lighten up inks
Too dark for what? Do you use the ink as a basecoat, for washing, to add shine, or what exactly?
A general tip if an ink is too dark. Use normal paint and thin that. If you mix ink with normal paint then you will lose the inks properties after you add a high amount of normal paint. So you could add a bit of white if you want but that would probably not work as expected. Rather get some purple paint mix it with some grey or white and thin that to a consistency that makes glazes possible.
