On a world that had once been ruled by the Imperium, its name long forgotten, there had been order. There had been streets that bustled with labor shift-changes, cathedrums whose bells marked the hours, and hab-blocks stacked like stone cliffs around the throats of manufactorums. There had been lights in windows. There had been vox-hymns and ration lines and the dull, dependable rhythm of an Imperial city doing what Imperial cities always did: enduring.
Now it was a hollow imitation of itself.
The skyline was a jagged mouth of broken towers, their upper levels sheared away by bombardment and time. Statues of forgotten saints lay face-down in the streets, their marble cheeks cracked, their halos crushed beneath rubble. Aquila reliefs had been torn from walls and smashed into shards, scattered like bones across plazas that had once hosted parades and sermons. Whole districts were nothing but collapsed ferrocrete, rebar clawing up through the ash like grasping fingers. The air tasted of soot and iron, and beneath it, something fouler: the sour sting of the Warp seeped into everything, threading itself through smoke and dust like a sickness.
Chaos had come here and never left.
It did not rule in the way the Imperium ruled. It did not build. It devoured. And even that was not enough, because Chaos could not stop itself from turning inward. Rival warbands fought across the ruins not for territory that mattered, but for pride, for hatred, for promises whispered by unseen gods. In the distance, the thunder of heavy weapons rolled through the city like an approaching storm, then faded, then returned from another direction. Daemons shrieked in alleyways and on rooftops, some hunting mortals who were long gone, others tearing at each other in bursts of impossible violence, as if even their spite needed an outlet.
Smoke rolled through the avenues in thick sheets, blurring everything into silhouettes and ruin. It carried embers, carried ash, carried the stench of burned promethium and scorched flesh. And at the heart of one shattered boulevard, where a plaza had once opened around a broken fountain, the smoke began to change.
It gathered.
Not as wind gathered it, not as fire pushed it, but as if the haze itself had been called by something unseen. Ash swirled inward, tightening into a dense, unnatural cloud that blotted out what little light remained. The air in that place grew sharp, cold, and wrong, and the very sound of the battlefield seemed to dull at the edges, as if reality held its breath.
A small flicker of blue light sparked deep within the cloud.
It flashed once, then again, like an eye opening in the smoke. The glow brightened for a heartbeat and then steadied, and a shadow moved within it, tall and unmistakably inhuman. A figure stepped forward, pushing through the haze as if it were a curtain.
It was the rogue Blood Angel.
His armour was not the pristine red of parade-ground heroes. It had been dulled by dust and scarred by long war, the surface scratched and chipped where blades and claws had bitten into ceramite. Soot clung in the seams. Dried grime darkened the edges of his plates. Even so, he moved with the measured certainty of an Astartes who had survived what should have killed him more than once. His bolt rifle was held in both hands, muzzle tracking the broken streets with disciplined control. At his side, his power sword lay sheathed, a silent promise of violence kept in reserve. On the other hip rested his bolt pistol, close and ready for the moments when distance ceased to matter.
He paused and listened.
Not with ears alone. With the instinct of a predator. With the hard-won caution of a lone warrior in a world that wanted him dead. His helm turned slowly, taking in the silhouettes that shifted in the smoke, the distant muzzle flashes that stuttered across ruined rooftops, the faint, warping laughter that did not belong to any living throat. He did not flinch. This was not unfamiliar. War-torn worlds all shared a language.
Then, beneath his armour, something answered that language with its own.
The Warp Crystal embedded in his chest pulsed.
A measured thrum, like a signal sent into darkness. It did not scream. It did not rage. It called. Tred focused on that sensation, letting the resonance spread outward from him, not as a sound but as a pressure, a ripple through the unseen currents that saturated this broken world.
For a moment, there was nothing.
Then something replied.
A faint return. A harmonic echo that pushed back against his own pulse, distant but unmistakable. His helm snapped toward it, body turning with the reflex of a warrior who had learned to trust the smallest warning signs. The resonance sharpened. The direction became clearer. Not a map. Not certainty. But enough.
Another crystal.
Another shard singing in the same twisted key.
The hunt was on.
He moved, slipping into the skeletal streets, keeping to cover and shadow where possible, choosing routes that avoided open ground. He did not seek battle here, not unless he had to. Daemons were everywhere, and Chaos was thick in the air like a storm front. A fight in this place could draw attention from things far worse than a pack of warp-spawned hunters.
As he advanced, the world reacted to him in subtle, unsettling ways. Corruption that clung to walls like oily bruises seemed to thin when he drew near. Warp-slick residue pooled in cracks and gutters and then retreated, evaporating into ash as though repelled. Painted sigils and half-living runes scrawled across shattered stone lost their shimmer and bled into dull stains. It was not the city healing. Nothing healed here. It was the Warp being denied, pushed back by the crystal within his chest, smothered into silence in the space around him.
Tred did not slow. He had seen this effect before, and he did not waste time wondering at it now. He only followed the pull, step by careful step, deeper into the ruin, toward the answering echo that waited somewhere ahead, and toward whatever had dared to carry such a thing into a world already drowning in damnation.
The streets tightened around him as he moved, the city folding inward into a maze of shattered structures and narrow passageways. Buildings leaned against one another like exhausted giants, their upper levels fused by collapse and fire, creating choking alleys where light struggled to reach the ground. Every route curved back on itself or ended in rubble. Vox-static whispered through the air without a source. Somewhere nearby, something screamed, then cut off abruptly.
Tred stopped.
He assessed the terrain for a heartbeat, then shifted course. A ruined administratum block loomed above the surrounding streets, its lower levels gutted by fire, its upper floors fractured but still standing. Without hesitation, he began to climb. Magnetic locks in his boots bit into ferrocrete and exposed metal as he ascended, pulling himself upward with controlled, economical movements. Loose debris fell away beneath him, vanishing into the smoke below.
When he reached the rooftop, the world opened.
From this height, the true scale of the devastation revealed itself. The city stretched outward in every direction, a dead sprawl of ruin and corruption. Entire districts burned unchecked, their fires burning in unnatural colors. Warp scars split the ground like open wounds, glowing faintly as they bled unreality into the streets. Ritual circles were etched into plazas and thoroughfares, some abandoned, others still active, surrounded by twisted remains that had once been human. Towers leaned at impossible angles, held upright by nothing but broken physics and warp-taint.
This was not a battlefield anymore.
