Keercrevlis Posted March 28, 2009 Share Posted March 28, 2009 Here's my version of a Wolf Lord on a Bike it is A "WIP" Tell me what you think! http://s729.photobucket.com/albums/ww298/K...mview=slideshow Link to comment https://bolterandchainsword.com/topic/66089-space-wolf-painting-converting-etc/page/7/#findComment-1932854 Share on other sites More sharing options...
Yeti Posted March 31, 2009 Share Posted March 31, 2009 Well, finally got around to photoshopping the image I took after the recent tournament. Check out my album (see sig) to see some of the model that make up Yeti Bearclaws Great Company. Link to comment https://bolterandchainsword.com/topic/66089-space-wolf-painting-converting-etc/page/7/#findComment-1937050 Share on other sites More sharing options...
stinkenheim Posted April 1, 2009 Share Posted April 1, 2009 first up, wolf tail talismans... take a small cone of greenstuff, smaller than you want the finished talisman to be... http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00509.jpg then using a sculpting tool or knife blade (make sure your tools are wet to stop the greenstuff sticking) score lines from top to bottom, this will lengthen the cone. when you get to the bottom of the talisman pull a couple of the strands outward slightly, and pull a few out from the sides to give a nice look to it. http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00511.jpg then square off the top slightly and also take a small piece out of the top corners so the top looks something like this /-\ http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00512.jpg then take a small ball of greenstuff and place it on the top, you might need to shape it slightly when its there but it should look like the tail comes out and then expands slightly (gives the impression that the metal clasp is pinching the hair together) http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00513.jpg then lastly score a small line just above the bottom of the ball of greenstuff... if you want you can instead add a small sauage of greenstuff but this is quicker and easier and looks fine. it just gives you th slight rim that you find on the plastic taismans. http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00515.jpg and there you go, a finished wolf tail talisman... next up, runic charms and wolf tooth necklaces... for the charm take a blob of greenstuff (yes 'blob' is a technical term... i went on the course you see) http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00516.jpg flatten it and square off some of the edges, try and make it look irregular if you can http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00517.jpg then using the tip of your scultping tool (or if its a really small charm your scalpel... jst be carefull if you put it in your move to moisten the blade cos tongues take ages to stp bleeding) and score in your chosen rune and a small dot at the top of the charm http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00518.jpg for teeth i find if you add a small, thin cone of greenstuff and shape it with a slight bend in it you should get a nice tooth like shape. if you can, a small nick at the top gets the shape of roots. but make sure you add a dot like you did with the charm. http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00519.jpg well now you need something to attatch them to, so take a thin sausage of greenstuff and place it just above http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00520.jpg and lastly using some more thin strips of greenstuff make the mtal rings, or leather straps that attatch the teeth and charms to the necklace... place one end in the small dots you made and then cut the sausage just above the necklace strap... and voila, a quick necklace is done :D http://i400.photobucket.com/albums/pp86/stinkenheim/DSC00521.jpg i will add a quick tutorial for the diamond gems but i'm waiting for the base to cure... Link to comment https://bolterandchainsword.com/topic/66089-space-wolf-painting-converting-etc/page/7/#findComment-1938202 Share on other sites More sharing options...
tacowrath Posted April 8, 2009 Share Posted April 8, 2009 http://i50.photobucket.com/albums/f315/grumpieleesa/l_cb9f660d60494394a2a504e85518503c.jpg Link to comment https://bolterandchainsword.com/topic/66089-space-wolf-painting-converting-etc/page/7/#findComment-1946291 Share on other sites More sharing options...
Grimfoe Posted April 8, 2009 Share Posted April 8, 2009 Here is my Wolf Lord and his Retinue. The WIP thread can be found in my sig line: http://www.bolterandchainsword.com/uploads/1235967177/gallery_33642_3057_224459.jpg[/i Link to comment https://bolterandchainsword.com/topic/66089-space-wolf-painting-converting-etc/page/7/#findComment-1946323 Share on other sites More sharing options...
