Lathe Biosas Posted December 7, 2025 Share Posted December 7, 2025 These guys were in the Dawn of War boxed set. Odd that the Blood Ravens would get 2 Chaplains, instead of a Librarian. What do you think about them? Gamiel 1 Back to top Link to comment https://bolterandchainsword.com/topic/387234-blood-ravens-special-characters/ Share on other sites More sharing options...
HeadlessCross Posted December 7, 2025 Share Posted December 7, 2025 (edited) Assuming those rules are real... 1. Judiciar is nice. Extra consolidation range is super clutch. Having a 4++ outside melee is also cool. 2. Chaplain is not useful though. While a FNP is nice, charging after falling back is something that can be granted in multiple manners. Ultimately, creating an army around the both of them won't be good, with the Chaplain especially holding it back. You're better off using the generic profiles and grabbing enhancements you feel fit. Edited December 7, 2025 by HeadlessCross Link to comment https://bolterandchainsword.com/topic/387234-blood-ravens-special-characters/#findComment-6145858 Share on other sites More sharing options...
Tacitus Posted December 8, 2025 Share Posted December 8, 2025 Technically the Judiciar isn't a Chaplain hes more like an acolyte or Chaplain in training or some such, I forget the exact fluff. They look like they use default models and get an alternate datasheet, so the first thing you want to do is look at the difference between the default guy, and the Epic Hero guy Judiciar is only a few points more and trades bonus attacks on his sword for extended consolidation space. Consolidation space is going to help everyone in the unit. The Precision big sword is pretty likely to get its bonus, but doesn't really buff the unit. The Chaplain trades a Get-Out-Of-Battleshock-Free card for Fall Back and Charge for a bigger price hike than the Judiciar. And (Power Armor/Normal/whatever) Chaplains aren't very impressive on the tabletop. Terminator Chaplains are better. So the Epic Hero Judiciar is an upgrade that probably justifies the point hike. The Chaplian probably also justifies the point hike, but chaplains in general (barring some other shenanigans) don't justify the base cost. Also remember you can't mix and match He'Stan (or the Salamanders Det you're working on) wtih the Judiciar because of the Faction Keywords. Are there any Blood Raven only Dets in the book too? Link to comment https://bolterandchainsword.com/topic/387234-blood-ravens-special-characters/#findComment-6145863 Share on other sites More sharing options...
Lathe Biosas Posted December 8, 2025 Author Share Posted December 8, 2025 Not that I can find so far, but I'm still looking. Link to comment https://bolterandchainsword.com/topic/387234-blood-ravens-special-characters/#findComment-6145874 Share on other sites More sharing options...
jaxom Posted December 8, 2025 Share Posted December 8, 2025 15 hours ago, HeadlessCross said: Assuming those rules are real... They're real as in they exist in a GW product. I assume they're meant for Narrative/Campaign play. They're not part of the Big Space Marine Points List in the tournament pack. 13 hours ago, Tacitus said: Also remember you can't mix and match He'Stan (or the Salamanders Det you're working on) wtih the Judiciar because of the Faction Keywords. Are there any Blood Raven only Dets in the book too? 10 hours ago, Lathe Biosas said: Not that I can find so far, but I'm still looking. There are not. I like both, but find their utility heavily depends on the detachment. For example, a Fall Back and Charge strat plus a good enhancement (as @HeadlessCross noted) are equivalent or better for the epic Chaplain. A melee weapon enhancement and movement/charge/consolidation trick strat are probably better than the epic Judiciar. That's just optimization though. Lathe Biosas 1 Back to top Link to comment https://bolterandchainsword.com/topic/387234-blood-ravens-special-characters/#findComment-6145945 Share on other sites More sharing options...
