schoon Posted June 10, 2006 Share Posted June 10, 2006 (edited) After reading Elusive71's article here, I had to give it a try. I started with: 1 Winged Skull torso front 1 Winged Skull-and-Crossbones torso front (for the abdomen) 1 regular torso back http://i4.photobucket.com/albums/y136/schoon9953/Torso1.jpg First, I cut the abdomen and belt off of A and the inverse portion off of B, leaving only the belt and abdomen. Then, instead of using a sheet of spacer (because the joint line for the torso pieces is actually very curvy), I glued a piece of 0.03 inch styrene strip onto C, and then glued A onto the spacer. Getting the abdomen and belt of B to fit right took a few test fits with sanding in between stages. Carefully cut off the buckle with a razor blade before gluing B into place. (It's much more difficult if you forget like I did :) ) http://i4.photobucket.com/albums/y136/schoon9953/Torso2.jpg I then glued the buckle back in place, but lower for the "double thickness" belt, and used it as a base for gluing on a strip of 0.02 x 0.06 inch styrene strip. Then I used green stuff to fill in all the gaps and to fix any bad casting problems. Locations of note: Gaps in the sides of the collar The side "seam" at the top of the belt (which appears to be a slightly bad cast) Extending the buckle hardware for the double-wide belt I used the extra GS to partially fill in the bottom of the torso (where the legs will fit) to make the leg portion of the task easier. http://i4.photobucket.com/albums/y136/schoon9953/Torso3.jpg It'll need a little sanding after the GS cures completely, but the torso is essentially done. Later... Legs! Edited July 13, 2009 by The Angelus Sanctus Link to comment https://bolterandchainsword.com/topic/89369-modelling-true-scale-marine/ Share on other sites More sharing options...
Sternhammer Posted June 14, 2006 Share Posted June 14, 2006 Looks good so far, Keep it up, how are the legs coming? Sternhammer Link to comment https://bolterandchainsword.com/topic/89369-modelling-true-scale-marine/#findComment-1030725 Share on other sites More sharing options...
Freebooter Posted June 14, 2006 Share Posted June 14, 2006 Looking really good. I remember i found on a forum somewhere (I'll try and find it), a guy started by adding a truescale squad to his radical DH army. It looked really cool seeing the marines being visibly bigger than the humans. Link to comment https://bolterandchainsword.com/topic/89369-modelling-true-scale-marine/#findComment-1030776 Share on other sites More sharing options...
Brother Gothard Posted June 14, 2006 Share Posted June 14, 2006 Woah! Sweet idea to bulk out only the chest vs the whole upper body. I'm SO stealing that for my deathguard. Link to comment https://bolterandchainsword.com/topic/89369-modelling-true-scale-marine/#findComment-1030782 Share on other sites More sharing options...