DV8 Posted April 14, 2009 Share Posted April 14, 2009 I was voluntold to post this here. My kill team from 2/3 years ago: http://www.spacewithinspace.net/images/warhammerimages/swkillteam.jpg And while I'm here, some fun nostalgia, sort of a before and after. Some shots of my original Space Wolves army. The bulk of it was painted about 10-odd years ago, with newer characters being added a few years later. The army was sold about 3 or 4 years ago. http://www.spacewithinspace.net/images/spacewolves/oldarmy/wolflord.jpg http://www.spacewithinspace.net/images/spacewolves/oldarmy/army.jpg http://www.spacewithinspace.net/images/spacewolves/oldarmy/characters.jpg http://www.spacewithinspace.net/images/spacewolves/oldarmy/wolfscouts.jpg http://www.spacewithinspace.net/images/spacewolves/oldarmy/bloodclaws.jpg http://www.spacewithinspace.net/images/spacewolves/oldarmy/greyhunters.jpg http://www.spacewithinspace.net/images/spacewolves/oldarmy/rhino.jpg http://www.spacewithinspace.net/images/spacewolves/oldarmy/longfangs1.jpg http://www.spacewithinspace.net/images/spacewolves/oldarmy/longfangs2.jpg DV8 Link to comment https://bolterandchainsword.com/topic/66089-space-wolf-painting-converting-etc/page/7/#findComment-1954451 Share on other sites More sharing options...
DV8 Posted April 14, 2009 Share Posted April 14, 2009 And my newest Space Wolf army, built about 2 months ago: http://www.spacewithinspace.net/images/spacewolves/jormunrek.jpg http://www.spacewithinspace.net/images/spacewolves/sternguard1.jpg http://www.spacewithinspace.net/images/spacewolves/sternguard2.jpg http://www.spacewithinspace.net/images/spacewolves/rhino_oseberg.jpg http://www.spacewithinspace.net/images/spacewolves/greyhunters1.jpg http://www.spacewithinspace.net/images/spacewolves/greyhunters2.jpg http://www.spacewithinspace.net/images/spacewolves/rhino_munin.jpg http://www.spacewithinspace.net/images/spacewolves/greyhunters3.jpg http://www.spacewithinspace.net/images/spacewolves/greyhunters4.jpg http://www.spacewithinspace.net/images/spacewolves/rhino_roskva.jpg http://www.spacewithinspace.net/images/spacewolves/vanguard1.jpg DV8 Link to comment https://bolterandchainsword.com/topic/66089-space-wolf-painting-converting-etc/page/7/#findComment-1954453 Share on other sites More sharing options...
Ant Posted April 16, 2009 Share Posted April 16, 2009 Forgive me for the bad quality of the photos, they were taken on my phone. My 13th Company. Wolf Lord http://i37.photobucket.com/albums/e63/Iorekspics/DSC00002.jpg Wolf Guard http://i37.photobucket.com/albums/e63/Iorekspics/DSC00006.jpg Erik the Illegal 13th Co. Dreadnought x) (i never use him, i just preffered 13th Co. colour scheme) http://i37.photobucket.com/albums/e63/Iorekspics/DSC00010.jpg Wulfen http://i37.photobucket.com/albums/e63/Iorekspics/DSC00013.jpg Long Fangs http://i37.photobucket.com/albums/e63/Iorekspics/DSC00014.jpg Grey Slayers http://i37.photobucket.com/albums/e63/Iorekspics/DSC00017.jpg Wolf Guard in Terminator Armor http://i37.photobucket.com/albums/e63/Iorekspics/aergre.jpg Rune Priest http://i37.photobucket.com/albums/e63/Iorekspics/stgh.jpg Unfinished Wolf Priest http://i37.photobucket.com/albums/e63/Iorekspics/aergerg.jpg And my Father's pride and joy 'Old School' army. Ragnar and Ulrik http://i37.photobucket.com/albums/e63/Iorekspics/DSC00018.jpg Techpriest and Stormcaller http://i37.photobucket.com/albums/e63/Iorekspics/DSC00020.jpg Long Fangs http://i37.photobucket.com/albums/e63/Iorekspics/DSC00022-1.jpg Blood Claw Assault Squad http://i37.photobucket.com/albums/e63/Iorekspics/DSC00023-1.jpg Scout Squad http://i37.photobucket.com/albums/e63/Iorekspics/DSC00024-1.jpg Terminator Squad http://i37.photobucket.com/albums/e63/Iorekspics/DSC00025.jpg Land Speeder (this model passed the 1st stage of Golden Daemon when my Father entered it in 1569 xD. Lol just kidding, but it did get past the 1st stage) http://i37.photobucket.com/albums/e63/Iorekspics/DSC00026.jpg Bjorn the Fell Handed http://i37.photobucket.com/albums/e63/Iorekspics/DSC00027.jpg Grey Hunters http://i37.photobucket.com/albums/e63/Iorekspics/DSC00028.jpg Ive got a few more pics on my photobucket :) heres a link http://s37.photobucket.com/albums/e63/Iorekspics/ Link to comment https://bolterandchainsword.com/topic/66089-space-wolf-painting-converting-etc/page/7/#findComment-1956987 Share on other sites More sharing options...
