Lathe Biosas Posted February 9 Share Posted February 9 (edited) I thought I had escaped painting White, until I bought an Apothecary. Any easy ways to paint a white armoured space marines? My current paint skill level is 0. If it's really easy, I'll paint all my Marines as Hospitalitiers. Edited February 9 by Firedrake Cordova Fixed formatting W.A.Rorie 1 Back to top Link to comment https://bolterandchainsword.com/topic/387554-how-to-paint-white-space-marines/ Share on other sites More sharing options...
Grotsmasha Posted February 9 Share Posted February 9 (edited) The secret is ... don't. You paint them a really light grey, and highlight with white. The quickest way currently would be to prime in Grey Seer, then do Apothecary White Contrast, but not all over. Target it into areas that are in the shade, and then all the recesses all over. Then edge in your white of choice. Alternatively, you could Apothecary White all over and then dry brush over with a light grey (Grey Seer or lighter), then edge in white. EDIT: Make sure to add agitators to your Apothecary White, and shake the ever loving crap out of it until there's no sediment sitting on the bottom of the pot. Edited February 9 by Grotsmasha Firedrake Cordova, LameBeard, Bryan Blaire and 4 others 5 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/387554-how-to-paint-white-space-marines/#findComment-6155843 Share on other sites More sharing options...
Sothalor Posted February 9 Share Posted February 9 Yeah I would not call myself a skilled painter by any means, but when it comes to painting white, one consistent technical detail pops up in my experience: Many white paints undergo separation when it comes to their pigments, and that will affect their behavior when trying to paint onto a mini. You really want to agitate the bejeezus out of them to get them to a consistency where they aren't working against you. Lathe Biosas 1 Back to top Link to comment https://bolterandchainsword.com/topic/387554-how-to-paint-white-space-marines/#findComment-6155847 Share on other sites More sharing options...
Lathe Biosas Posted February 9 Author Share Posted February 9 How do you do the black between the armour? Link to comment https://bolterandchainsword.com/topic/387554-how-to-paint-white-space-marines/#findComment-6155854 Share on other sites More sharing options...
Karhedron Posted February 9 Share Posted February 9 I also find painting white a challenge but Apothecarion White contrast paint does help. Here is my Biologis who I painted pretty simply with the following recipe. Basecoat Grey Seer Contrast Apothecarion White Highlight with Corax white Not perfect but pretty decent results without going overboard on complexity. Lathe Biosas, calgar101, RolandTHTG and 3 others 4 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/387554-how-to-paint-white-space-marines/#findComment-6155855 Share on other sites More sharing options...
Grotsmasha Posted February 9 Share Posted February 9 1 hour ago, Lathe Biosas said: How do you do the black between the armour? Black Templar Contrast will do it nicely W.A.Rorie, Firedrake Cordova and Lathe Biosas 2 1 Back to top Link to comment https://bolterandchainsword.com/topic/387554-how-to-paint-white-space-marines/#findComment-6155863 Share on other sites More sharing options...
Sky Potato Posted February 15 Share Posted February 15 (edited) Corax White Soulblight Grey all over shade Corax White chunky edge highlight Bold Titanium White (Pro Acryl) fine edge highlight. You can skip direct to this if you want. I always found Grey Seer with Apothecary White to be just too grey for my liking. Corax White & Soulblight Grey is still a light grey, it just reads more as white. It’s amazing the colour jump from that to the Bold Titanium White. Edited February 15 by Sky Potato Typo Lathe Biosas 1 Back to top Link to comment https://bolterandchainsword.com/topic/387554-how-to-paint-white-space-marines/#findComment-6156990 Share on other sites More sharing options...
Teetengee Posted February 16 Share Posted February 16 I'd also recommend that if you use a warm white, use warm colors over the rest of the mini, and likewise for cool. This will trick the eye into seeing the warmth as an aspect of lighting, instead of a marker of color. Lathe Biosas 1 Back to top Link to comment https://bolterandchainsword.com/topic/387554-how-to-paint-white-space-marines/#findComment-6157039 Share on other sites More sharing options...
