tagsta Posted April 23, 2006 Share Posted April 23, 2006 /edit here is the improved version feel free to correct language and grammar mistakes. my english is not perfect B) Tagsta's Lava Base Tutorial This Tutorial is supposed to be a basic method to create a high number of good looking lava bases in a rather short time. If you follow these 6 Steps you can easily base your whole army in a lava theme. A higher standard for Showcase Minis is also possible. Just practise the Basic Tutorial a little bit and then try the same thing with a larger amount of colours. Enough talking, let's begin: ROCKS: black undercoat drybrush with codex grey drybrush again with fortress grey LAVA: http://i3.photobucket.com/albums/y68/Tagsta/Warhammer40k/tutorial.jpg the basic colour for the lava spots is red gore (STEP 1) paint the red gore undercoat with spots of blood red (but leave a rim red gore visible) (STEP 2) continue the procedure with... ...blazing orange (STEP 3) ...golden yellow + bad moon yellow (STEP 4) and eventually add a tiny spot of white in the center of the lava (the hottest spot) (STEP 5) the basic lava base is done! quite easy, isn't it? Advanced Lava (Source Lightning) (STEP6) You can add a Source Lightning effect to the stones, if you like to... Imagine the tiny lava bubbles as the light source... Drybrush a large circle of red gore on the rock. Add a smaller circle of blood red. add another small circle of blazing orange add an even smaller circle of golden yellow... You're done. congratulations greetz tagsta Link to comment https://bolterandchainsword.com/topic/85588-basing-painting-a-lava-base/ Share on other sites More sharing options...
StratoKhan Posted April 23, 2006 Share Posted April 23, 2006 The effect is very spectacular indeed. Well done. Maybe if the Tut. was more elaborate/organised better it would be even more useful? Like with Step 1, Step2... But still, good illustrative pics, and it's concise, so nice job. Link to comment https://bolterandchainsword.com/topic/85588-basing-painting-a-lava-base/#findComment-990388 Share on other sites More sharing options...
Brother Redemption Posted April 23, 2006 Share Posted April 23, 2006 I like the effect. Especially the glow on the rock. That looks v. cool. Link to comment https://bolterandchainsword.com/topic/85588-basing-painting-a-lava-base/#findComment-990400 Share on other sites More sharing options...
Ahmato Posted April 23, 2006 Share Posted April 23, 2006 How did you paint the glow effect on the rock? Link to comment https://bolterandchainsword.com/topic/85588-basing-painting-a-lava-base/#findComment-990407 Share on other sites More sharing options...
Brother apocalyptic Posted April 23, 2006 Share Posted April 23, 2006 drybrushing I presume, thats what I used when I did a lava base... Link to comment https://bolterandchainsword.com/topic/85588-basing-painting-a-lava-base/#findComment-990424 Share on other sites More sharing options...
Obliterator Posted April 23, 2006 Share Posted April 23, 2006 Very nice tutorial Link to comment https://bolterandchainsword.com/topic/85588-basing-painting-a-lava-base/#findComment-990438 Share on other sites More sharing options...
SkyTalon Posted April 23, 2006 Share Posted April 23, 2006 Sweet Tutorial! I may just start using Lava Bases for my own models... :) Is that Slate your using for the rocks? Any idea where you can get small amouts of that stuff? 'Cuz last time I found some it was in a huge bag--way to heavy for me to carry by myself, and it had so much in it that it was kind of obvious I'd never use it all lol B) Thanks, SkyTalon Link to comment https://bolterandchainsword.com/topic/85588-basing-painting-a-lava-base/#findComment-990448 Share on other sites More sharing options...
FireLizard Posted April 23, 2006 Share Posted April 23, 2006 For the slate I use on my bases I just went to the local Hardware store and picked up araw slate tile from the flooring section. Then take a hammer to it B) It'll cost you maybe 3 bucks and you'll get nice, random shapes. Of course.. the only problem wiht that is you often get nice, random shapes :) The result is usually about 70% of the chips and pieces I can use, about 30% are etiher Just too big, but not big enough to be broken again or "dust in the wind"-small. Link to comment https://bolterandchainsword.com/topic/85588-basing-painting-a-lava-base/#findComment-990452 Share on other sites More sharing options...
Ahmato Posted April 23, 2006 Share Posted April 23, 2006 BTW, what do you use to stick the slate onto the base? Link to comment https://bolterandchainsword.com/topic/85588-basing-painting-a-lava-base/#findComment-990481 Share on other sites More sharing options...
tagsta Posted April 23, 2006 Author Share Posted April 23, 2006 I like the effect. Especially the glow on the rock. That looks v. cool. a source lightning technique from CMON... Pick the bubbles as the light centre. Drybrush the rock with red tones in a wide circle Continue that procedure with the same colours that I described above. make sure that you leave shades of the darker colour tones visible. hope that that quick description it is understandable Is that Slate your using for the rocks? No. I used Polystyrene and did a little carving work. Link to comment https://bolterandchainsword.com/topic/85588-basing-painting-a-lava-base/#findComment-990540 Share on other sites More sharing options...
Emperors Servant Posted July 21, 2006 Share Posted July 21, 2006 nice lava, but evry time i try to do it when i put the yellow over the red it stands our realy bad and dosent look good. any help would be great Link to comment https://bolterandchainsword.com/topic/85588-basing-painting-a-lava-base/#findComment-1060375 Share on other sites More sharing options...
tagsta Posted July 21, 2006 Author Share Posted July 21, 2006 nice lava, but evry time i try to do it when i put the yellow over the red it stands our realy bad and dosent look good. any help would be great did you skip the orange part? Link to comment https://bolterandchainsword.com/topic/85588-basing-painting-a-lava-base/#findComment-1060384 Share on other sites More sharing options...
Emperors Servant Posted July 21, 2006 Share Posted July 21, 2006 nope, the yellow is just so much brighter Link to comment https://bolterandchainsword.com/topic/85588-basing-painting-a-lava-base/#findComment-1060392 Share on other sites More sharing options...
tagsta Posted July 21, 2006 Author Share Posted July 21, 2006 nope, the yellow is just so much brighter did you leave some orange visible? could be the reason... a pic would be useful Link to comment https://bolterandchainsword.com/topic/85588-basing-painting-a-lava-base/#findComment-1060412 Share on other sites More sharing options...
tagsta Posted July 21, 2006 Author Share Posted July 21, 2006 I just edited the first post with the updated version feel free to correct any language/grammar mistakes greetz Link to comment https://bolterandchainsword.com/topic/85588-basing-painting-a-lava-base/#findComment-1060430 Share on other sites More sharing options...
