Hello fellow hobbyists,
Before the B&C went down I was asked to do a tutorial on how I converted one of my marines.
This is my very first tutorial so bear with me. It's a simple one but if anything is unclear or can be improved upon, please let me know. :P
HOW TO DE-BUNNIFY KHORNE BERZERKER HELMETS:
Requirements:
-A hobby knife.
-A Steady hand.
-Decent lightning.
-Pliers/clippers.
I strongly recommend that you DO NOT cut towards yourself, but away from you instead. This makes it harder but it's also alot safer. :lol:
-Step 1-
A Berzerker helm and my tool of choice.
-Step 2-
Snip off the ears at a good angle so that you have room to work a bit, with the leftovers.
-Step 3-
Cut down the side of the helmet to clear excess plastic, slowly. The bottom bar indicates approximately where you should stop. (No dont cut into the finger! ;))
-Step 4-
Make your cut into the side of the helmet.
Different angle:
-Step 5-
Carefully scrape off excess plastic. Don't fret and rush this part because one mistake here, will either ruin the helmet or require a little GS work to fix. This step usually takes me 15-20 minutes.
End result:
Different angle (it's not cleaned up yet):
-an example-
Different angle:
-painted version
I believe it's possible to come up with all sorts of new helmet combinations and I hope you will find this little tutorial useful.
-Brother Nihm
Edited by The Angelus Sanctus
https://bolterandchainsword.com/topic/85259-modelling-khorne-berzerker-helmet/
Register a new account
Sign in
