brother Vorn_GarDos Posted December 15, 2025 Share Posted December 15, 2025 I recently purchased the white dwarf 518. The article had missions and models to use to recreate older starter sets. The thing I was thinking is they included this, but they didn't include the stats to use for the models. I wanted to know if 8th edition stats can be used to recreate these starter set squads or do i have to search for 10th edition WH40k datacards? Link to comment https://bolterandchainsword.com/topic/387267-white-dwarf-wd518/ Share on other sites More sharing options...
LameBeard Posted December 15, 2025 Share Posted December 15, 2025 1 hour ago, brother Vorn_GarDos said: I recently purchased the white dwarf 518. The article had missions and models to use to recreate older starter sets. The thing I was thinking is they included this, but they didn't include the stats to use for the models. I wanted to know if 8th edition stats can be used to recreate these starter set squads or do i have to search for 10th edition WH40k datacards? They want your money, brother! They want you to buy a couple of codices! But some missions do work pretty well across multiple editions, with only minimal tweaks. brother Vorn_GarDos 1 Back to top Link to comment https://bolterandchainsword.com/topic/387267-white-dwarf-wd518/#findComment-6147194 Share on other sites More sharing options...
brother Vorn_GarDos Posted December 16, 2025 Author Share Posted December 16, 2025 (edited) 4 hours ago, LameBeard said: They want your money, brother! They want you to buy a couple of codices! But some missions do work pretty well across multiple editions, with only minimal tweaks. Haha. Good jest. Of course GW wants money. Edited December 16, 2025 by brother Vorn_GarDos LameBeard 1 Back to top Link to comment https://bolterandchainsword.com/topic/387267-white-dwarf-wd518/#findComment-6147207 Share on other sites More sharing options...
Solution Domhnall Posted December 16, 2025 Solution Share Posted December 16, 2025 12 hours ago, brother Vorn_GarDos said: I recently purchased the white dwarf 518. The article had missions and models to use to recreate older starter sets. The thing I was thinking is they included this, but they didn't include the stats to use for the models. I wanted to know if 8th edition stats can be used to recreate these starter set squads or do i have to search for 10th edition WH40k datacards? I've got the issue downstairs, but from what I remember of reading it, you are playing it with the current rules and unit stats, just with the model count matched to the old editions (and swap Intercessors for Tacticals if don't have them). brother Vorn_GarDos 1 Back to top Link to comment https://bolterandchainsword.com/topic/387267-white-dwarf-wd518/#findComment-6147228 Share on other sites More sharing options...
