AngelSaphire Posted April 18, 2006 Share Posted April 18, 2006 I used the Winter Assault as base for my Chaplain: http://i31.photobucket.com/albums/c396/InL...ies/58917_3.jpg Now I present my Chaplain: http://i31.photobucket.com/albums/c396/InLovingMemories/DSC02441.jpg http://i31.photobucket.com/albums/c396/InLovingMemories/DSC02438.jpg http://i31.photobucket.com/albums/c396/InLovingMemories/DSC02437.jpg http://i31.photobucket.com/albums/c396/InLovingMemories/DSC02433.jpg http://i31.photobucket.com/albums/c396/InLovingMemories/DSC02439.jpg currently I haven't done anymore because I need help with the metal areas; Im sure most people have seen this lovely GD entry http://img127.imageshack.us/img127/7577/photo24300tj3nk.th.jpg My question is how do I recieve a simillar effect with gold and metal? I've never seen anything like it before. Cheers ~AngelSaphire +++ Edit: oversized picture turned to a link, please refer to the rules of the PC&A for more info. +++ Link to comment https://bolterandchainsword.com/topic/85334-winter-assault-style-chaplain-wip/ Share on other sites More sharing options...
Ardus Posted April 18, 2006 Share Posted April 18, 2006 Not bad. The Chappy in the pic scares me more though. I think you need to remove the pistol holster from the front of his leg, add more seals and do dads. Ardus Link to comment https://bolterandchainsword.com/topic/85334-winter-assault-style-chaplain-wip/#findComment-987275 Share on other sites More sharing options...
Badaab Posted April 18, 2006 Share Posted April 18, 2006 What really scares me about this model is the apparent lack of planning when sticking it together. Remove the mould lines, please. And, in all honesty, mentioning that you'd like a model to inspire fear, and then building a model which is kneeling and pointing simply doesn't do it for me. If he were kneeling over a fallen foe, maybe, but still, he'd be kneeling. Try something with a standing pose, or something more dynamic. If he must be poised over a fallen foe, have him standing over it. -Joe Link to comment https://bolterandchainsword.com/topic/85334-winter-assault-style-chaplain-wip/#findComment-987283 Share on other sites More sharing options...
-Q- Posted April 19, 2006 Share Posted April 19, 2006 I don't see the connection to the DoW model =( Sorry Maybe it's just the pictures. Try to take pictures before you prime or after you paint. Black primer eats light and hides detail. Link to comment https://bolterandchainsword.com/topic/85334-winter-assault-style-chaplain-wip/#findComment-987290 Share on other sites More sharing options...
AngelSaphire Posted April 19, 2006 Author Share Posted April 19, 2006 Hmm, I couldn't remove the mold lines from the arm but I'll try again. Is there anything I could to him in his current pose to make him stand out more? Also I might just edit the post if I completely failed to achieve a Winter-assault styled Chaplain EDIT: And sorry the my Chaplain dissapointed so bad :rolleyes: EDIT 2: I might just drop the whole fear idea and just go for a chappy that looks like the Wintassault version since IMO like the kneeling position Link to comment https://bolterandchainsword.com/topic/85334-winter-assault-style-chaplain-wip/#findComment-987295 Share on other sites More sharing options...
Kaptin Gavrin Posted April 19, 2006 Share Posted April 19, 2006 I think it's the start of an interesting conversion. If you're willing to go through some extra work, it might be an interesting idea to give him a scenic base, and then reposition the legs using wire and GS to make it look like he just leapt down from a higher point, and is pointing to a foe he's preparing to charge. Link to comment https://bolterandchainsword.com/topic/85334-winter-assault-style-chaplain-wip/#findComment-987300 Share on other sites More sharing options...
Hemal Posted April 19, 2006 Share Posted April 19, 2006 Try to actually model your pose yourseld - bend down in his position and se what is and isn't viable for the pose - I think that could be a very good pose for a chaplain, but only in some sort of conext - maybe he is administering last rites to a fallen brethren who is about to be killed by an apothecary as an act of mercy? And yeah, remove the mould lines, that's always easier on a model before ou start conversion work.. A few more srolls, seals, chains etc would help add character. You can use the fol from say a tomato paste tube and stick it on as parchment, and use thin strips with a blob of greenstuff to act as the purity seals if you have no plastic or resin seals spare. There are some great bits omn the marine command sprues as well which you could use, such as the little shrine whoch you could stick to the backpack. Link to comment https://bolterandchainsword.com/topic/85334-winter-assault-style-chaplain-wip/#findComment-987318 Share on other sites More sharing options...