It was a carcass being fought over.
In the distance, he could see Chaos in its purest form: not unity, not conquest, but endless self-destruction. Warbands clashed across shattered boulevards. Daemonic engines lumbered through ruins only to be torn apart by rival entities moments later. Sorcerous fire arced across the skyline, colliding with artillery barrages that reduced entire blocks to dust. The world was not falling. It had already fallen. What remained was the echo.
Then the Warp Crystal in his chest flared.
Not gently this time.
The pulse struck him with sudden clarity, sharp and directional, like an arrow loosed from the dark. Tred turned instantly, raising his bolt rifle and bringing its scope to his helm. He followed the resonance outward, letting instinct and augmetics align, and then he saw it.
Movement in the sky.
A figure swept across the ruins at speed, elevated above the battlefield on a living, winged form that should not have existed. A demonic beast, its silhouette warped and wrong, carrying an armored rider clad in corrupted plate. The rider’s armor bore the unmistakable bulk and proportions of an Astartes, but its markings were obscured by distance, grime, and the shimmer of warp energies clinging to him. Tred narrowed his focus, adjusting the scope, but the truth remained frustratingly incomplete.
A Chaos Space Marine.
Legion unknown.
The crystal sang harder in response.
But something else was wrong.
The rider was under fire.
Searing lances of plasma energy tore through the smoke from below, bright coils of unstable power snapping past the airborne figure in violent arcs. Each shot left a brief afterimage burned into the haze, the air itself warping where the bolts passed. One blast clipped the beast’s flank, detonating in a burst of incandescent light that sent fragments of corrupted flesh spiraling downward. The creature screamed, banking sharply as another plasma bolt narrowly missed its head, passing close enough to flash white-hot against its armor.
This was not indiscriminate fire.
Someone was hunting him.
Tred did not hesitate.
He committed the terrain to memory in an instant, mapping broken streets, collapsed transitways, and vertical access points as his mind calculated distance and approach. The bolt rifle dropped from his scope as he moved, breaking into a full sprint toward the edge of the rooftop. He vaulted the shattered parapet without slowing, plunging into the smoke-choked streets below.
The impact sent ash and debris billowing outward as he hit and ran, boots pounding across fractured stone and metal. The resonance pulled him forward, stronger now, guiding him through the ruins toward the source of the plasma fire. Ahead, the thunder of battle intensified, plasma detonations flashing through the haze like artificial lightning.
Whatever waited there, whatever force had drawn another Warp Crystal into this damned city, Tred was already closing the distance. The ruins swallowed him as he charged into the smoke, drawn toward the clash of Chaos, and fire.
Tred slowed as the smoke thinned, slipping into the gutted interior of a half-collapsed hab structure whose upper floors had folded inward under bombardment. He pressed himself into the shadows behind a fractured window frame, its plasteel glass blown out long ago, and looked out onto what had once been a broad processional avenue. Statues lay shattered along its length, their faces ground into the street beneath boot treads and tank tracks that no longer came. The avenue was now a torn killing ground, its surface cratered and scarred by repeated plasma impacts and warp-burns, the stone vitrified in places where heat had lingered too long. The air shimmered faintly with residual energy, and ash drifted down in slow, aimless spirals, settling on ruin that would never be cleaned.
The beast struck the ground in a spray of shattered stone and warped flesh.
It hit hard, the impact cracking the avenue beneath it. Its wings were ruined beyond use, membranes shredded and bones broken, dragging uselessly as it thrashed and howled. It did not die. It clawed at the street with desperate strength, gouging deep scars into the ferrocrete as it tried to pull itself forward, driven by instinct and whatever unholy will still bound it to its master.
The rider was thrown clear.
He rolled once across the rubble, then came up on one knee with unnatural balance, cloak torn and scorched where plasma fire had grazed it moments before. As the smoke shifted, Tred saw the armour clearly. Scriptural plates layered over ceramite. Serrated iconography worked into every surface. Litanies carved deep, not painted, as if the words themselves had been forced into the metal.
And on the shoulder guard, unmistakable even beneath soot and warp-stain, burned the sigil of the Word Bearers.
The Warp Crystal embedded in Tred’s chest pulsed, sharp and insistent, its resonance tightening like a drawn blade.
Plasma fire ripped across the avenue again, detonating against rubble near the fallen beast and forcing the Word Bearer to step back. The shots came in controlled cadence, evenly spaced, each bolt placed to deny ground rather than waste ammunition. There was no frenzy in it. No indulgence. Whoever was firing understood angles, understood pressure, understood how to break an enemy’s options apart piece by piece.
Then the smoke parted.
From within the drifting dust, something vast moved forward.
A towering figure emerged at a run, heavy boots hammering the broken street with enough force to send loose debris skittering aside. His armour was thick and brutal, plate layered upon plate, scarred by siege after siege, each gouge and burn mark left unrepaired. Hazard striping cut through soot-blackened iron in harsh, utilitarian bands. There was no scripture etched into his plate. No ornament. No ritual markings. Only function, reinforced and refined through relentless war.
A plasma pistol burned bright in one gauntlet, firing in disciplined bursts as he advanced. In the other, he carried a chainsaw axe, its teeth screaming as it bit into the air, the sound harsh and industrial rather than savage.
There was no doubt what he was.
An Iron Warrior.
He crashed into the space between rubble and flame like a living battering ram. Plasma fire tore through the first wave of daemons that leapt to intercept him, bodies bursting apart in incandescent flashes as unstable energy consumed warp-flesh from the inside out. Those that survived long enough to reach him were met by the chainsaw axe, its roaring teeth carving through claw and bone with mechanical finality. He advanced without hesitation, without flourish, every movement calculated to maintain momentum.
As the Iron Warrior clashed with the Chaos daemons, the avenue became a slaughter ground of its own. Warp-spawned bodies fell and dissolved into smoke, their remains leaving nothing behind but scorched stone and drifting ash. The Iron Warrior pressed forward through it all, relentless, unyielding, forcing the fight closer and closer to the Word Bearer.
The Word Bearer raised his voice.
Not in panic. Not in rage. But in command.
He extended one arm and pointed toward the Iron Warrior, the gesture sharp and deliberate. Only then did Tred see it. Mounted along the Word Bearer’s arm, bound into corrupted ceramite, was a Warp Crystal shard. Its surface caught the light at a wrong angle, geometry bending in ways the eye refused to fully accept. It did not flare. It did not blaze. It simply answered, resonating faintly in sympathy with the crystal embedded in Tred’s own chest.