Tacitus Posted December 8, 2025 Share Posted December 8, 2025 5 hours ago, jaxom said: A melee weapon enhancement and movement/charge/consolidation trick strat are probably better than the epic Judiciar. That's just optimization though. I don't know about that. The way the rule is written his army using Blood Ravens characters would get the +1 to wound from OOM (And even though I think that was lucky oversight for the Blood Ravens that's how I would play it because these guys are still pretty generic not Epic) and I think Fights First and +1 to wound vs OOM is better than +1 to wound all the time (which is wasted vs OOM). I think there's two ways to build a shenanigans layer - either including or duplicating and independent OOM. The Chaplain only duplicates for melee (which can be fine if you're building that way) but there's ways to get a new OOM too that may work better for the Justiciar fights first. Depends on all the pieces put together and where you can pick them up. Link to comment https://bolterandchainsword.com/topic/387234-blood-ravens-special-characters/#findComment-6145996 Share on other sites More sharing options...
Indy Techwisp Posted December 8, 2025 Share Posted December 8, 2025 22 hours ago, Lathe Biosas said: Odd that the Blood Ravens would get 2 Chaplains, instead of a Librarian. There's no Librarians on that reused Starterbox Sprue, that's why. HeadlessCross and jaxom 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/387234-blood-ravens-special-characters/#findComment-6145997 Share on other sites More sharing options...
jaxom Posted December 8, 2025 Share Posted December 8, 2025 31 minutes ago, Tacitus said: I don't know about that. The way the rule is written his army using Blood Ravens characters would get the +1 to wound from OOM (And even though I think that was lucky oversight for the Blood Ravens that's how I would play it because these guys are still pretty generic not Epic) and I think Fights First and +1 to wound vs OOM is better than +1 to wound all the time (which is wasted vs OOM). I think there's two ways to build a shenanigans layer - either including or duplicating and independent OOM. The Chaplain only duplicates for melee (which can be fine if you're building that way) but there's ways to get a new OOM too that may work better for the Justiciar fights first. Depends on all the pieces put together and where you can pick them up. I have no idea how this is relevant to what I said. "A melee weapon enhancement and movement/charge/consolidation trick strat are probably better than the epic Judiciar," would be something like Judiciar with the Honour Vehement (+1A and +1S in melee, double if in Assault Doctrine) to hit the Str8 breakpoint. Link to comment https://bolterandchainsword.com/topic/387234-blood-ravens-special-characters/#findComment-6146002 Share on other sites More sharing options...
Tacitus Posted December 8, 2025 Share Posted December 8, 2025 (edited) Oh I think we both crossed things up - Headless Cross was talking about the Epic Chaplain's Fall Back and Charge plus the part of your post I cropped because I didn't think it was relevant to the point: Quote are equivalent or better for the epic Chaplain. Which gave the impression you were saying the Epic Chaplain was better than the Epic Judiciar Edited December 8, 2025 by Tacitus jaxom 1 Back to top Link to comment https://bolterandchainsword.com/topic/387234-blood-ravens-special-characters/#findComment-6146011 Share on other sites More sharing options...
HeadlessCross Posted December 10, 2025 Share Posted December 10, 2025 On 12/8/2025 at 7:54 AM, jaxom said: They're real as in they exist in a GW product. I assume they're meant for Narrative/Campaign play. They're not part of the Big Space Marine Points List in the tournament pack. There are not. I like both, but find their utility heavily depends on the detachment. For example, a Fall Back and Charge strat plus a good enhancement (as @HeadlessCross noted) are equivalent or better for the epic Chaplain. A melee weapon enhancement and movement/charge/consolidation trick strat are probably better than the epic Judiciar. That's just optimization though. There's not a lot of rules to grant Marines extra consolidation range. So it'd be a matter of if the detachment being used grants offensive bonuses with Strats to the special Judiciar and his squad. At minimum, it's at least INTERESTING and you can actually make a game plan around using the movement vs just the straight up melee enhancement (which would ordinarily be better). It's honestly just a shame the Chaplain doesn't offer anything interesting. Lathe Biosas and jaxom 2 Back to top Link to comment https://bolterandchainsword.com/topic/387234-blood-ravens-special-characters/#findComment-6146264 Share on other sites More sharing options...
