Basing: Simple Snow Base
Here is one of my snow bases
http://i42.photobucket.com/albums/e342/Zain1234/snow.jpg
http://i42.photobucket.com/albums/e342/Zain1234/snow2.jpg
and this is how you make them
1.) mix space wolf grey to pva glue 1:10 and then stir baking soda /power to make a paste.
2.) Pile the paste onto your base and then sprinkle more bakeing soda on top of this.
3.) when dry glaze with more pva
and that's it a fraction of the cost of the gw rubbish and i feel looks ten times better.
hope this has helped
zain
https://bolterandchainsword.com/topic/88538-basing-simple-snow-base/
yes, you can do windowsills and such with this method as well, the more baking soda you have, the thicker it will be, so it wont drip off too easily. It also shrinks a bit when it dries and leaves "frost" lines of where it started which add to the effect. I just "finished" doing my tau army with this method and did the tops of barrels and other debris with snow quite nicely.
A clear coat will help hold it on as well
-Legacy40k
  • 3 years later...
A big thing with snow bases is that i've had an extremely tough time keeping a model ON TOP of snow. So either it's glue to the base and snow around the feet or make a spacer under his feet at the same level as the snow to make him look like he's walking on top of it. Generally my model would break off the top with huge chunks of snow on his feet. Just my imput. :) Nice job mate
  • 2 months later...
  • 1 month later...
  • 6 months later...
  • 1 month later...
A big thing with snow bases is that i've had an extremely tough time keeping a model ON TOP of snow. So either it's glue to the base and snow around the feet or make a spacer under his feet at the same level as the snow to make him look like he's walking on top of it. Generally my model would break off the top with huge chunks of snow on his feet. Just my imput. :rolleyes: Nice job mate
You're forgetting though. Any one of these army foot soldiers with all their armor, wargear, and equipment, likely weigh upwards of 300 pounds for IG and probably 700+ undoubtedly for marines. They'll definitely be punching through the top layers of any snow field. (Ice is a different matter, but we're talking about snow.)
  • 1 month later...
  • 3 months later...
A few things to avoid as well, if you use a spray on gloss varnish apply the 'snow' to the base after the gloss coat and apply a spray on matte varnish. Most matte varnishes (I use Krylon in particular) will have an anti-yellowing agent that will keep the 'snow' looking pristine.
Another thing other may want to consider is adding in a drop or two of the Asurmen Blue wash. If you've ever seen fresh snow on a sunny day, the shadows casted by the snow are a light blue. The Asurmen Blue helps create this effect. If you'd like to attain that sparkle that real snow has, a small drop of Vallejo's Chainmail Silver mixed in with the paste can give it a nice sparkle.
Also, when moving the snow around the base, especially in harder to reach areas, use a small brush that you can moisten with clean water. This will make the paste a little bit more glue-like and you'll have an easier time moving it about.
