxying anyway I assume you are playing casual games. Karhedron 1 Back to top Link to comment https://bolterandchainsword.com/topic/386946-using-heresy-minis-as-proxys-in-40k/#findComment-6137508 Share on other sites More sharing options...
Doobles57 Posted October 20, 2025 Share Posted October 20, 2025 17 hours ago, jimbo1701 said: Thanks for that. Found the points values now they’re just a bit jumbled up. Seems the saturnine stuff doesn’t have 40K rules still which is a shame. The Saturnine Praetor could be proxied as a Terminator Captain. The Saturnine Termies are actually a similar size to Centurions so that could work depending on weapons. The dread is, however, massive so there's not an obvious parallel if size is an important factor in your proxying. I also don't think there's an obvious entry to use the gun platform for either. Link to comment https://bolterandchainsword.com/topic/386946-using-heresy-minis-as-proxys-in-40k/#findComment-6137552 Share on other sites More sharing options...
sitnam Posted October 21, 2025 Share Posted October 21, 2025 On 10/20/2025 at 2:28 AM, Craig said: – 1x Saturnine Dreadnought - hellbrute . I think a forgefiend, although still smaller, would be a better fit. 23 hours ago, Doobles57 said: The dread is, however, massive so there's not an obvious parallel if size is an important factor in your proxying. I also don't think there's an obvious entry to use the gun platform for either. The Redemptor isn't that much smaller, it could work as long as your not super focused on WYSIWYG. Maybe the gun platform can be a Hammerfall bunker? DemonGSides and Dr. Clock 2 Back to top Link to comment https://bolterandchainsword.com/topic/386946-using-heresy-minis-as-proxys-in-40k/#findComment-6137739 Share on other sites More sharing options...
Dagoth Ur Posted October 21, 2025 Share Posted October 21, 2025 I've been using the Saturnine Dreadnought as a stand-in for Redemptor-chassis dreadnoughts recently and it works fine. The shoulders make it a smidge taller but width is the same as is the base size. Saturnine Terminators work well for centurion/obliterator stand-ins in my experience, and I am using the saturnine praetor as a stand-in for Cannok Var/other TDA characters on 50mm bases. They usually wind up roughly the same height with scenic bases anyways and locally we also aren't that fussed about such things anyways. DemonGSides 1 Back to top Link to comment https://bolterandchainsword.com/topic/386946-using-heresy-minis-as-proxys-in-40k/#findComment-6137769 Share on other sites More sharing options...
Emperor Ming Posted October 21, 2025 Share Posted October 21, 2025 Heresy Brother Tyler 1 Back to top Link to comment https://bolterandchainsword.com/topic/386946-using-heresy-minis-as-proxys-in-40k/#findComment-6137805 Share on other sites More sharing options...
Evil Eye Posted October 21, 2025 Share Posted October 21, 2025 Some models work just fine as straight proxies for existing models; notably, the Proteus (built with hull heavy bolters and the assault ramp) makes a perfectly good 40K Land Raider. Dr_Ruminahui 1 Back to top Link to comment https://bolterandchainsword.com/topic/386946-using-heresy-minis-as-proxys-in-40k/#findComment-6137876 Share on other sites More sharing options...
Dr. Clock Posted October 24, 2025 Share Posted October 24, 2025 On 10/21/2025 at 6:15 PM, Evil Eye said: Proteus 100% - used mine last night for my first Caanok Var terminator spam game, and it's just a really good time. For list building in the app the Brutalis is luckily the same points as both a Leviathan and a Deredeo right now, and I like using both. I just used a Leviathan as a Brutalis last night out of not wanting to look up the Legends sheet... having used the Leviathan all edition, I can report that and they are honestly very similar. Deredeo with las and missiles is likewise probably fine as a Ballistus, though the plasma version I have will continue as a Legends rule-of-cool anti-TEQ piece. Cheers, The Good Doctor. Link to comment https://bolterandchainsword.com/topic/386946-using-heresy-minis-as-proxys-in-40k/#findComment-6138376 Share on other sites More sharing options...
Casual Heresy Posted October 25, 2025 Share Posted October 25, 2025 (edited) My best mate has used heresy Predators, Cataphractii Terminators and a Proteus Land Raider in his 40k Chaos army at a grand tournament at Warhammer World, after clearing it with the events team just in case. If it’s good enough for the literal home of Warhammer, it’s good enough for everywhere else. I think the best plan is always talk to people. Players and tournament organisers who refuse are probably not worth engaging with. As long as nothing is modelled for advantage, and you’re clear on what is what, most normal players will just be happy to see a cool looking army on the other side of the table. Edited October 25, 2025 by Casual Heresy Link to comment https://bolterandchainsword.com/topic/386946-using-heresy-minis-as-proxys-in-40k/#findComment-6138497 Share on other sites More sharing options...