AngelSaphire Posted April 19, 2006 Author Share Posted April 19, 2006 Hmm I'll change him into a more commanding look; like he is directing men into a charge over a fallen brother EDIT: Update: I added more purity seals and cut away more mold lines I found. I didn't add a shrine to his back because it didn't seem to look right anyways; also I adjusted his Croz a bit more upwards so it looks more inspirational http://img217.imageshack.us/img217/1420/dsc024492uu.jpg I hope it's a improvement Link to comment https://bolterandchainsword.com/topic/85334-winter-assault-style-chaplain-wip/#findComment-987353 Share on other sites More sharing options...
Chaplain Desmodus Posted April 19, 2006 Share Posted April 19, 2006 I think it looks good! With the new base you've created a small diorama which is cool, just don't overdo it, simply glueing stuff to the base doesn't really work (been there, done that). It's an unusual pose for a chaplain, but IMO rather effective. The adjusted crozius looks better. I also like the way you've painted the skull helmet, very menacing. The metallics effects you mentioned can be emulated by painting the metallics on (perhaps starting with a base coat of tin bitz, then mixing tin bitz and boltgun, then adding mithril to the mix on two or three steps)and then carefully painting several layers of thinned inks over them (I would start with a 10:1 ratio of water:ink). Browns, greens, purples and blue can be used, you might want to stay away from adding black though, as it can kill the colour (unless you want a duller, more shadowy look of course). Link to comment https://bolterandchainsword.com/topic/85334-winter-assault-style-chaplain-wip/#findComment-987470 Share on other sites More sharing options...
Brother Redemption Posted April 19, 2006 Share Posted April 19, 2006 I liked it first time round and it looks even better now. I do think you've captured the look from the Winter Assault chaplain. Link to comment https://bolterandchainsword.com/topic/85334-winter-assault-style-chaplain-wip/#findComment-987475 Share on other sites More sharing options...
AngelSaphire Posted April 22, 2006 Author Share Posted April 22, 2006 Huge update: http://i31.photobucket.com/albums/c396/InLovingMemories/DSC02457.jpg http://i31.photobucket.com/albums/c396/InLovingMemories/DSC02456.jpg http://i31.photobucket.com/albums/c396/InLovingMemories/DSC02455.jpg http://i31.photobucket.com/albums/c396/InLovingMemories/DSC02454.jpg http://i31.photobucket.com/albums/c396/InLovingMemories/DSC02453.jpg I hope he's better now for you guys :P been painting him non-stop :) Link to comment https://bolterandchainsword.com/topic/85334-winter-assault-style-chaplain-wip/#findComment-989639 Share on other sites More sharing options...
Cubeface Posted April 22, 2006 Share Posted April 22, 2006 That's looking really good so far. I like how you matched the bass to the theme of the games (i.e. snow). Don't forget to close that green paint. :P --cubface Link to comment https://bolterandchainsword.com/topic/85334-winter-assault-style-chaplain-wip/#findComment-989652 Share on other sites More sharing options...
dex_911 Posted April 22, 2006 Share Posted April 22, 2006 I reckon he looks good. The snow looks pretty good to me too. Overall i really like it, and i think you captured the spirit of the WA Chappie very well. Good job dex Link to comment https://bolterandchainsword.com/topic/85334-winter-assault-style-chaplain-wip/#findComment-989660 Share on other sites More sharing options...
Chaplain-Azriel Posted April 22, 2006 Share Posted April 22, 2006 Well done! im a hug fan of the new chappy, nice paintjob as well :jaw: Link to comment https://bolterandchainsword.com/topic/85334-winter-assault-style-chaplain-wip/#findComment-989728 Share on other sites More sharing options...
Brother Redemption Posted April 22, 2006 Share Posted April 22, 2006 Its looking v. good. I like the pose and paintjob. Link to comment https://bolterandchainsword.com/topic/85334-winter-assault-style-chaplain-wip/#findComment-989780 Share on other sites More sharing options...