The daemons reacted instantly.
Those still standing turned as one, as if yanked by unseen chains, and hurled themselves at the Iron Warrior in a coordinated surge. He met them head-on, plasma and steel tearing through their ranks, holding his ground through sheer brutality and discipline. But the Word Bearer did not linger to watch.
He turned back to his wounded mount, grasped its mane, and hauled himself onto its back as it struggled upright. The beast lurched forward, wings dragging uselessly as it fled down the avenue, carrying its master away into the smoke. Within seconds, both rider and mount vanished into the ruin, the echo of chanting fading into the city’s endless noise.
The Iron Warrior stood alone amid the wreckage.
Then the second wave came.
Smaller daemons emerged from the surrounding structures, their forms thin and distorted, eyes burning with sickly light. They did not charge. They spread out, moving slowly, deliberately, hands raised as the air around them shimmered and twisted. Reality itself seemed to buckle under their presence.
The Iron Warrior staggered.
False light detonated across his senses, not a physical blast but a psychic rupture that slammed into his mind. Targeting overlays desynced. Depth perception collapsed. Sound fractured into meaningless echoes. His movements slowed, commands arriving a fraction of a second too late to matter.
He dropped to one knee.
Then both.
The chainsaw axe slipped from his grasp and struck the ground, teeth still spinning uselessly. He tried to rise, systems fighting against the imposed distortion, but his body refused to respond in time. The daemons closed in, blades lifting, their movements unhurried.
From the shadows of the ruined avenue, a new figure stepped forward.
Tred emerged into the open, his presence cutting through the illusion field like a blade through smoke. As he crossed the boundary, the Warp Crystal embedded in his chest surged, and the effect was immediate. The shimmering distortions collapsed outward as if punctured, layered hallucinations shattering like brittle glass as reality snapped back into alignment.
Tred raised his bolt rifle and opened fire.
The nearest daemons were torn apart in disciplined volleys, their forms unraveling into smoke and ash as he advanced, methodical and unyielding. He did not shout. He did not hesitate. He simply eliminated the threat, clearing the space around the fallen Iron Warrior with ruthless efficiency.
Behind him, the Iron Warrior dragged in a harsh breath as his senses realigned, systems stabilizing as the pressure lifted. He looked up through the thinning smoke and saw the red-armoured figure standing amidst the ruin, bolt rifle still tracking for targets, posture steady and unreadable.
For a moment, the battlefield fell quiet around them.
And the echo of the crystal’s song lingered in the air.
After a long moment, he lowered the rifle a few degrees, enough to signal readiness without invitation. Beneath his armour, the Warp Crystal embedded in his chest answered his focus, its pulse tightening and drawing his awareness outward. The resonance was weaker now, stretched thin by distance, but it remained clear enough to follow. The Word Bearer had fled deeper into the city’s corpse.
Tred shifted his footing, preparing to move.
A low hiss of contained energy cut the silence behind him.
He froze.
The distinctive hum of a plasma pistol rose, unstable power building in its chamber. The glow spilled across broken stone at his feet, painting jagged shadows along the avenue wall. Tred did not turn at once. He did not tense. He simply stopped, hands steady on his weapon, posture unchanged, acknowledging the presence behind him without conceding control.
Seconds dragged by, heavy and measured.
When he finally turned his head, it was slow and deliberate, just enough for the crimson lenses of his helm to settle on the towering figure behind him. He did not raise his rifle. He did not reach for his pistol or sword. He stood as he was, neither threatening nor submissive.
The Iron Warrior held his aim, massive frame braced, armour still bearing the marks of recent punishment. Soot streaked his plate. Scoring from plasma and claw marred the iron. One knee had not quite straightened yet, the servo still recalibrating after the assault. He watched Tred in silence, assessing, recalculating.
“What is a Blood Angel doing on this world?” he asked at last.
His voice was flat, stripped of curiosity or courtesy, each word delivered with mechanical clarity.
“The Imperium is far from here.”
“I have my own means,” Tred replied. His voice was calm, unhurried. “I am not here with my Chapter. I walk alone.”
The Iron Warrior said nothing immediately. His helm angled slightly, a subtle shift that betrayed calculation rather than disbelief. Loyalist doctrine did not account for solitary Astartes appearing on worlds like this without support, without command authority, without explanation. The idea did not fit cleanly, and he did not like things that did not fit.
His focus sharpened.
“You broke the warp-field,” he said. “My suit, my systems, and my body were crippled. Sensory input desynced. Motor control lagged. I was reduced to my knees.” The plasma pistol remained trained on Tred’s helm. “Then you entered the distortion, and it collapsed. Explain.”
“I can’t,” Tred said. “I don’t know how it works. Only that it does.”
That answer lingered between them.
The Iron Warrior studied him again, longer this time, helm tilting as if stripping away assumptions layer by layer. He did not like uncertainty. He tolerated it when it was useful.
“And why are you here?” he asked.
Tred did not hesitate. “I am hunting the Word Bearer.”
The Iron Warrior went completely still.
Around them, the city groaned, distant artillery rolling through the ruins like thunder beneath the earth. Somewhere far off, something screamed and was abruptly silenced. The Iron Warrior’s attention locked fully onto Tred now, the weight of it unmistakable.
“You tracked him,” he said.
“Yes.”
“You know where he’s going.”
“I do.”
The plasma pistol lowered a fraction, the hum dipping but not vanishing. The Iron Warrior exhaled slowly, a controlled release of breath rather than relief. “Then I will not kill you,” he said. “Not yet.”
He straightened at last, damaged servos compensating as his massive frame settled into a more stable stance. “I am here to destroy that Word Bearer. Your presence increases the likelihood of that outcome.” His voice hardened. “Do not mistake this for trust.”
He raised the pistol again, just enough to make the warning unmistakable.
“Attempt deception. Hesitate. Interfere. And I will end you where you stand.”
Tred said nothing.
He turned away from the Iron Warrior and began walking, boots crunching softly over broken stone as he followed the faint pull of the crystal deeper into the ruins. After a brief pause, heavy footfalls followed behind him, iron on ferrocrete, steady and relentless.
They did not walk together.
But they walked the same road.
The hunt continued.
They moved through the ruins without formation.