ubermarcus Posted April 29, 2009 Share Posted April 29, 2009 Here's my Wolf Lord, my first attempt at mixing and matching bits from non-space marine models. http://img.photobucket.com/albums/v135/smeagol_deagol/wolves_logan.jpg And Ragnar Blackmane, the first serious model I painted in about 10 years. I was glad to find I'm not as terrible as when I was 14! :P http://img.photobucket.com/albums/v135/smeagol_deagol/wolves_ragnar.jpg Link to comment https://bolterandchainsword.com/topic/66089-space-wolf-painting-converting-etc/page/7/#findComment-1971199 Share on other sites More sharing options...
Vash113 Posted May 10, 2009 Share Posted May 10, 2009 My army so far: http://i107.photobucket.com/albums/m307/Vash113/Space%20Wolves/IMG_0571-1.jpg http://i107.photobucket.com/albums/m307/Vash113/Space%20Wolves/IMG_0573-1-1.jpg http://i107.photobucket.com/albums/m307/Vash113/Space%20Wolves/IMG_0567-1.jpg http://i107.photobucket.com/albums/m307/Vash113/Space%20Wolves/IMG_0566-1.jpg Link to comment https://bolterandchainsword.com/topic/66089-space-wolf-painting-converting-etc/page/7/#findComment-1982816 Share on other sites More sharing options...
SpaceWolf918 Posted May 27, 2009 Share Posted May 27, 2009 Her is some of my army. They are Space Wolves just painted way darker. Wolf Lord Front http://i721.photobucket.com/albums/ww214/HighLordUlrik/Testimage.jpg Wolf Lord Back http://i721.photobucket.com/albums/ww214/HighLordUlrik/NewBack002copy.jpg Venerable Dreadnought http://i721.photobucket.com/albums/ww214/HighLordUlrik/PhotoshopedDredNo2.jpg Land Speeder Typhoon http://i721.photobucket.com/albums/ww214/HighLordUlrik/PHSLandSpeeder.jpg Thats all for now. Coments and questions are wellcome Link to comment https://bolterandchainsword.com/topic/66089-space-wolf-painting-converting-etc/page/7/#findComment-2002161 Share on other sites More sharing options...
Megalodon Posted July 2, 2009 Share Posted July 2, 2009 Let me introduce the Venerable Dreadnought Skeld Redmane to the denizens of the Fang! He's ready to smite the foes of the Imperium! http://img.photobucket.com/albums/v673/EasyEight/40K/Wolves/spacewolves008.jpg http://img.photobucket.com/albums/v673/EasyEight/40K/Wolves/spacewolves009.jpg http://img.photobucket.com/albums/v673/EasyEight/40K/Wolves/spacewolves010.jpg http://img.photobucket.com/albums/v673/EasyEight/40K/Wolves/spacewolves011.jpg Link to comment https://bolterandchainsword.com/topic/66089-space-wolf-painting-converting-etc/page/7/#findComment-2038121 Share on other sites More sharing options...
Wamp Posted July 16, 2009 Share Posted July 16, 2009 Hi, Brothers. My Wolf Priest. This is full my conversion, but it's painted by prof art: http://s57.radikal.ru/i158/0903/bc/79638c02dc5a.jpg http://s40.radikal.ru/i090/0903/fa/3464c46d8b1f.jpg Link to comment https://bolterandchainsword.com/topic/66089-space-wolf-painting-converting-etc/page/7/#findComment-2051429 Share on other sites More sharing options...
