Painting Project
hey all
im painting a land raider for my local gamestore painting contest and i want to do everything i can to win :P
i was hoping to get all the advice and painting tips that i can get that will help me get up in the standings..
it is due by the 30th of june so i dont have much time
i already know it will include flames (maybe ghost rideresck treads)and i am gonna use the tutorial i found on B&C for allowing doors to open and close
i want to try and sculpt ghostly hands, weapons, etc coming out but i know how long that will take
any help i can get will be so greatly appreciated thanks
will try and post pics if i can get digi working right
https://bolterandchainsword.com/topic/88337-painting-project/
Well, you already have a opening ramp on the front, the side doors have bad visibility inside, so it's more an issue if you want a "lego" land raider or not. By "lego" I mean a tank that has all parts movable etc, sorta like a toy you can push around on the floor and make "wroom" sounds with. ;)
If you want to "win" the competition, then opening doors should be last on your list. Convert the model, if you want to get extra points for imaginative ideas, but a land raider can win ANY contest if you paint it well, since it has large surfaces ideal for freehand stuff and whatnot.
Anyway, get to work on your ghost hands and stuff, and post some WIPs if you really want help. If you keep it all theoretical and just talk about what you "want" to do, people will lose intrest in the thread.
Cheers
By "lego" I mean a tank that has all parts movable etc, sorta like a toy you can push around on the floor and make "wroom" sounds with. :jaw:
Hil-A-rious ;)
It would only take some rubber treads, slightly remodelling the interior and addin ball bearings on the inside.
All my landraiders have treads glued to them, but i might just do that to a rhino or bike squad.
thanks for the idea :P
-t14
Yeah, I'm working on a specialised army land raider, but I'll clue you in on a cool idea I'm doing. Take the crusader frag launchers, cut the skully part off as well as filing down the launchers. Plasticard over these, and have one that "juts out" like a platform. On the lascannon sponsons, take the hurricane bolter shieldy things (the big side parts with the winged skulls) and do the same thing, make a platform along the bottom of both. This makes perfect "mounts" for army themed soldier statues. Attach a model to evry mount, paint it brass and finished! Oh, and Dark Elf cauldron of blood candles are great accents for the creepy motif you're no doubtedly going for. Hope that helps, good luck!!!