Tred walked ahead, following the faint, persistent pull of the Warp Crystal embedded in his chest. The Iron Warrior followed several paces behind, chainsaw axe mag-locked at his side, plasma pistol held low but ready. He did not watch the path. He watched Tred.
The city pressed in around them as they advanced. Buildings leaned inward like conspirators, their interiors gutted by fire and collapse. Warp residue clung to walls and pooled in the cracks of the street, slick and oily, twitching faintly as if aware of their passing. Daemonic spoor stained the ground, half-real shapes frozen where creatures had died and dissolved, leaving only the memory of their presence behind.
After several minutes of silence, the Iron Warrior spoke.
“You said you walk alone,” he said. “Yet you claim a purpose. Explain it.”
Tred did not slow. His helm remained forward, crimson lenses fixed on the route ahead. “I am no longer bound to the Imperium’s command structure,” he said. “I do not receive orders. I do not march with fleets.”
The Iron Warrior let that sit for a moment. “Then why are you here?”
“I still serve the Emperor’s will.”
That earned a pause.
The Iron Warrior’s footfalls slowed by a fraction. “The Emperor’s will,” he repeated, tone flat. “You speak of it as if it were a measurable thing.”
“It is,” Tred replied. “It is survival. Resistance. Denial of the Warp’s dominion.” He glanced briefly at the corruption lining the street as they passed. Where he walked, the slick warp-filth thinned, shriveling and receding as if repelled by his presence. “That is the Emperor’s will, whether the Imperium recognizes it or not.”
The Iron Warrior watched the ground change beneath Tred’s steps. He did not comment on it.
“Do you make a habit,” he asked instead, “of fighting alongside Traitor Legions?”
Tred stopped.
Not abruptly. Just enough to acknowledge the question. He turned his head slightly, helm angling toward the Iron Warrior without fully facing him.
“I do not see you as a Traitor Legion,” he said. “I see an Iron Warrior.”
The words landed heavier than any insult could have.
For the first time since their encounter, the Iron Warrior’s stride faltered. Just for a step. His helm turned toward Tred fully now, optics fixed on him with renewed intensity.
“That distinction matters to you?” he asked.
“It does,” Tred replied. “You are what you choose to be in battle. Not what others name you.”
The Iron Warrior did not respond immediately. They resumed walking, their steps echoing between ruined walls. Around them, the city groaned, distant bombardments shaking loose debris from fractured balconies. Warp-etched runes flickered and died as they passed, their light fading into nothing when Tred drew close. A pair of lesser daemons watched them from a collapsed doorway and then withdrew, forms unraveling as if the world itself rejected their presence.
After a long stretch of silence, the Iron Warrior spoke again, his voice quieter now. “You speak as if identity is not dictated by allegiance.”
“It is dictated by action,” Tred said.
They continued deeper into the city’s corpse.
The streets widened as they advanced, opening gradually into a broad, shattered square. Once, it had been a gathering place, ringed by administratum offices and hab-spires, its center dominated by a toppled statue whose features had been ground smooth by centuries of devotion before being defaced by war. Now the square was scarred by ritual markings burned into the stone, some fresh, some half-erased by bombardment. The air here felt heavier, saturated with lingering warp energy.
Tred slowed as they entered the shattered courtyard, the pull of the Warp Crystal in his chest tightening, then shifting, as if searching for purchase. The square opened around them, wide and broken, its stone etched with half-burned ritual marks and the scars of heavy bombardment.
The Iron Warrior halted and scanned the perimeter, helm turning in short, precise movements as he mapped firing lanes, elevated positions, and likely points of ambush.
“He passed through here,” he said.
“Yes,” Tred replied.
He stood still for a moment longer, focusing inward, letting the crystal’s faint resonance stretch outward once more, testing the air, the stone, the lingering warp-scent left behind. The pull wavered, thinned, then tugged again, uncertain but present.
“Yes,” Tred said again, quieter this time, as if confirming it to himself.
And there they paused, in the ruined heart of the city, while the trail cooled and the silence pressed in around them.
Silence pressed in around the ruined courtyard.
Then came the sound of movement.
At first it was faint, almost easy to dismiss. A soft, uneven patter echoing from somewhere beyond the shattered stone. Too light for boots. Too many points of contact. Tred’s helm tilted slightly as the sound repeated, skittering along the edges of the square like insects moving just out of sight.
The Iron Warrior stiffened.
More footsteps joined the first. A dozen, then dozens, multiplying rapidly. The sound thickened into a wet, trampling rhythm that echoed from the surrounding structures. From alley mouths. From broken archways. From above.
Both warriors raised their weapons.
The Iron Warrior widened his stance, plasma pistol humming as it charged, chainsaw axe snarling to life in his other gauntlet. Tred brought his bolt rifle up, sweeping the perimeter, tracking movement that refused to resolve into solid targets.
They could hear them.
But they could not see them.
Then the world exploded.
Daemons burst into the courtyard in a single, coordinated ambush. They poured from doorways and ruptured stone, dropped from rooftops, clawed their way up through cracked paving as if the ground itself had betrayed them. Tall, horned shapes slammed down alongside smaller, faster horrors that skittered and leapt with bladed limbs flashing.
The Iron Warrior met them head-on.
Plasma fire roared from his pistol, each shot a sun-bright lance that punched through warp-flesh and sent daemons screaming back into unreality. Those that closed the distance were met by the chainsaw axe, its roaring teeth chewing through bone and sinew with industrial finality. He fought like a siege engine unleashed, advancing through the swarm, every blow meant to remove space, to deny the enemy ground.
Tred fired from behind him.
Bolt rounds thundered into the mass of daemons, detonating inside bodies that burst apart in sprays of ash and screaming light. Each kill ended the same way. The daemon’s form unravelled, collapsing inward before dissolving into drifting smoke that was torn away by the corrupted air. No bodies remained. Only scorched stone and fading echoes.
The horde pressed in regardless.
Smaller daemons darted through gaps, moving too fast, too erratic. Tred adjusted his fire, switching targets without pause, his bolter barking until the magazine ran dry. The weapon clicked empty.
He dropped it without hesitation.
The bolt rifle hit the ground as his power sword came free in one smooth motion, its edge igniting with restrained fury. His bolt pistol cleared its holster at the same time. He stepped forward, joining the Iron Warrior in the press of close combat.
They fought back-to-back without a word.