Erazoender Posted July 17, 2009 Share Posted July 17, 2009 I'm not going to post pictures here, as I am still working on my wolves, but this is what I got on my blog: http://www.warhammer-game.com/warhammer-game-blog.html Link to comment https://bolterandchainsword.com/topic/66089-space-wolf-painting-converting-etc/page/7/#findComment-2052238 Share on other sites More sharing options...
TeamLando Posted July 17, 2009 Share Posted July 17, 2009 My good old Njal Stormcaller finially arrives at CoolMini, I think I'm actually gonna get more active on that page rather than uploading a diorama or a battle scene every year :P Well, hell, I'll probably do that anyways but....anyway! Here's Njal, painted him last year, my first try at blending. Kinda neat I'd say, still pleased with him, woulv'de been slightly better if he'd been painted today but that's how it works in this hobby isn't it :P http://www.coolminiornot.com/pics/pics13/img4a60e87a79116.jpg http://www.coolminiornot.com/227277 It's the URL to CoolMini, vote those of you who want to! :D Link to comment https://bolterandchainsword.com/topic/66089-space-wolf-painting-converting-etc/page/7/#findComment-2052956 Share on other sites More sharing options...
Durfast Spiritwolf Posted July 26, 2009 Share Posted July 26, 2009 Well I finally got around to taking some piccies: http://www.bolterandchainsword.com/index.p...h&mid=43042 Here's some tasters: Link to comment https://bolterandchainsword.com/topic/66089-space-wolf-painting-converting-etc/page/7/#findComment-2061248 Share on other sites More sharing options...
Parcival Posted July 28, 2009 Share Posted July 28, 2009 Dear Brothers of Leman Russ, As you can see in my signature, I am a Blood Angels collector, but when I purchased used Terminators for my force, this Space Wolf Terminator sneaked into my purchase so I figured I may paint it as well. I hope my painting is adequate for such a great Chapter. http://lh6.ggpht.com/_ulSnsKLwG68/Sm6ZP-LMY_I/AAAAAAAAB18/APHJxU-UyRs/s400/DSC04690.JPG http://lh5.ggpht.com/_ulSnsKLwG68/Sm6ZRXhVXII/AAAAAAAAB2A/vlO4D4Jfzis/s400/DSC04692.JPG http://lh3.ggpht.com/_ulSnsKLwG68/Sm6ZSwQlR1I/AAAAAAAAB2E/4QIzRSfaYcs/s400/DSC04694.JPG http://lh6.ggpht.com/_ulSnsKLwG68/Sm6ZUJA_MWI/AAAAAAAAB2I/xUlxih9pd3A/s400/DSC04697.JPG Link to comment https://bolterandchainsword.com/topic/66089-space-wolf-painting-converting-etc/page/7/#findComment-2063040 Share on other sites More sharing options...
warboy Posted August 8, 2009 Share Posted August 8, 2009 here's a few photos i dug up of my colour scheme of PAIN my wolf guard with mark of the wulfen, Power Sword and master crafted bolt pistol http://i425.photobucket.com/albums/pp337/Warboy1982/P1010466.jpg Wolf Guard with frost blade and plasma pistol http://i425.photobucket.com/albums/pp337/Warboy1982/P1010471.jpg Long Fang firing missile launcher http://i425.photobucket.com/albums/pp337/Warboy1982/P1010474.jpg Grey Hunter with power fist http://i425.photobucket.com/albums/pp337/Warboy1982/P1010477.jpg Grey Hunter with plasma gun http://i425.photobucket.com/albums/pp337/Warboy1982/P1010480.jpg enjoy Link to comment https://bolterandchainsword.com/topic/66089-space-wolf-painting-converting-etc/page/7/#findComment-2073612 Share on other sites More sharing options...
