Land Raider Prometheus with dozer blades
Hyperion
I've got round to trying out my idea for LR dozer blades using the 'new' IG vehicle sprue.
I haven't seen many LRs with dozer blades, and I don't remember seeing this done anywhere before (the Golden Daemon winner used the old dozer blades) - but that's not to say it hasn't. I'd be interested to know if anyone has already done this, and general opinions.
++EDIT++ See post 21 for new pics. :D
Hey, that looks really nice! I do agree that you need support on the ramp side, looks like it would collapse inward while the LR is driving. I have an idea, but it's complex. Have the whole dozer blade, over the ramp and everything, but have the middle part fold outward when the ramp opens. Kinda like this:
_\----/_ (Ignore the hyphens, those are for formatting purposes)
Iono, if you have the resources and craftiness, it might be worth a try to depict that.
I should have mentioned that the idea is for one of these on each side, with no dozer blade in the middle. I think the dozer blades are only required to protect the tracks, which lets the ramp drop unimpeded (like the GD winner).
Because the blades are fairly short, to me it looks like a single set of pistons per blade is enough, but the consensus so far is that it should have extra support. The great thing is that at the moment it only uses the standard dozer blade, and I don't want anything too extravagant. Do you reckon that running a length of sprue diagonally behind the blade would look suitably reinforced?
That Land Raider will still be stopped by a few sturdy trees; it needs a dozer blade in the middle.
Hmm, I'm stuck!
The reasons I originally wanted dozer blades in front of only the tracks were: 1) the Land Raider is huge and well armoured, so not much will stop it (including trees! ^_^ ) but the rules mention throwing a track, which is a weak point; 2) the assault ramp needs to be clear; and 3) it needed to be relatively simple and not totally alter the front of the LR.
It now looks like this:
I've added an extra piston to adjust the angle of the blade:
Unfortunately, the new pistons look rather weedy in these pics (they look better real than in the pics - often the way!) but my massive bits box has spectacularly failed to provide any alternative! :)
I was hoping to add dozer blades to all my LRs, but I had to scavenge these pistons from lascannon sponson mountings (from a LRC, so I don't need them) but I'd have to buy an extra sponson sprue for each LR to keep doing this! I'm also not sure if I should try and replace the pistons with something more substantial, or leave it alone.
I'm not keen on trying to add a central blade, because any pistons that will fit the space will not match the ones at the sides, and it'll look too unbalanced.
Oh well, my other LRs are going to be Black Templars, so they'll just have to do without (they'll be too busy charging at the enemy anyway!).
++Edit++
I've just checked and that sprue is
It looks stunning :(
If you go to a hobby/railroad store, you can often pick up brass tubing in a myriad of diameters.
Get a tube that fits snugly inside a larger tube. Instant piston at whatever diameter you need at a mere pittance.
Consider angling the blades very slightly away from the centerline from the tank. This will make it look like it can smash through obstacles rather than push at them.
Cheers
-t14
Why not make it like the blade on a real bulldozer, have one blade running all the way accross the front and have the "arms" of the blade go part way down the side of the landraider. The whole blade could then be lifted up above the ramp.
I'm liking this idea so much I may have to go buy a landraider
Edit, just found this
DA Land Raider
Q EDIT: Corrected Link
well the problem is guys, if he goes for one huge blade he's gonna lose the front assault ramp! I have to say it looks VERY good for what you're trying to achieve (especially with all the forge world stuff), BTW is this particular land raider going to be a prometheus pattern? I'm asking because the front armor looks like the one my friend has and his is a promey.... cool idea *steals*.
Gotta say it'll look splendid when it's done, mad props man. :)
Err?
Err?
Like the DA Land Raider in the link, Q.
Thanks for all the replies and suggestions. I tried a few more options yesterday, and nothing seemed to work, so I ended up chatting with my brother last night (he's an engineering student) and in the end we agreed that the dozer blades as they are would work perfectly well for their purpose. Talk about coming full circle.
Just a few final thoughts:
1. the 'attitude control' diagonal piston would not need to be as hefty, because the main force would still go through the larger pistons.
2. the blades are short enough relative to the side pistons not to need any other reinforcement.
3. it's not a minesweeper - the dozer blades are just there to prevent damage to the tracks from debris (I did try adding a blade under the ramp but it didn't work!).
4. the 'attitude control' piston looks like it could extend the blades forwards (to more of an angle) which would be useful to move sand, etc... (currently it's set up to deal with rubble, which needs more flat-on shoving than channeling sideways).
5. looking more closely at the setup of the pistons, you could drive the LR into a solid block and the pistons would act as shock absorbers, but where the bump-stops are they still wouldn't hit the tracks.
6. if you did run into something totally immobile then the pistons slamming back on their stops would automatically slam on the brakes too!
Anyway, thanks again. I'll put up some more pics when it's more complete. :wacko:
Right, I was wondering why the good Chaplain would suggest that the DA option would remove access to the front ramp when the post actually already answered that :wacko:
Moving the thing up and down makes the most sense but sadly folks are always going to ask how anyone would get out of the front.
I like your explanation Ilmarinen, to think of it as a way to keep the tracks clear. Nice theory (until the belly gets caught up on something ;))
nice work, it looks great as it is, especially after going through the effort of getting an enginners point of view on the design.
I've allways thought of dozer blades for LR being just as you'ved designed. The whole one ramp thing, I think, wouldn't work well with the post-heresy designed LR's, think thay should only be used on the pre-heresey versions!
I take it your dozer blades were from one IG sprue chopped down the middle? Stolen for "Inspiration" ahem
Some more progress:
I'm pretty pleased with how the dozer blades match the overall look of the model. Front mounted sponsons seem more sensible (you can keep firing as you disembark without killing your marines!) but make the LR look a little front heavy - but with the dozer blades the sponsons are more in the middle.
It's another addition to my Deathwatch/Ordo Xenos army. I did try giving the gunner an Adeptus Mechanicus pad, but it didn't really work, so I'm sticking with an ordinary pad. (BTW does anyone know where I can get some of these discontinued 'fist' pads?).
I added the targeter and display on the storm bolter because it didn't look like he'd be able to see past the gun to what he was aiming at! :blink:
Dang, that's a neat trick for the Storm Bolter! Consider that one firmly **yoinked**.
I like how the whole thing is turning out, actually. I tried using the mine plow off an M1 Abrams for mine, but the scale of it is too big, though it'd fit a Baneblade, 1:35 is a little big.
Thanks for the replies. I really like the more high-tech look of the storm bolter - total spur of the moment idea! :lol:
The head is the Deathwatch one.
GW decided to streamline its pad range a while ago (they ran out of room in the warehouse, apparently) so they changed them to sprues of 5 (instead of singles) and, unfortunately, they only kept one 'fist' pad (not the nicest either IMO). So, this one is discontinued, but I'd like to get hold of some more - if anyone knows where.
The only thing I have left to do is to add purity seals, scrolls, icons, etc... (I'm off on hols for a few weeks so it won't be completed for a while yet, and as for painting.......... :blink: ).