Tred cut down a leaping daemon with a single upward sweep, the blade slicing cleanly through its torso before the creature dissolved into smoke mid-fall. He fired his pistol point-blank into another, the round detonating and sending the thing screaming back into the Warp. He pivoted, blade flashing again, severing limbs, crushing skulls, never overcommitting, never lingering.
The Iron Warrior drove forward beside him, axe rising and falling in brutal arcs. A larger daemon lunged, claws raking across his chest plate. He answered by burying the chainsaw axe into its skull, the teeth screaming as they chewed deep.
The daemon convulsed.
The axe stuck.
For a fraction of a second, the Iron Warrior wrenched at it, servos whining as he tried to tear the weapon free. That was when something moved behind him.
A lithe shape slipped through the smoke, too quiet, too precise. Its form shimmered with unnatural grace, bladed limbs raised, its laughter a whisper of promise and cruelty. It closed the distance in a heartbeat, striking from the Iron Warrior’s blind side.
Tred saw it.
“Brother, behind you!”
He did not fire.
He threw.
The power sword left his hand in a spinning arc, humming as it cut through the smoke. The Iron Warrior ducked instinctively, helm snapping down as the blade passed inches over his head. The sword punched straight through the daemon’s chest, impaling it against a slab of fractured stone.
The creature shrieked once.
Then it unraveled, dissolving around the embedded blade, leaving nothing behind but drifting ash and the sword buried deep in the rock.
The Iron Warrior turned.
His optics fixed on the spot where the daemon had been, then snapped back to Tred. For the briefest moment, something unreadable passed through his posture. Surprise, perhaps. Or recognition.
The fight did not pause for reflection.
More daemons rushed in, but the momentum had shifted. The Iron Warrior tore his axe free from the dying creature, the daemon collapsing into smoke around the blade. Plasma fire flared again. Tred retrieved his bolt rifle, slammed a fresh magazine home mid-stride, and brought it up as he fired.
The remaining daemons fell quickly.
Bolt rounds detonated. Plasma burned. Warp-flesh dissolved. One by one, the attackers were banished back into unreality, their forms breaking apart into nothingness until only silence remained.
Ash drifted through the courtyard.
Tred lowered his rifle and walked past the Iron Warrior without a word. He reached the stone slab, braced one boot against it, and tore his power sword free, the blade dimming as he caught it and returned it to his grip.
Behind him, the Iron Warrior spoke.
“Why did you call me brother?”
Tred paused, then turned his head slightly.
“In the middle of that fight,” he said, his voice steady, “for one second, I forgot what we were supposed to be. I forgot sides. I forgot titles.” He met the Iron Warrior’s gaze. “I saw a warrior fighting beside me. Nothing more.”
The Iron Warrior said nothing.
The ruins groaned around them, and the echo of battle faded into the broken city.
And for a moment longer, neither of them moved.
For a heartbeat, the Iron Warrior was silent.
Then his posture changed.
He straightened fully, damaged servos locking into place with a muted grind, and turned on Tred with sudden sharpness. The chainsaw axe was still in his grip, its teeth slowly winding down, the sound filling the space between them like a warning.
“I am not your brother,” he snapped.
The word came out hard, stripped of hesitation or restraint. “Do not use it again.” He stepped closer, iron plate scraping against rubble as his shadow fell across Tred. “You are not my kin. You are not my equal. You are a tool.”
His helm angled downward, optics burning cold. “As far as I am concerned, whether you live or die is irrelevant so long as you remain useful.” His voice lowered, dense with long-held resentment. “I am an Iron Warrior. My strength is iron. My loyalty is iron. That word died a long time ago.”
The courtyard held its breath.
Tred did not argue.
He did not apologize.
He simply inclined his head a fraction, acknowledgment without concession, and turned back toward the ruins ahead.
The Iron Warrior watched him for a long moment longer before following, the bitterness in his words lingering in the air like the aftertaste of smoke.
They moved again, deeper into the city’s corpse.
The ruins grew denser as they advanced, the streets narrowing into crooked arteries choked with debris and half-real growths of warp corruption. Veins of unnatural matter pulsed along shattered walls, swelling and shrinking as if breathing. The air thickened with pressure, not heat, but a weight that pressed against the senses, dulling sound and bending light at the edges. Every step closer felt like walking against an unseen current.
Tred noticed it first in the way the corruption behaved.
Closer to him, the worst of it recoiled. Warp-slick residue dried and cracked beneath his boots. Whispering sigils etched into stone dimmed as he passed, their glow guttering out like candles starved of air. But beyond that narrow margin, the Warp asserted itself violently. Shadows twisted at wrong angles. Faint laughter echoed from nowhere. The city itself seemed to resent his presence, as though reality and unreality were arguing over who was allowed to exist here.
Ahead, the skyline shifted.
A tower rose above the surrounding ruins, its original Imperial lines warped and broken, spire fractured but still standing through sheer wrongness. Where its upper levels should have been dark, a storm of color churned instead. Warp energy coiled around the crown of the structure, bleeding into the sky in slow, spiraling arcs. Flickers of daemonic light pulsed rhythmically, like a beacon calling things that should not answer.
The Iron Warrior slowed, helm lifting toward it.
The closer they came, the stronger the Warp became. The air vibrated faintly, teeth-aching pressure settling into bone and ceramite alike. Distant shapes moved within the haze around the tower’s base, silhouettes resolving and dissolving as daemons patrolled the grounds in uneven, restless patterns. The structure was not merely occupied.
It was active.
The Iron Warrior stopped abruptly, turning toward Tred.
“Is he in there?”
The question was not shouted. It was demanded, edged with urgency barely contained.
Tred did not answer immediately. He shifted his stance, focusing inward, letting the Warp Crystal embedded in his chest pulse outward once more. The resonance flared in response to the tower, sharp and insistent now, tugging with unmistakable certainty. He studied the flow of energy for a heartbeat longer, then nodded.
“Yes.”
The Iron Warrior’s gauntlets clenched.
“Then I must reach him before he desecrates them further.”
That gave Tred pause.
He turned slightly as they resumed their advance, watching the Iron Warrior from the corner of his helm. “What does he have,” he asked, “that matters so much to you?”
For several steps, the Iron Warrior did not answer.
They passed beneath a collapsed skybridge, its wreckage fused to the street by warp-fire. Daemons watched from broken windows and withdrew as the pair approached, their forms blurring and thinning, unwilling to draw too close. The tower loomed larger now, its presence oppressive, its energy crawling across the ruins like static.
