Raejin99 Posted May 14, 2006 Share Posted May 14, 2006 I've had this idea for a conversion for my BT terminators ever since I had seen the BT sprues. I wanted to use the torsos with the talbards on them and try to use them on the termi torsos. I was wondering if anyone else here has tried this, and can tell me how the torsos line up with each other. Link to comment https://bolterandchainsword.com/topic/86871-bt-termi-conversion-idea/ Share on other sites More sharing options...
Freakiq Posted May 14, 2006 Share Posted May 14, 2006 It'll require some cutting but once you get it to fit it looks awsome. :tu: Link to comment https://bolterandchainsword.com/topic/86871-bt-termi-conversion-idea/#findComment-1005955 Share on other sites More sharing options...
Marshal Draziel Posted May 14, 2006 Share Posted May 14, 2006 I've tried it - and with a bit cutting, it looks quite good! even when you use the knight helmets with it! I'd post pics, but they're not painted... prob wont be either... All in all - it can look great or bad... it's up to your own converting skills - but I can recomend that you try Link to comment https://bolterandchainsword.com/topic/86871-bt-termi-conversion-idea/#findComment-1005956 Share on other sites More sharing options...
The Defiler Posted May 14, 2006 Share Posted May 14, 2006 This link might help you: http://fr.games-workshop.com/40k/space_mar...nator/index.asp Explainations are in French, but pics don't need explainations. The Def' Link to comment https://bolterandchainsword.com/topic/86871-bt-termi-conversion-idea/#findComment-1005995 Share on other sites More sharing options...
Master Chaplain Astador Posted May 14, 2006 Share Posted May 14, 2006 I did it as well. On the one with the Crusader Seals going down each side you have to trim the edge because the legs get in the way. Actually just this weekend I started painting the squad. I'll post pics when I can. Cheers, MCA. Link to comment https://bolterandchainsword.com/topic/86871-bt-termi-conversion-idea/#findComment-1006004 Share on other sites More sharing options...
Marshal Pentacost Posted May 14, 2006 Share Posted May 14, 2006 I did mine with a strip of 1mm plasticard between the fron and back peces, makes them look just a bit more bulky. Link to comment https://bolterandchainsword.com/topic/86871-bt-termi-conversion-idea/#findComment-1006140 Share on other sites More sharing options...
Raejin99 Posted May 15, 2006 Author Share Posted May 15, 2006 Thanks for all of the help. This link might help you:http://fr.games-workshop.com/40k/space_mar...nator/index.asp Explainations are in French, but pics don't need explainations. The Def' That's perfect, exactly what I was looking for. Thanks! Link to comment https://bolterandchainsword.com/topic/86871-bt-termi-conversion-idea/#findComment-1006822 Share on other sites More sharing options...
ale0x Posted May 15, 2006 Share Posted May 15, 2006 http://tmb.hkbo.net/wh40k/squadbarak1.jpg Link to comment https://bolterandchainsword.com/topic/86871-bt-termi-conversion-idea/#findComment-1006852 Share on other sites More sharing options...
