castellan avalon
ok last one i promise! :P
here is my second hq for the army...tried mixing new with old...(those old lightning claws still rock :P )
the head will be changed for a head from the empire knight sprue... but what do you think?? too much?..not enough???
cheers for any and all comments
http://i2.photobucket.com/albums/y2/chaplainmortis/v4.jpg
http://i2.photobucket.com/albums/y2/chaplainmortis/v3.jpg
http://i2.photobucket.com/albums/y2/chaplainmortis/v2.jpg
http://i2.photobucket.com/albums/y2/chaplainmortis/v1.jpg
http://i2.photobucket.com/albums/y2/chaplainmortis/v.jpg
https://bolterandchainsword.com/topic/89858-castellan-avalon/
Just remember to throw the grenade on three. One, two, five" no three sir" awe right, three it is*BOOM* gotta love monty python :D
looks good from the sides but the loincloth just doesn't look right, it just detracts from the mini, it's a bit too big, other than that it's pretty good.
Good to see someone still using the old style lightning claws. I was so sad when they put out the new terminators with those hideous lightning claws.
But, like the others said, the shoulder pads do look a tad small. You could beef the metal shoulders up with plasticard or try to remount them on the plastic shoulders.
Just an extra idea, although its semi based in general look. Excluding the idea of the Lightning Claws (man i still love the old ones vs the new 'knuckle busters') you could remove the small targeter thats on top of the armor as well since the model is geared for HtH (i assume the target helps for ranged weapons, although i guess in saying that they would also act as a sensor array of sorts). Alas, it is up to you on that idea, the model will look good with or without it.
hey all
cheers for the replies..
i think i will add some platicard to the shoulder pads to bulk it out as you have all mentioned :) ..prob make some shrapnel guards...should do the trick
the head is being replaced...just chucked that one in there so it didnt look to odd when your viewing the pics.
as for the "holy orb"...well nothing anywhere actually says its the "holy orb of antioch" to me its just decoration.. but i can see how funny it would look as a grenade stuck above his head ;) .. :devil: so might just replace that :)
nice to see a debate on the merits of new/old lightning claws
Looks good. Clean up the claws and either bulk out the shoulders with plasticard or consider using the new Terminator shoulder pads with the old lightning claws. I'd take off the Holy Orb of Antioch - just looks too goofy. Maybe use a generic Aquila or a Templar cross or something instead. The little script/unrolled scroll/thing on the side of his arm just looks out of place, consider removing that.
Do you plan on using the Empire knight head with the laurels? That should look pretty cool, although the current head looks good too.