Finally, the Iron Warrior spoke.
“He has taken the bodies of several warriors from my squad,” he said. His voice was low, stripped of ornament or rage. “They fell during the fighting on this world. I do not know what he intends to use them for.” He paused, helm angling toward the tower. “But I know what the Word Bearers do with the dead.”
The chainsaw axe shifted slightly at his side, teeth clicking once as the machine spirit stirred.
“I will not allow their remains to be defiled,” he finished. “Not by him.”
Tred said nothing.
They moved on, closing the last stretch of ground until they reached the outer structures overlooking the tower’s grounds. From the roof of a shattered administratum building, the full scale of the site revealed itself.
The courtyard below was vast, once a formal plaza, now utterly consumed. Daemonic formations clustered across the open ground, hundreds of warped figures prowling, circling, gathering in loose, predatory packs. Some knelt before crude altars carved into the stone. Others paced restlessly, weapons scraping against the ground, drawn to the Warp energy radiating from above. The tower dominated it all, its base ringed with corruption, its upper levels wreathed in writhing light.
Warp lightning arced between broken spires near its crown.
The Iron Warrior surveyed the scene in silence, already dissecting angles, counting threats, calculating casualties.
Tred felt the crystal’s pull intensify, a steady, inexorable draw toward the heart of the tower.
Whatever ritual was taking place there, it was nearing something decisive.
And beneath the howling Warp and the watching daemons, both warriors understood the same truth.
There would be no easy way in.
They watched the tower from the rooftop in silence.
Below them, the grounds writhed with unnatural life. Daemons prowled in loose, shifting patterns, clustering and breaking apart as if pulled by invisible currents. Some knelt before warped icons hammered into the stone, others paced restlessly, claws scraping, weapons dragging. Chains rattled somewhere in the haze. The air itself vibrated with pressure, warp energy bleeding outward from the tower’s crown in slow, pulsing waves that made the ruins groan.
Tred studied the swarm. “We cannot go through that.”
“No,” the Iron Warrior replied. “We will not.”
He moved to the edge of the rooftop and crouched, one gauntleted hand bracing against the fractured stone. His helm swept the surrounding structures in deliberate arcs. He was no longer seeing buildings. He was seeing stresses, load paths, fault lines. Where Imperial architecture had once been rigid and proud, Chaos had softened it, eaten away at foundations, warped supports until they bore weight they were never meant to carry.
His gaze settled on a half-collapsed hab-block leaning toward the tower, its lower levels fractured and braced with crude, daemonic reinforcements. Chains as thick as a man’s torso anchored something large in the shadow of its base.
The Iron Warrior rose slowly, plasma pistol lifting.
Tred turned sharply. “What are you doing?” he demanded. “Are you trying to draw the entire horde onto us?”
The Iron Warrior did not look at him. His pistol tracked a single point with minute adjustments, calculating angle, yield, reaction time. “I have sieged citadels that killed armies for daring to approach,” he said calmly. “You do not break a fortress by charging it.”
He paused, finger tightening on the trigger.
“You break what it relies on.”
The plasma pistol fired.
The shot did not strike the building.
It struck a chain.
The link vaporized in a flash of white-blue light, molten metal spraying outward. The restraint failed instantly, and what had been bound was unleashed.
The daemon surged forward with a roar of rage and confusion, its massive bulk slamming into the already compromised structure. Stone cracked. Reinforced beams twisted. The creature struck again, maddened by pain and sudden freedom, its blows echoing through the ruin.
The Iron Warrior watched, unmoving.
The first crack ran through the building’s lower supports like a spreading wound.
Then another.
And another.
The hab-block shuddered, its upper levels sagging as the internal stresses redistributed themselves catastrophically. Adjacent structures groaned in protest, their weakened connections snapping one by one. The failure spread outward, slow at first, then accelerating, a cascading collapse marching toward the tower like a falling line of dominos.
Tred and the Iron Warrior turned their helms together, tracking the destruction as it unfolded.
Daemons reacted too late.
The building finally gave way, its upper mass shearing loose and crashing sideways into the tower’s lower exterior. The impact was titanic. Stone exploded. Warp-lit debris rained down, crushing lesser daemons and hurling others screaming into the air. The tower’s outer wall buckled, cracking under the sudden weight.
The grounds erupted into chaos.
Daemons turned on one another, territorial fury ignited by the collapse. Others surged toward the destruction, drawn by noise and instinct, swelling the madness into a riot of claws and flame.
When the dust began to clear, a slanted mass of broken stone and twisted metal lay wedged against the tower’s lower levels.
A bridge.
Solid enough to climb. High enough to bypass the killing ground below.
Right where they needed it.
Tred stared at it. “You knew that would happen.”
“I calculated it,” the Iron Warrior replied, already stepping forward.
“And if it hadn’t worked?”
The Iron Warrior did not slow. “Then we would not be standing here.”
They advanced onto the fallen structure together, leaving the screaming confusion below them, climbing toward the tower as warp lightning flared overhead and the true battle waited above.
As they moved through the upper levels of the tower, the Iron Warrior slowed suddenly, helm snapping to the side. Ahead, in a partially collapsed chamber, the beast lay crouched amid broken stone and hanging chains. The creature’s massive frame was hunched low, its warped jaws working rhythmically as it tore at something on the floor.
An Iron Warrior’s corpse.
The armor was unmistakable, hazard stripes scorched and cracked, ceramite split open where the beast had bitten through. The warrior’s helm lay crushed nearby, its lenses dark.
The Iron Warrior did not hesitate.
With a wordless snarl of rage, he surged forward, chainsaw axe roaring to life as he charged the beast head-on. Plasma fire flashed once, then the sound of impact echoed through the chamber as axe teeth bit deep into corrupted flesh. The beast screamed, thrashing wildly as the Iron Warrior drove it back, fury and iron meeting warp-born muscle in a storm of sparks and blood.
Tred did not follow.
He paused, sensing the pull intensify above him.
The Warp Crystal in his chest flared, sharp and urgent, dragging his attention upward like a hooked blade. The confusion below, the clash of iron and daemon, had opened a narrow window.
Tred took it.
The clash below echoed upward through the tower’s hollow spine, each impact buying only moments before the noise would draw worse things to them.
