Grotsmasha Posted October 24, 2025 Share Posted October 24, 2025 (edited) The Rules as they stand are 40mm BUT the newer TDA Captain and Belial are both on 50mm. Should i future proof and do 50mm? If yes, 50mm, should i do this for Voldus too? Edited October 24, 2025 by Grotsmasha Link to comment https://bolterandchainsword.com/topic/386990-q-gk-grand-master-in-tda-40mm-or-50mm-base/ Share on other sites More sharing options...
Solution W.A.Rorie Posted October 24, 2025 Solution Share Posted October 24, 2025 I say yes. The 40mm for characters is just too small. I plan on doing it too mine as well. Grotsmasha 1 Back to top Link to comment https://bolterandchainsword.com/topic/386990-q-gk-grand-master-in-tda-40mm-or-50mm-base/#findComment-6138288 Share on other sites More sharing options...
Grotsmasha Posted October 24, 2025 Author Share Posted October 24, 2025 Having completed the core of the conversions, the TDA GM overhangs a 40mm terribly. Voldus is a little better, but it does look crowded, so I do think I'll be going with the 50mm bases. W.A.Rorie 1 Back to top Link to comment https://bolterandchainsword.com/topic/386990-q-gk-grand-master-in-tda-40mm-or-50mm-base/#findComment-6138304 Share on other sites More sharing options...
Ranulf Posted October 26, 2025 Share Posted October 26, 2025 50mm is the go IMHO. If the range refresh comes in 11th edition, I’d wager the TDA characters will be on 50’s. Grotsmasha and W.A.Rorie 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/386990-q-gk-grand-master-in-tda-40mm-or-50mm-base/#findComment-6138602 Share on other sites More sharing options...