ChrisSpaceWolves Posted August 18, 2009 Share Posted August 18, 2009 http://i332.photobucket.com/albums/m339/ChrisMBianchi/100_5659.jpg http://i332.photobucket.com/albums/m339/ChrisMBianchi/100_5635.jpg http://i332.photobucket.com/albums/m339/ChrisMBianchi/100_5670.jpg http://i332.photobucket.com/albums/m339/ChrisMBianchi/100_5668.jpg http://i332.photobucket.com/albums/m339/ChrisMBianchi/100_5496.jpg http://i332.photobucket.com/albums/m339/ChrisMBianchi/100_5482.jpg http://i332.photobucket.com/albums/m339/ChrisMBianchi/100_5356.jpg http://i332.photobucket.com/albums/m339/ChrisMBianchi/100_5330.jpg http://i332.photobucket.com/albums/m339/ChrisMBianchi/100_5202.jpg http://i332.photobucket.com/albums/m339/ChrisMBianchi/100_5620.jpg http://i332.photobucket.com/albums/m339/ChrisMBianchi/100_5616.jpg http://i332.photobucket.com/albums/m339/ChrisMBianchi/100_5667.jpg wip http://i332.photobucket.com/albums/m339/ChrisMBianchi/100_5637.jpg Link to comment https://bolterandchainsword.com/topic/66089-space-wolf-painting-converting-etc/page/7/#findComment-2083071 Share on other sites More sharing options...
Perry Posted September 8, 2009 Share Posted September 8, 2009 http://img.photobucket.com/albums/v465/Pezzar/111.jpg My first Space Wolves model, been sat in its blister for 6 years since Gamesday 03, thought it was finaly time to paint it ready for the new Space Wolves codex. Link to comment https://bolterandchainsword.com/topic/66089-space-wolf-painting-converting-etc/page/7/#findComment-2104924 Share on other sites More sharing options...
Thorgad Posted September 9, 2009 Share Posted September 9, 2009 Hail everyone! I've finally gotten around to taking some pictures of my Work In Progress SpaceWolves for the Great Hunt vow. I vowed to paint my 32 bloodclaws, my slightly converted WGBL, and the five fenrisian wolves I've put together so far. Note: I apologize in advance for the shoddy quality of the pictures, but when all you have is a cell-phone cam, you gotta make do. This is the buncha bloodclaws I so foolishly vowed to paint up. These still need a few finishing touches, but are actually almost ready to be dipped! http://farm4.static.flickr.com/3532/3903624906_dd300ab2d9_o.jpg The (yet unpainted) Wolfguard Battleleader, not exactly the most awesome and extreme conversion to date, but I like how he turned out nonetheless. http://farm3.static.flickr.com/2563/3903554956_ededb741a3_o.jpg This is how the bloodclaws turn out after they're dipped. I'm actually quite pleased with the result! http://farm3.static.flickr.com/2555/3903555030_dc340b6fde_o.jpg Haven't gotten started on the wolves yet, but I'll be getting to them sometime this week. As a bonus, here's a picture of my runepriest, lovingly referred to as "Jesús" among my friends and opponents: http://farm3.static.flickr.com/2513/3903554980_cf5bd68ed4_o.jpg Link to comment https://bolterandchainsword.com/topic/66089-space-wolf-painting-converting-etc/page/7/#findComment-2105658 Share on other sites More sharing options...
SamaNagol Posted September 23, 2009 Share Posted September 23, 2009 I was inspired by the new Logan artwork from the codex: http://i601.photobucket.com/albums/tt91/Sa...llustration.jpg So I started work on this: http://i601.photobucket.com/albums/tt91/Sa...ol/DSC00183.jpg Yeh I got bored this afternoon waiting for my Advance Orders to turn up... Knocked these two out in a couple of hours cannibalising various sprues. Still need a few touches here and there but are essentially finished. Combi Melta & Chain Fist http://i601.photobucket.com/albums/tt91/Sa...ol/DSC00188.jpg Frost Blade & Storm Shield (awaiting decoration) http://i601.photobucket.com/albums/tt91/Sa...ol/DSC00189.jpg Another 2 for the WolfWing.... Storm Bolter & Wolf Claw: http://i601.photobucket.com/albums/tt91/Sa...ol/DSC00193.jpg Storm Shield & Wolf Claw: http://i601.photobucket.com/albums/tt91/Sa...ol/DSC00192.jpg And another update on Logan.... http://i601.photobucket.com/albums/tt91/Sa...ol/DSC00196.jpg Slowly but surely getting there. Logan is oh so close to being finished: http://i601.photobucket.com/albums/tt91/Sa...ol/DSC00197.jpg http://i601.photobucket.com/albums/tt91/Sa...ol/DSC00198.jpg The start to my 1500pt Power Armour list. Blood Claws Wolf Guard Pack Leader (I have to have this model in every SW army I do), Wolf Priest, 2 Grey Hunters Wolf Guard Pack Leaders http://i601.photobucket.com/albums/tt91/Sa...ol/DSC00210.jpg Link to comment https://bolterandchainsword.com/topic/66089-space-wolf-painting-converting-etc/page/7/#findComment-2121652 Share on other sites More sharing options...
