Gyson_Vore Posted June 15, 2005 Share Posted June 15, 2005 I normalyplay Space Wolves, but I want a different army to use with Witch hunters. The Color scheme is Black Armor with orange and red flames. The Chapter sign is A flaming fist. 22nd Founding Traits and Disadvantages: Cleanse and Purify to Death before Dishonor Home World: The home world is a harsh feral planet, the majority of land mass covered by volcanoes. The people of the planet, Flarose, are nomadic and do not build lasting buildings. They are always moving to escape the sulfuric smog to safe lands, where life can live easier. The tribes rarely use metals, because the heat of the planet would melt it. Instead, weapons fashioned from animal horns. When tribes march to war, they daub their faces in the ash of the volcanoes, hoping to gain the strength of the heat from whence it came. Organization: The chapter is organized into 12 Companies. The Company is headed by a Captain and a group of veterans, instead of just a Captain. The Chapter master is also restricted by these limitations, and leads a conclave of his captains. These groups are known as Guiding Flames. Combat Doctrines: The Chapter believes largely in the purging and cleansing powers of Flamers, and are usually the special weapon of choice. There is recorded pyromania in the chapter, and many of their battle rights and religious ceremonies. Other than that, they follow the Index Astartes closely, but slight divergence exists in their vehicles. Two examples are the Dragoon APC and the Volcano Predator. The Dragoon is a standard Rhino, except in place of the Storm Bolter, they put a Twin-linked Flamer. The Volcano is a Predator with a Multi-Melta mounted in a turret, and Heavy Flamers suspensions. Beliefs: The Order of the Cleansing Flame is part of the Promethan Cult, but their offerings are to the Emperor, and their offerings are sometimes the enimeis that they face. Their Belief is absoulute, and fights with the Ordo Herectus often. Gene Seed: The Gene Seed is that of the Salamanders Chapter, and may explain the affinity for fire. Battle Cry: Link to comment https://bolterandchainsword.com/topic/77270-the-order-of-the-cleansing-flame/ Share on other sites More sharing options...
jimmythemoose Posted June 15, 2005 Share Posted June 15, 2005 It's a good start, just needs some filling out. There is one main problem however. If the planet is hot enough to melt metals wouldn't it be inhospitable for humans? Link to comment https://bolterandchainsword.com/topic/77270-the-order-of-the-cleansing-flame/#findComment-888798 Share on other sites More sharing options...
Gyson_Vore Posted June 15, 2005 Author Share Posted June 15, 2005 It's a good start, just needs some filling out. There is one main problem however. If the planet is hot enough to melt metals wouldn't it be inhospitable for humans? <{POST_SNAPBACK}> I meant the heat caused impurities in the metal, which makes it impossible to smith into anything usefull. Link to comment https://bolterandchainsword.com/topic/77270-the-order-of-the-cleansing-flame/#findComment-888800 Share on other sites More sharing options...
Ferrata Posted June 15, 2005 Share Posted June 15, 2005 Sounds good, but why the 12 chapters? You have some nice traits/personalities but you could do with some more reason behind it. Ferrata Link to comment https://bolterandchainsword.com/topic/77270-the-order-of-the-cleansing-flame/#findComment-888810 Share on other sites More sharing options...
Gyson_Vore Posted June 15, 2005 Author Share Posted June 15, 2005 Sounds good, but why the 12 chapters? You have some nice traits/personalities but you could do with some more reason behind it. Ferrata <{POST_SNAPBACK}> More reason how? Link to comment https://bolterandchainsword.com/topic/77270-the-order-of-the-cleansing-flame/#findComment-888813 Share on other sites More sharing options...
Ferrata Posted June 15, 2005 Share Posted June 15, 2005 More reason how?Why do they have 12 Companies? Why have the created 2 new tanks, when usually most chapters dernt even slightly modify a tank The Gene Seed is that of the Salamanders Chapter, and may explain the affinity for fire If you read the geneseed debate, you might want to change this bit. I would say because they see the awesome effects of volcanoes on their homeworld, they use flamers and meltas in battle Ferrata Link to comment https://bolterandchainsword.com/topic/77270-the-order-of-the-cleansing-flame/#findComment-888819 Share on other sites More sharing options...
schoon Posted June 15, 2005 Share Posted June 15, 2005 The tribes rarely use metals, because the heat of the planet would melt it. <{POST_SNAPBACK}> I don't mean to be a spoil-sport, but as a blacksmith, I'm going to have to say something about this one: heat doesn't spoil metals, nor add impurities. Metal might be rare on the world, but excess heat would actually make it easier to forge or purify what's there. I'd suggest making the planet deficient in metal ores - that would do the trick much better. That would also fit in well with the nomadic, animal-based construction. On other points, by going with 12 companies, you're actually diverging fairly widely from the Codex. There's no reason you can't do it, but just realise that it makes them fairly divergent (in a fluff rather than rules sense). Why do they fight with the Ordo Hereticus? Write some supporting fluff to tell the story of why. Keep at it! Link to comment https://bolterandchainsword.com/topic/77270-the-order-of-the-cleansing-flame/#findComment-888884 Share on other sites More sharing options...
Gyson_Vore Posted June 16, 2005 Author Share Posted June 16, 2005 Does this help with the Ordo Herectus some? "Combat Doctrines: The Chapter believes largely in the purging and cleansing powers of Flamers, and are usually the special weapon of choice. There is recorded pyromania in the chapter, and many of their battle rights and religious ceremonies. Other than that, they follow the Index Astartes closely, but slight divergence exists in their vehicles. Two examples are the Dragoon APC and the Volcano Predator. The Dragoon is a standard Rhino, except in place of the Storm Bolter, they put a Twin-linked Flamer. The Volcano is a Predator with a Multi-Melta mounted in a turret, and Heavy Flamers suspensions. Located near the planet Ophelia VII, this chapter is often recruted into their service because of their faith in the Emperor and beleif in the cleansing power of fire, and will rarely deny allying with them. " Link to comment https://bolterandchainsword.com/topic/77270-the-order-of-the-cleansing-flame/#findComment-889727 Share on other sites More sharing options...