By the time he reached the upper levels, the sounds of battle had dulled beneath him, replaced by a pressure that had nothing to do with noise.
As he moved higher, silent and precise, ascending the last broken stairwell until the air itself changed. Sound dulled. Gravity felt uncertain. The chamber ahead was wide and circular, once a spire’s observation level, now stripped bare and reworked into a ritual space.
At its center stood the Word Bearer.
He was framed by a lattice of warp energy, strands of crackling force extending outward from a crystalline focus mounted along his arm. The Warp Crystal burned with malignant light, its glow reflected in the dead eyes of the bodies laid out around him.
Iron Warriors.
Their corpses were arranged in deliberate patterns, limbs positioned with ritual precision. Arcs of warp energy leapt between them, crawling across armor and exposed flesh, linking body to body in a flickering circuit. The air screamed softly, time stuttering at the edges of vision as the ritual strained against reality.
Tred felt it then.
Attention.
Not a presence with form, but pressure. Like standing beneath a vast weight held just barely in check. The warp around the ritual thickened, coiling inward, shapes half-forming and collapsing again. The crystal in Tred’s chest vibrated violently, resonating with the forces at work.
Something was watching.
The Word Bearer lifted his arms higher, chanting words that made the chamber bend and shudder. Warp lightning lashed down, striking the bodies, forcing energy through them in surging waves.
For a moment, it almost worked.
Space twisted. The air folded in on itself. One of the bodies convulsed, armor warping as if reality itself were trying to pull it apart and reassemble it into something else.
Then the strain became too much.
The bodies failed.
Not with an explosion, but with rejection. Warp energy surged through them and met resistance, gene-forged flesh refusing to yield, psyches too rigid, too blunt. The circuit destabilized. Energy screamed back toward the crystal in violent feedback, ripping through the ritual lattice.
The bodies collapsed inward, smoking and broken, their forms left scorched and empty, the ritual lines guttering out one by one.
Silence fell.
The Word Bearer staggered, arms still raised, helm tilting as if listening. Warp energy swirled briefly around him, forming no shape, no face, only presence.
Then a voice pressed into the chamber.
“You failed.”
It was not loud. It did not need to be.
The Word Bearer reached out instinctively, one gauntlet extended as if pleading. “Wait,” he rasped. “The fault was not the design. The materials—”
The pressure vanished.
The warp snapped back into itself, the watching presence gone as if it had never been there.
The Word Bearer’s arm fell limp to his side.
For a long moment, he stood motionless. Then his head bowed, shoulders sagging under the weight of sudden, crushing realization.
“I warned them,” he hissed, voice trembling with fury. “I warned them we needed something that sings to the Warp.”
Below, stone shattered.
The floor erupted as the daemon beast burst upward through it, the Iron Warrior’s chainsaw axe still embedded deep in its neck. The creature collapsed forward, momentum carrying it only a few steps before its form unraveled, dissolving into smoke and ash as it was finally banished back into the Immaterium.
The Iron Warrior emerged through the wreckage, armor scarred, axe slick with warp residue. He took in the scene in a single glance: the bodies, the crystal, the Word Bearer.
“You have defiled iron,” he said coldly. “For that, you will answer.”
From the shadows above, Tred shifted position, blade ready, eyes locked on the Word Bearer.
And the Word Bearer, trembling with rage and humiliation, turned toward them both.
His grip tightened around the Warp Crystal.
The real battle was about to begin.
The Word Bearer screamed.
Not in pain. In fury.
Warp energy surged around him as he thrust his arm toward the corpse of the fallen beast. The Warp Crystal flared violently, its light no longer contained, no longer refined. Tendrils of unreality lashed outward and wrapped around the daemon’s remains, dragging flesh, bone, and essence inward.
The corpse began to dissolve.
Muscle collapsed into vapor. Warp-born sinew unraveled into streams of screaming light. The substance of the beast did not vanish. It was taken. Drawn screaming into the Word Bearer’s body as his armor split apart, plates buckling and tearing under the strain.
His form swelled.
Bones cracked and reshaped. Spikes punched through ceramite and flesh alike. His arms elongated, fingers fusing into clawed talons slick with warp ichor. A hunched, towering shape rose where the Word Bearer had stood, crowned with horned protrusions and a skull-like visage stretched into something bestial and hateful.
The transformation ended with a roar that shook the tower.
The Iron Warrior charged.
He did not wait. He never did.
Plasma fire flashed as he sprinted forward, then he ducked low, chainsaw axe screaming as he carved into the beast’s leg. Warp-flesh split under the grinding teeth, ichor spraying across the floor as the creature reeled and lashed out blindly.
Bolter fire thundered from behind him.
Tred fired controlled bursts into the monster’s face, detonations ripping across its skull and forcing it to turn, snarling, claws raking at empty air as rounds exploded against its features. Each shot was placed to draw attention, to keep the thing’s focus divided.
The creature reacted with unnatural speed. It twisted its massive torso, claws carving through the air as it surged toward the Iron Warrior, forcing him to disengage and dive clear. Tred adjusted instantly, advancing a step and firing again, bolt rounds tearing into exposed warp-flesh and detonating in bursts of light and smoke. The beast staggered, then adapted, its hide thickening where it had been struck, claws striking the floor hard enough to crater stone. It slammed one arm down toward Tred, missing him by a fraction as he rolled aside, coming up on one knee and firing point-blank into the joint of its elbow. The explosion forced the limb to recoil, buying the Iron Warrior precious seconds to circle behind it once more, axe revving as he prepared another brutal strike.
The beast swung hard.
The Iron Warrior rolled beneath the blow, came up behind it, and drove his axe into its calf again, tearing deep. He fired point-blank into its back, plasma searing holes through warp-flesh as the creature howled and staggered.
It adapted.
A massive arm slammed down, catching the Iron Warrior mid-stride and hurling him across the chamber. He hit the far wall hard, ceramite cracking as he slid to one knee, stunned but not broken.
The beast turned fully toward Tred.
It charged.
Tred dropped the bolt rifle and drew his power sword and pistol in a single motion. He moved laterally, firing as he went, bolt rounds detonating against the creature’s chest as he closed the distance. The beast swiped, claws tearing through stone where he had been a heartbeat earlier.
Steel met claw.
Tred blocked the next strike with his blade. The impact screamed through his arms, the power field flaring wildly as warp and machine collided. For a moment, he held.
Then the blade shattered.
