Lathe Biosas Posted November 14, 2025 Share Posted November 14, 2025 I've been thinking of building a Salamanders Space Marine force, but I fail miserably when painting fire/flames. Any suggestions on alternative paint schemes for all the flame patterns that decorate Vulkan He'stan and his noble pyromaniac friends? Link to comment https://bolterandchainsword.com/topic/387118-any-alternatives-to-painting-traditional-flames/ Share on other sites More sharing options...
Grotsmasha Posted November 15, 2025 Share Posted November 15, 2025 You could try the molten lava look? Underpaint on reds/orange/yellow, and then cover with very dark grey / black irregular blocks Lathe Biosas and Firedrake Cordova 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/387118-any-alternatives-to-painting-traditional-flames/#findComment-6142462 Share on other sites More sharing options...
Madao Posted November 15, 2025 Share Posted November 15, 2025 Have you tried contrast paints? Paint the flame white and use yellow and orange/red contrasts to wet blend the colour OR just drybrush orange on the white and then apply only yellow contrast over the whole flame. While the first option can give you a better looking flames, the second one gives you OSL for free Lathe Biosas and Firedrake Cordova 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/387118-any-alternatives-to-painting-traditional-flames/#findComment-6142473 Share on other sites More sharing options...
Firedrake Cordova Posted November 15, 2025 Share Posted November 15, 2025 (edited) Is this any help? Edited November 15, 2025 by Firedrake Cordova Lathe Biosas 1 Back to top Link to comment https://bolterandchainsword.com/topic/387118-any-alternatives-to-painting-traditional-flames/#findComment-6142499 Share on other sites More sharing options...
Lathe Biosas Posted November 15, 2025 Author Share Posted November 15, 2025 Thanks for the advice. Wet Blending and other advanced techniques are difficult for me. I'm more of a base and wash kinda guy. But I'm trying to get better... Link to comment https://bolterandchainsword.com/topic/387118-any-alternatives-to-painting-traditional-flames/#findComment-6142503 Share on other sites More sharing options...
Madao Posted November 15, 2025 Share Posted November 15, 2025 1 minute ago, Lathe Biosas said: Thanks for the advice. Wet Blending and other advanced techniques are difficult for me. I'm more of a base and wash kinda guy. But I'm trying to get better... Wet blending is easy enough for me to use with contrast paints. Just put a blob of red paint on the top of the fire, quickly rinse and dry the brush, load yellow paint and start painting from the bottom of the flame. Once you get to the red paint, just go on - it will mix with the yellow on your brush. From that point just go back and forth with the brush between these two colours and they will mix nicely and make a proper gradient transition (avoid going into the recesses at that point, as it will darken the spots which should be brightest). You are aiming at something like here: Lathe Biosas, Firedrake Cordova and Valkia the Bloody 1 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/387118-any-alternatives-to-painting-traditional-flames/#findComment-6142506 Share on other sites More sharing options...
Firedrake Cordova Posted November 15, 2025 Share Posted November 15, 2025 1 hour ago, Lathe Biosas said: Wet Blending and other advanced techniques are difficult for me What about dry-brushing? Link to comment https://bolterandchainsword.com/topic/387118-any-alternatives-to-painting-traditional-flames/#findComment-6142511 Share on other sites More sharing options...
Lathe Biosas Posted November 15, 2025 Author Share Posted November 15, 2025 3 hours ago, Firedrake Cordova said: What about dry-brushing? No time like the present to learn. Of all the chapters, why did I have to like the Salamanders? Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/387118-any-alternatives-to-painting-traditional-flames/#findComment-6142523 Share on other sites More sharing options...
Firedrake Cordova Posted November 16, 2025 Share Posted November 16, 2025 (edited) Thankfully, drybrushing is easy to learn - it always used to be looked down upon as a "beginner technique", which is a bit unfair, really. Whilst the Artis Opus brushes are nice, there's other effective options - Army Painter's Masterclass Drybrush set are essentially the same, as are Artify's, but you can also use makeup brushes. GW make "flat" drybrushes which give you the option of using a narrow or broad stroke with the same brush. Or, you can use old and worn out brushes (do not use nice pointy brushes- it will ruin them). The main thing is to make sure that you get enough paint off of the brush, so only a little is deposited on the raised parts. Edited November 16, 2025 by Firedrake Cordova Lathe Biosas and Valkia the Bloody 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/387118-any-alternatives-to-painting-traditional-flames/#findComment-6142553 Share on other sites More sharing options...
LameBeard Posted November 16, 2025 Share Posted November 16, 2025 If you are worried about painting actual flames, I think the solution is: cut them off. I’m always a bit sceptical of modelled smoke/fire/fumes … grumble grumble … we didn’t have them in my day. There is no shame in being a Salamander without a brazier stuck on your jump pack. if you are worried about painting flame markings, then remember, a little goes a long way. Decals may be an option for a big space. Otherwise the trick is to choose a panel that can be black. First paint a sort of rainbow: yellow stripe at the bottom, then orange, then red at the top. Then take your black and paint the negative space between the flames. See the knee pad here (ignore the not very Salamanders green) Firedrake Cordova, Lathe Biosas and Madao 1 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/387118-any-alternatives-to-painting-traditional-flames/#findComment-6142615 Share on other sites More sharing options...
Deus_Ex_Machina Posted November 17, 2025 Share Posted November 17, 2025 On 11/14/2025 at 9:33 PM, Lathe Biosas said: I've been thinking of building a Salamanders Space Marine force, but I fail miserably when painting fire/flames. Any suggestions on alternative paint schemes for all the flame patterns that decorate Vulkan He'stan and his noble pyromaniac friends? It´s just a practice thing. You need to make sure the tip of the flame is not too thick as it will look like a tentacle. After a few attempts you should have figured it out. Here is an example of Bad Moonz flames on my Stompa: https://ibb.co/album/XSxDMh Lathe Biosas 1 Back to top Link to comment https://bolterandchainsword.com/topic/387118-any-alternatives-to-painting-traditional-flames/#findComment-6142766 Share on other sites More sharing options...
