A quick question about green stuff
I am about to start bulking up the legs for my daemon prince and I would like to know how to make the green stuff smooth and straight.
Like in this example (which is great because I am working with a obliterator for a base allso)
http://www.prophet-miniatures.com/gallery/...ize/typhus1.jpg
or
http://www.prophet-miniatures.com/gallery/...nurglelord1.jpg
**EDIT: Images changed to links. Please make sure you are following forum rules and not hotlinking to sites that are not yours.**
https://bolterandchainsword.com/topic/89208-a-quick-question-about-green-stuff/
Yes thats how you make smooth as for straight here is what I would do.
Fill out the leg with GS but leave make it about 1mm to thin. Do worry and the smoothness here as it isn't important. Let that cure. Next get somthing flat (plate ect) and cover it in oil. Place a ball of GS on the plate and keep rubbing it with you fingger until its smooth and about 1mm thick. Leave it for a while (15 mins) then cut it to shape with a sharp tool but make sure its wet. The simply pick it up and wrap it around the leg (work out the measurements of the leg first). Fix and funger prints by rubbing it and it should be prefect.
Hope that helps
~zbo