The power sword exploded into fragments of sparking metal and dying energy, the force of the blow hurling Tred backward. He struck the ground hard, rolling once before coming to a stop, armor scorched and cracked.
The beast loomed over him, claws rising.
It would have ended there.
The Iron Warrior hit it from behind.
He surged forward with a roar of effort, leaping onto the creature’s back, mag-locks biting into warped flesh as he climbed. With both hands, he drove the chainsaw axe down into the beast’s skull, teeth shrieking as they bit deep.
The monster screamed, thrashing violently, trying to dislodge him.
It wasn’t enough.
Tred was already moving.
He rose, drew his bolt pistol, and sprinted forward, leaping up onto the creature’s side. With one hand, he braced against its warped armor. With the other, he forced the Iron Warrior’s axe deeper, adding his strength to the drive.
Together, they pushed.
The chainsaw axe punched through.
Warp energy erupted outward as the blade breached something vital. The creature convulsed, its form unraveling from the inside as the corrupted essence sustaining it collapsed. Light, smoke, and screaming pressure tore through the chamber as the beast began to disintegrate.
The explosion was brief but violent.
Warp energy blasted outward, throwing both warriors clear as the monster collapsed inward, its massive form dissolving into ash and screaming vapor that was ripped apart by the failing ritual energies.
Silence followed.
The Iron Warrior rose first, dragging himself upright, axe still in hand. Tred pushed himself to his feet moments later, armor damaged, sword destroyed, but alive.
Where the beast had stood, there was nothing left.
Only scorch marks. Broken stone. And the fading echo of something that should never have existed.
They stood in the ruined ritual chamber, breathing steady, weapons lowered.
The Word Bearer was dead.
Silence reclaimed the ritual chamber.
The warp residue still clung to the air, but it was thinning now, bleeding away like smoke after a fire. High above, through the shattered crown of the tower, the clouds began to part. Not fully. Just enough. Pale sunlight spilled down through the broken stone, cutting through the haze and dust, illuminating the ruin in long, muted shafts of gold.
It did not cleanse the chamber.
But it marked an ending.
Tred pushed himself upright, armor scorched, joints stiff with damage. He crossed the chamber slowly, retrieved his fallen bolt rifle, and slammed a fresh magazine into place. The click echoed sharply in the quiet.
He turned.
The Iron Warrior stood opposite him, chainsaw axe resting at his side, posture rigid, helm angled just enough to watch him. For a moment, neither moved. The distance between them felt heavier than any battlefield, each measuring the other, both knowing exactly how fast this could end.
“…You fought well,” he said.
The words sounded old. Heavy. As if they had been forged long ago and left unused.
“You Blood Angels,” he continued, his voice grinding through layers of restraint, “lost your Primarch and did not shatter. You carry a curse that gnaws at your minds and drags you toward madness.” His helm tilted slightly, studying Tred with something close to scrutiny. “And yet, even with that weight upon you, you continue to fight. Even when your thoughts betray you. Even when your blood itself turns against you.”
He paused.
“There is iron in that. A rare kind. Many Legions would have broken beneath such a burden.”
Tred inclined his head, accepting the words without pride.
“And you Iron Warriors,” he replied, “may have sided with Horus in his rebellion… but when the others fell to excess, to obsession, to the promises of gods that feed on weakness, you did not.” His gaze held steady on the towering figure before him. “Your reasons may be your own. Your bitterness well-earned. But you endured where many did not.”
The Iron Warrior’s gauntlet flexed once.
“You prevailed against something that has claimed entire Legions,” Tred continued. “The pull of the chaos gods.”
Silence followed. Not hostile. Not warm. Simply heavy.
The Iron Warrior turned away, his attention settling on the fallen bodies of his brothers. “I could kill you now,” he said. “No one would question it.”
He stood still for a moment longer, then shook his head once.
“But I will not.”
“I must call for retrieval,” he said, voice lowering. “Their bodies must be reclaimed. Their armor stripped of corruption. Their names spoken.” He looked back over his shoulder. “The rites will take time. While I perform them, my attention will be elsewhere.”
A deliberate pause.
“If you are gone by then,” he added, “I will not pursue you.”
He knelt beside one of the fallen Iron Warriors and lifted a power sword from the rubble. Its casing was battered, its surface dark with blood and ash, its edge etched with sigils meant to bite deep into warp-spawned flesh.
He rose and tossed it.
Tred caught the weapon cleanly.
“This iron will not fail you,” the Iron Warrior said. “Not as the Imperium’s promises did.”
Tred studied the blade for a heartbeat, its balance uncompromising and precise. The power sword’s surface was smooth, unadorned by ornament, its metal a dull iron-gray etched with hazard-striped sigils and the stark skull-and-chevron iconography of the Iron Warriors. No filigree. No devotionals. Only function. Along its edge, the power field hummed with a cold, disciplined resonance, not a raging warp-fury but a tightly bound containment, engineered to bite into unreality rather than bargain with it. As Tred held it, the Warp Crystal within his chest reacted, not flaring, but steadying, its presence pressing outward as if recognizing a weapon forged to deny the Immaterium rather than channel it. Where Chaos sought excess and mutation, this blade answered with refusal. Against daemons, it would not burn brighter. It would simply cut deeper. Then inclined his head once more. He did not thank him. He did not need to.
He turned and began his descent.
Halfway down the broken stairwell, a brief blue flicker cut through the air around him, sharp and precise, and then he was gone, drawn into the Warp as quietly as he had emerged.
The Iron Warrior remained.
He knelt among the dead and began the rites of iron and remembrance, his voice low as he recited the names of the fallen, one by one, anchoring them to memory so the Warp could not claim them entirely.
Yet even as he worked, his thoughts lingered elsewhere.
On the failed ritual.
On the crystal.
On the blood angle that walk alone.
What was this all for? he wondered.
And if this was merely a test… what comes when it succeeds?
The sunlight faded behind drifting clouds.
Somewhere beyond the tower, the faint echo of the Warp Crystal’s song faded at last, and as it did, the sunlight dimmed once more behind drifting clouds, as if the world itself refused to believe the quiet would last.
And the question remained.
The end
Till next time
thanks for reading
if you have any constructive criticism it would be most appreciated
Edited by Tred1998
https://bolterandchainsword.com/topic/387453-rogue-blood-angel-blood-and-iron/
Register a new account
Sign in
