Paint Extender?
Hi scar weaver, Ive used the Vmc drying retarder on a few occasions, Its a thick semi gel like stuff that takes a little time to work into your chosen colour but is remarkably good at - well, extending paint :lol:
So far the best way iv'e found of using it is to stick a blob on your pallette and thin it about 50/50 with water, then add as much to your paint as needed. Be warned though it can take a Looong time to dry.Naturally. Hope this helps.
https://bolterandchainsword.com/topic/90835-paint-extender/#findComment-1045641
You should mix it with the paint on your palette. Most are made for non-miniaure painting and are a bit thicker. So they are not a thinning medium and tend to mak the paint glossy. You should forst find out how long a specific ratio stays wet. If you use too much drying retarder then your paints could stay wet for hours. And then you could justsue oil paints instead. The best use for that stuff is in my opinion to add just a little bit when painting little details where you use a small brush. The small size of the brush doesn't carry that much paint so it can dry faster on the brush and leave you with nothing to paint when you have moved the brushover to the miniature.
https://bolterandchainsword.com/topic/90835-paint-extender/#findComment-1045643
