rabblerouser Posted May 14, 2006 Share Posted May 14, 2006 Sometimes if you sand with a file or scrape with the back of a knife, you leave behind a trail of "fuzzy" plastic bits that cling to the plastic piece What do you use to remove this? Link to comment Share on other sites More sharing options...
Brother Gothard Posted May 14, 2006 Share Posted May 14, 2006 I use my iron lungs and blow hard on them. Seriously. Either your knife isn't sharp enough, or you need to exercise more to get stronger lungs. It's more likely to be the first one - the dull knife. Link to comment Share on other sites More sharing options...
Lord_Maggot Posted May 14, 2006 Share Posted May 14, 2006 I have the same problem even with a new knife blade. My solution is an old tooth brush I have handy. Quick scrub and it's cleaned up real easy. Hope it helps :D Link to comment Share on other sites More sharing options...
Callas Posted May 14, 2006 Share Posted May 14, 2006 Edge of the finger usually works.... :D Link to comment Share on other sites More sharing options...
mario Posted May 14, 2006 Share Posted May 14, 2006 See above plus: - Airbrush (without paint) - water but you need to dry the minature later - the tip of your modeling knife - sculpting tools - a bit of green stuff on a stick (it's sticky) Link to comment Share on other sites More sharing options...
marcus Posted May 14, 2006 Share Posted May 14, 2006 If my lungs are not up to the job, I have a canister of air spray with a little straw in the nozzle, gets rid of most unwanted bits of plastic pretty quick :D . Link to comment Share on other sites More sharing options...
Ahmato Posted May 14, 2006 Share Posted May 14, 2006 A vacuum cleaner. No seriously, get the old Dyson out and suck off all the Debris, works good on dust too, just don't let go of the model :D Link to comment Share on other sites More sharing options...
Coop_DH Posted May 14, 2006 Share Posted May 14, 2006 i can imagine it now...sucking up all that debre from one of your soon-to-be prize possetions and then all of a sudden "woosh" its in the vacume :blink: Link to comment Share on other sites More sharing options...
ionfish Posted May 14, 2006 Share Posted May 14, 2006 I find the following process works well for both metal and plastic miniatures. 1) Clean the flash etc. off the miniature with a sharp knife or scalpel and needle files. Make sure you clean the files regularly or they'll get clogged and won't do their job properly. 2) A bit of abrasive cloth will give you a smoother finish. 3) Brush off any dust with a toothbrush (you can get cheap ones at your local supermarket). 4) Wash the miniature in warm water, scrubbing it with a clean toothbrush (i.e. not the same one you've just used to remove the dust). 5) Let it dry thoroughly before doing anything else with it. Hairdryers help. And there you have it: a smooth, clean miniature free of gribbly bits and ready for priming. Link to comment Share on other sites More sharing options...
MaimKillBurn Posted May 14, 2006 Share Posted May 14, 2006 I would usually just pick away at the plastic fuzzies with a small knife if they're in a tight spot. Other than this, as mentioned before, I'd just blow all the fuzzies off. I know what you mean, it's especially fuzzy for me when I file plastic :rolleyes: . Another thing you might consider is taking a piece of paper and cupping the edge to make a spoon type tool for getting into those nasty spots chalked with fuzz (such as between an arm and a shoulder pad). Link to comment Share on other sites More sharing options...
flyinghippo Posted May 15, 2006 Share Posted May 15, 2006 Ive had a similar problem but it's only on the gun barrels. What do you use for those? Link to comment Share on other sites More sharing options...
Beornling 3.1415 Posted May 15, 2006 Share Posted May 15, 2006 Edge of the finger usually works.... :ph34r: I was going to say, thumb or a damp piece of leather cloth..... Link to comment Share on other sites More sharing options...
