mortiferum Posted May 26, 2006 Share Posted May 26, 2006 UK Plasticard / Plastikcard / Styrene sheet availability? I Link to comment https://bolterandchainsword.com/topic/88021-uk-plasticard-plastikcard-styrene-sheet-availability/ Share on other sites More sharing options...
Iron-Daemon Forge Posted May 26, 2006 Share Posted May 26, 2006 Is there no hobby, model or Art shops near by you???? As for what type, I'd recommend 1mm & 0.5mm are you best type to use & also easyer to cut with a blade. While 2mm+ you will be there for some time. Just any near by art store should do it, check the yellow pagies or google. IP Link to comment https://bolterandchainsword.com/topic/88021-uk-plasticard-plastikcard-styrene-sheet-availability/#findComment-1015574 Share on other sites More sharing options...
Hemal Posted May 26, 2006 Share Posted May 26, 2006 Most model or hobby shops will sell it - it's pretyy mcuh stock for rail-model collectors Link to comment https://bolterandchainsword.com/topic/88021-uk-plasticard-plastikcard-styrene-sheet-availability/#findComment-1015580 Share on other sites More sharing options...
mortiferum Posted May 26, 2006 Author Share Posted May 26, 2006 Hmm, there is a specialist model railway shop not far from where I work, never thought of looking there? :( I'll try, incidentally what do model railway enthusis (sp) use it for? Thanks Morty Link to comment https://bolterandchainsword.com/topic/88021-uk-plasticard-plastikcard-styrene-sheet-availability/#findComment-1015720 Share on other sites More sharing options...
