Boltman Posted June 3, 2006 Share Posted June 3, 2006 I'm in the planning stage of an Urban gaming table, with 2x2 modular base boards, and movable buildings on mdf boards. I do not have simple access to a GW store, and I would liek to know: How wide are the plastic GW new building tiles and walls? For instance, how wide in inches is a building (4 walls) that is 2 floor tiles wide by 3 tiles long? I need dimensions to plan sidewalks and such. Thank you in advance, Boltman Link to comment https://bolterandchainsword.com/topic/88909-city-of-death-buildings-dimensions/ Share on other sites More sharing options...
Luther - the fallen Posted June 3, 2006 Share Posted June 3, 2006 The floor tiles are 5,5x5,5 cm and a standard wall is 5,6 cm wide and 7,8 cm tall the aquila door is 9,4 cm wide and 7,8 tall... hope it helps... Luther.. Link to comment https://bolterandchainsword.com/topic/88909-city-of-death-buildings-dimensions/#findComment-1022544 Share on other sites More sharing options...
Boltman Posted June 3, 2006 Author Share Posted June 3, 2006 Yes, thank you. But when two walls are assembled in a corner, do they meet at the tip, or one wall is inbedded in the rear of another to make a corner? Are tehre corner pillars? Boltman Link to comment https://bolterandchainsword.com/topic/88909-city-of-death-buildings-dimensions/#findComment-1022559 Share on other sites More sharing options...
major buzzmore Posted June 4, 2006 Share Posted June 4, 2006 Hi Boltman, There is no corner 'mitre' the walls just butt up against each other. I hope that helps, if you building are going to be anything like your minis, these buildings will be awesome !! Also if you are after specific building pieces, just check out the link in my sig. Cheers Buzzzmore Link to comment https://bolterandchainsword.com/topic/88909-city-of-death-buildings-dimensions/#findComment-1022871 Share on other sites More sharing options...
madscuzzy Posted June 4, 2006 Share Posted June 4, 2006 The heights per panel in simple numbers are... 2"x3". The large door is 2 panels worth. Platforms are 2" square per panel and sadly balcony walls are 2cm for accuracy...:o Link to comment https://bolterandchainsword.com/topic/88909-city-of-death-buildings-dimensions/#findComment-1022917 Share on other sites More sharing options...
