while bolter was down
daemonclaw
thought i would try showing a couple of things i knocked up while bolter was down,
i am not trying to win any awards for painting :P just trying to make them look good on
the table :blush:
i wanted the apostle body to be bigger than the last one so i carved up a terminator and sacrificed it to the chaos gods who warped his armour
http://i2.photobucket.com/albums/y30/daemonclaw/40knew002.jpg
also here is a tank from his army
http://i2.photobucket.com/albums/y30/daemonclaw/40knew016.jpg
http://i2.photobucket.com/albums/y30/daemonclaw/40knew015.jpg
http://i2.photobucket.com/albums/y30/daemonclaw/40knew014.jpg
http://i2.photobucket.com/albums/y30/daemonclaw/40knew013.jpg
thoughts and constructive criticism welcome
https://bolterandchainsword.com/topic/84650-while-bolter-was-down/
i have seen both these models in "real life" and the pictures really do not do the models justice...
the amount of insane sculpting work that went into that dark apostle is awesome!!! also pay attention to the base!
the flames on the tank are cool and really add to the tank!! also looks great when your staring at it across a ruined cityscape board!!
some really cool stuff...and i know for a fact that you have more crazier s*%t than this to show :blush:
I've never understood why such evil baddasses as the chaos space marines would want to draw flames on their tanks a la fast and furious. I like the apostle though. The tank just doesn't scream menacing to me unfortunately.
I personally like the flames on the tank. :blush:
The apostle is very cool - mind sharing what the main bits are? - you have said a termi ( i assume it is a chaos one to start with )
those shoulder guards specifically look good
the flames on the predator look good as well - only the ones on the main hull at the bottom i dont think look as good as the others do as they dont come in from a hidden edge ( if that makes sense )
hope to see more of this great work
thanks,
L
hey all thanx for the input ^_^ as for the bits it was mainly a plastic terminator stripped of all iconography,
the main body then had the termy collar at the back cut away ,the shoulder pads are plastic imperial as well scraped clean and recessed then all was smothered in greenstuff .storm bolter hand is from new termy chaplain.and the crozius was a storm hammer with chaos icon from fantasy knights sprue ^_^
ps as for the flames ,the idea was about way before fast and furious and even badasses like to further impose their intimidation. after all you dont get a bad reputation from looking pretty ;)
cheers D