Dr. Clock Posted February 19 Share Posted February 19 Your start is pretty decent tbh. White isn't easy, but don't let it get you down. As others have said, use 'actual white' sparingly, and only really at the end. Mostly Ulthuan Grey is the prevailing hue on my whites, after I put on Grey Seer and a coat of Titanium (it's a Game Colour paint from days past... basically a blue that's almost white), and then selective wash Nuln Oil into plate joins. From the looks of things you might be well served to pick an off-white on the blue or red side like that for underpainting - when it's just stacks of neutral grey that's really when it starts looking a bit flat and dusty, whereas blue or red shifting some of the underlayers will make the actual white at the end a bit more legible. That's to say that even just starting on Wraithbone instead of Grey Seer might liven it up a bit. Cheers, The Good Doctor. Lathe Biosas and Firedrake Cordova 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/387554-how-to-paint-white-space-marines/#findComment-6157641 Share on other sites More sharing options...
Brian_Sisk Posted February 20 Share Posted February 20 For white armor, I usually basecoat in a mid-gray or off-white first. Then paint the white over it - it helps prevent streaks and makes it look cleaner. Washes and highlights can add depth, but even just a gray wash around the edges makes a huge difference without being too hard. Lathe Biosas and Firedrake Cordova 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/387554-how-to-paint-white-space-marines/#findComment-6157763 Share on other sites More sharing options...
jaxom Posted February 21 Share Posted February 21 The simplest method I know is: 1) Prime or basecoat an off-white color (like Greyseer). 2) Contrast or speedpaint appropriate for white all over the model. Alternative: use a mix of black wash or black contract/speedpaint and either water or medium. 3) Dry brush all over with a light grey, only in a downward motion. 4) Selective dry brush with white on upward facing edges. You can use a blue-grey in step 3 to get a cooler white color. You can use a browner color in step 2 and a cream or off-white in step 3 to get a more bone-white color. Firedrake Cordova and Lathe Biosas 1 1 Back to top Link to comment https://bolterandchainsword.com/topic/387554-how-to-paint-white-space-marines/#findComment-6157838 Share on other sites More sharing options...
hd3 Posted February 28 Share Posted February 28 On 2/9/2026 at 2:04 PM, Grotsmasha said: The secret is ... don't. You paint them a really light grey, and highlight with white. The quickest way currently would be to prime in Grey Seer, then do Apothecary White Contrast, but not all over. Target it into areas that are in the shade, and then all the recesses all over. Then edge in your white of choice. Alternatively, you could Apothecary White all over and then dry brush over with a light grey (Grey Seer or lighter), then edge in white. EDIT: Make sure to add agitators to your Apothecary White, and shake the ever loving crap out of it until there's no sediment sitting on the bottom of the pot. When you say add agitators, what do you mean? Because I'm having a similar problem with my apothecary white Link to comment https://bolterandchainsword.com/topic/387554-how-to-paint-white-space-marines/#findComment-6158807 Share on other sites More sharing options...
Grotsmasha Posted February 28 Share Posted February 28 2 hours ago, hd3 said: When you say add agitators, what do you mean? Because I'm having a similar problem with my apothecary white I add a pair of these, reduces shaking time significantly. Link to comment https://bolterandchainsword.com/topic/387554-how-to-paint-white-space-marines/#findComment-6158814 Share on other sites More sharing options...
hd3 Posted March 1 Share Posted March 1 On 2/28/2026 at 4:54 PM, Grotsmasha said: I add a pair of these, reduces shaking time significantly. I'll look into that! Thanks grotsmasha. Out of curiosity, is this worth trying if I've already tried using a proper electric paint shaker? Or should I just write off that paint after that? Link to comment https://bolterandchainsword.com/topic/387554-how-to-paint-white-space-marines/#findComment-6158928 Share on other sites More sharing options...
Grotsmasha Posted March 1 Share Posted March 1 1 hour ago, hd3 said: I'll look into that! Thanks grotsmasha. Out of curiosity, is this worth trying if I've already tried using a proper electric paint shaker? Or should I just write off that paint after that? I have one of those, and still use it with the mixing balls too, Link to comment https://bolterandchainsword.com/topic/387554-how-to-paint-white-space-marines/#findComment-6158936 Share on other sites More sharing options...