lokeiSHP Posted September 23, 2009 Share Posted September 23, 2009 Hey all, Finally got the first of my repaints done last night: http://farm4.static.flickr.com/3536/3946949534_d62fe15f12_b.jpg http://farm4.static.flickr.com/3509/3946949444_ba3d5dbfa5_b.jpg http://farm3.static.flickr.com/2622/3946949370_50d8fe8ca8_b.jpg http://farm3.static.flickr.com/2498/3946167237_3ce166f823_b.jpg http://farm3.static.flickr.com/2631/3946949256_683d95cca7_b.jpg http://farm3.static.flickr.com/2602/3946949182_d60e1550ee_b.jpg http://farm4.static.flickr.com/3464/3946949056_98926c8a7e_b.jpg http://farm3.static.flickr.com/2513/3946948992_9a8850e8a3_b.jpg One squad down, many to go. You can see the old paint jobs here http://www.flickr.com/photos/18569737@N02/...57614996916359/ Link to comment https://bolterandchainsword.com/topic/66089-space-wolf-painting-converting-etc/page/7/#findComment-2121756 Share on other sites More sharing options...
MaveriK Posted October 10, 2009 Share Posted October 10, 2009 http://i140.photobucket.com/albums/r35/Azn_MaveriK/WarWolves%20WIP/BloodFang-003.jpghttp://i140.photobucket.com/albums/r35/Azn_MaveriK/WarWolves%20WIP/BloodFang-001.jpgS BLOODFANG WIP trend http://www.bolterandchainsword.com/index.p...howtopic=169211 http://i140.photobucket.com/albums/r35/Azn_MaveriK/WarWolves%20WIP/BloodFang-005.jpghttp://i140.photobucket.com/albums/r35/Azn_MaveriK/WarWolves%20WIP/BloodFang-006.jpg http://i140.photobucket.com/albums/r35/Azn_MaveriK/WarWolves%20WIP/BloodFang-002.jpghttp://i140.photobucket.com/albums/r35/Azn_MaveriK/WarWolves%20WIP/BloodFangSize001.jpg He's about as tall as a plastic Wolf Guard Terminator, I'm gonna use this guy as either a warrior of Fenris with the Mark of the Wulfen, a Lone Wolf with Wolf Claws, or a Lone Wolf with the Mark of the Wulfen... more on my BLOG under my signature Link to comment https://bolterandchainsword.com/topic/66089-space-wolf-painting-converting-etc/page/7/#findComment-2145832 Share on other sites More sharing options...
Haakon Ironheart Posted October 17, 2009 Share Posted October 17, 2009 Converted from High Elf Lions, I think it captures the spirit well enough...Lots of Greenstuff to cover the body as fur and actually it was my first try at sculpting sth as a wolf head...I am especially proud of the Rider and his frostblade. I hope you like them both as much as I do!!! http://www.coolminiornot.com/pics/pics14/img4ad199969d8a5.jpg My second Thunderwolf rider. I hope you like him as much as the first one... ;) http://www.coolminiornot.com/pics/pics14/img4adc78037e93d.jpg Link to comment https://bolterandchainsword.com/topic/66089-space-wolf-painting-converting-etc/page/7/#findComment-2154914 Share on other sites More sharing options...
